Radiaor Flush Question
Pull the thermostat out and stick the hose in the radiator and turn on high. Then fire up the truck and let the water pump through till clear. Shut off and drain the water out park it nose down on a slope. Then mix your coolant 50/50 and fill the block up till the coolant is level with the thermostat hole. Then replace the thermostat with a new one and install. Top off with coolant. Take it for a ride and allow to cool and check your levels again.
Question on truing my brake rotors
I got a friend's dad to put my rotors up on a lathe and turn them true. He fiddled around with getting them exactly perfect in the lathe for nearly 30 minutes a piece. Then only turned about 5 to 10 thousandths off all 4 rotors. Absolutely smooth and great braking. (Thank you Relentless70)
Varying Temperature
NAPA... I've got Dripley's $10 thermostat and it works fine! http://forum.mopar1973man.com/threads/5637-Would-you-come-forward-please!?highlight=thermostat Typically that would show up as a constant hot engine because of diminished cooling capacity of the radiator. Happens every winter with outside temps in the minus. Still an all the thermostat should closed and keep its heat. Once again consider my minus temperature up north here I still have ZERO problem keeping 190-195 solid all winter long.
coast not working
During this process you should be able to back probe the clockspring also and see if the switch is working or not. Could be a damaged clockspring or a damaged switch. I doubt is a servo problem because if it was you would have trouble either holding cruise or outright shutting it down.
Varying Temperature
Like these guys are showing there is a rare chance that something else will effect weird coolant temperatures. But would rather replace thermostats that guessing at ECM and wiring unless the thermostats don't fix the problems. So make sure to do you testing before buying ECM or wiring harness.
2013 Jet Boat Races in Riggins, Idaho
This river ranges from 40-100 feet deep. In some areas its can be only waist deep. Yeah a fish finder or sonar would be a good idea.
Starts then dies
That the only reason I don't think it will change much. But we need to hear from the OP and find out what he's found any ways...
Varying Temperature
99.9% of the time is a bad thermostat.
How a engine block is made
Another great video on how engine blocks are made.
How a turbo is made
Something I stumbled across on Youtube and figured its worth sharing.
Full Color Wiring Diagrams!
Corrected link. http://forum.mopar1973man.com/downloads.php?do=file&id=220
front axle disconnect
Haven't yet. At least on the 96 Dodge...My 02 is solid axle which is another option to to forcibly lock the axle and leave it locked. There is no real big loss in MPG's with locked really.
vacuum pump seal
Oil Leaks locations [*]Front crank seal [*]Rear Crank seal [*]Tappet cover gasket (or AKA cam cover gasket) [*]Vacuum pump [*]Valve cover gasket (rare) [*]Turbo drain (hose connection) Vacuum leaks As for vacuum lines for the plastic just remove them and flex the line in a big arc and if the line is crack it will continue to crack or break when you bow the plastic because it just plan brittle from age. I just grab some vinyl tubing and replaced all the lines on MoparMom's 96 Dodge for the same issue. Other than that the vacuum pump becomes a air compressor and imitates blow by issues. Personal note: I need to catch you phone call I'll be home tonight!
Prayer Time
Hey gang... Let put THRacing and Rogan into our prayers that they both can over come their medical issues that they are both having! http://forum.mopar1973man.com/threads/7714-re-dad?p=73450#post73450
vacuum pump seal
Vacuum pump blow by is typically created by a vacuum leak in one of the hoses. Broken or cracked piece of plastic tube, harden rubber connectors, etc.I would look at the simple stuff first before yanking put the vacuum pump and power steering box combo to rebuild that vacuum pump. Unless you have a oil leak there too. All diesel engines will have a certain amount of blow by but my rule of thumb is as long as the blow by isn't serve enough to blow oil out the breather tube your fine.
Starts then dies
I don't think that going to work being he might have a sucking air leak downstream.
'99 24v wouldn't start
DANGER! DANGER! THE FUEL INJECTION PUMP SUPPLIES EXTREMELY HIGH FUEL PRESSURE TO EACH INDIVIDUAL INJECTOR THROUGH THE HIGH-PRESSURE LINES. FUEL UNDER THIS AMOUNT OF PRESSURE CAN PENETRATE THE SKIN AND CAUSE PERSONAL INJURY. WEAR SAFETY GOGGLES AND ADEQUATE PROTECTIVE CLOTHING AND AVOID CONTACT WITH FUEL SPRAY WHEN BLEEDING HIGH-PRESSURE FUEL LINES. WARNING: ENGINE MAY START WHILE CRANKING STARTER MOTOR. This goes a long with this thread. WARNING! Very graphic nature http://forum.mopar1973man.com/threads/6090-Hydraulic-Injection-Injury?highlight=injection+injury
Heater Core Questions
Yes... If your going that far you might as well change it out and get a new one. Yours is most likely plugged up with dirt and gunk. You'll see when you pull it out.
axle question
Should be a sticker under the hood, in the glove box and the steel tag on the diff. In the glove box of the 02 http://forum.mopar1973man.com/attachment.php?attachmentid=1539&d=1301768538 Under the hood on the 96..
... Remember it should spit that fairly forceful that VP44 is trying to reach 4,500 PSI just for a idle so if its just dribbling you know you either have air in the system or the VP44 injection pump is not doing so great.
Starts then dies
You might have fuel pressure but if the pump is pushing air into the system then it will stall out every time because air will compress and VP44 won't be able to reach pop pressure so it will stall out. Just because you so fuel pressure make sure you not push a bunch of foam or air too. VP44 just don't like air period.
This evening's road trip...
I rather have a true FLAT bed without all the extra metal sides and added weight. Flatbed should be lighter not heavier than the stock box. Even my old 1972 Dodge Power Wagon had a lighter flat bed than the stock box.
re dad
Sorry to hear about this. Tell your Dad we are behind saying prayers for him.
Valve lash
Guys are right. As long as they all are just a bit tight I would would chalk it up to a overzealous adjustment. Range of allowance.Exhaust - 0.015 to 0.030Intake - 0.006 to 0.015As long as its between these number you good still. Like I using 0.008 and 0.018 for intake and exhaust.
hard starting with fuel pressure
Fuel pressure (idle, cranking, and WOT at highway speed)?Error codes?I would consider re-doing the drawstraw right. That would help a bunch on your problems being it acts like its losing prime because of the bad drawstraw. Or other plumbing issues allowing air to leak back in. Being you have no fuel pressure at start up this points to a air leak more than a VP44 issue.
