Feeling "un-handy" with a Fuel pressure gauage
You on the right track. But I would highly suggest you do a Vulcan Big Line Kit and not use the facory plumbing with FASS DDRP pump it will perform better with 1/2" plumbing.
Radiator leak. Hot tank and repair or get new Rad.
I don't know of any way to repair aluminum radiators. My first thought is to maintain the coolant properly so the pH levels never rot the aluminium and steel parts. So I would just replace the radiator because if it thin in one spot it already thin in several other spots too. If the radiator is thin and leaking I would watch the oil cooler and the heater core closely too.
Might not being the lift pump is not working properly. You might end up loosening the banjo on the VP44 for a moment and bumping the starter and watch for fuel flow. If it just dribbles then the lift pump is shot and the pressure reading are true.
clutch master cylinder?
Last resort trick you might try. Try pumping the clutch pedal several time rapidly and see if that helps the issue. If so you still got air in the line yet. Rapid clutch pedal pumping might work the last bit of air out.
Lift pump just die on you? http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/32-stock-lift-pumps Common failures of the stock lift pump is the plastic hub breaks in the rotor or the check ball regulator fails internally and won't pump pressure at all.
scan gauge
I think the problem lies in the fact there is no real way for the PCM to display true flow information in your case. Then your distances is way off from change in tires so it going to be tough to get accurate information I guess its the end of the road for the SG...
Strange cranking. I'm Stumped. Help!
So if its not the starter then I would follow the cable route. Make sure if you have them made that all the proper wires are soldered into the terminals for you.
Questions For Electronics Experts?
You mean the shield ground? The black braided cable that goes from the PCM case to the firewall? This doesn't make connection with the harness though.
Well my no start problem is back
Ok... Thinking out loud here.Batteries Good?Battery cables Good?Neutral Safety Switch Good?Ignition Switch Good?Starter Contacts Good?Starter Brushes Good?(Unknown) Is there a starter solenoid relay and fuse is the PDC?
Converting a Dodge RAM 1999 ram 5.9 fuel pump wiring harness to Dodge RAM 2500
Actually I don't think it will work at all because gasoline fuel injection is roughly 40-50 PSI and the diesel lift pump is only 12-15 PSI even if you did get it to work the pressure would be too much for the VP44.
scan gauge
Now you also know that hand math is not accurate either.
No. There is no other ground. The PCM is on the passenger side firewall and the ECM is on the driver side of the engine block. The PCM gets it ground direct from the passenger side ground cable. Then the ECM and VP44 get there ground from the driver side battery cable. As for maintaining my battery cables I never even mess with them, I never bother to clean them, I never have to put sandpaper or wire brush to them. How you might ask? I keep them coated with engine oil that's all. Remember I'm the battery king... My whole house is ran off of 24V battery system.
Slow cranking is most likely starter brushes are wiped out. http://www.fostertruck.com/dodge/
First off no teflon tape and any sender fittings. Make sure the sender had good contact to the banjo bolt (metal to metal). What happens is the teflon insulates the sender from ground so the pressure gauge will show low or nothing. Teflon tape is not a good thing to possibly get into the fuel system to it would most like cause some serious issues.There is a air bubble caught in the filter housing and the drain is show fuel but the air bubble is being forced through the filter towards the VP44 so since air can be compressed the sender is still seeing zero. You should bleed the line at the VP44 by using the schrader valve or cracking the banjo fitting. Then crack 1,3,4 injector lines and crank till you see fuel spray or it starts. Then shut down tighten the injector lines and fire it up.
Realy for the lift pump is safe the current draw is small. I bet Rogan can tell you how much current in mA it takes to trigger a relay.
Already done. The PCM is direct connected to the passenger side battery terminal and has no tie to the body. No. Because most are either weak ground connections (corroded terimnals) or bad alternator diodes. I think the mechanical regulator would be way too harsh on the electronics with the pulse hi and pulse lo type charging like back in the old days there wasn't any electronics really just lights and switches. As for the relay style hook like AirDog and FASS is the best way to hook up the lift pump and keep the heavy current draw off the ECM and prevents damage. But the biggest cause of damage is AC noise that is either cause from loose alternator connection, bad alternator diodes, or bad alternator field brushes... Because technically if the batteries would hold up for ever and never need external charging the ECM and PCM would never take on damage.
Boost fooler?
SuperChips should be a boost fooler anyways like a Smarty. So there is no need for a boost fooler. But you'll need to get a adjustable boost elbow so you can increase the boost of the turbo (This is for manual truck with a HX35W Turbo). If you got a HY35W Turbo (Automatic) then you would use a J Hook to control the wastegate.
scan gauge
Speed variance is from wrong sized tires. Scan Gauge should be calibrated to the GPS not the speedo. Mine does the same thing in the 02 Dodge after 65 MPH. Speedo = 65 - GPS = 65.5 - SGII = 66 Speedo = 70 - GPS = 71.0 - SGII = 71 But there is a slight 0.5 MPH offset and the SGII is calibrated to the GPS not the speedometer.
Must not of bled it out right and have air bubble caught in the system. You must remove the entire htdrualic system to bleed it properly. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/28-transmission-systems/54-hydraulic-clutch-master-and-slave-replacement Yes you can buy them separately.
advice on nv5600
If you pulling the trans out to deal with one part I would get a full rebuild kit anyways...
Best way to spend a few hundred bucks????
HX35W turbo would be a nice upgrade but won't change power at all just reduce EGT's a bit.But now a tuner like a Smarty (65 HP), Edge Comp (120 HP), Edge Juice (120 HP), Quadzilla XLT (65 HP), Power Puck (65 HP), Quadzilla Adrenaline (180 HP) will actually change power. But adding any kind of fueling change I highly suggest gauges if you don't already have them.
finally something easy to fix
Yea... Water pumps are simple job to do on a Cummins.
New. Hello
Welcome to the family. I'm more of the type of person to do the work myself knowing that I done the work to the best of my abilities. So if you not sure of what going on or how to fix it... Please, Please, Please ask lots of questions we'll be more than happy to help out. Maybe if you talk to family members enough you might someone close by willing to help you out.
Wife's missing... last seen driving my truck...
What happened?
isaac
Sound like you guys and gals did ok? :shrug:I'm without TV so news of other areas is by word of mouth.
