Had to do some laundry..
After 30K miles and 1 year! 150K miles and once a year brake fluid changes.
ToyHauler Trip...
Right on Russ... I've got a tale to tell as well soon...
A/C pressures
Hmmm... As stated over on Wikipedia... If its used for inhalers and air soft guns I doubt there is any issues with discharging freon in the atomphere.
Dumping station?
Hmmmm... That a lot of water! Wow!I've only got 50 gallons but mounted at the rear bumper. Which tends to me make me a bit tongue light running full tank which I typically do.I'm really curious of the pin weight...
Who Tows and hits over 30 psi on stock headbolts - headgasket ?
Well I got back from a camping trip and hauling the trailer around. Yes I can tag 35 PSI without thinking but do I really want to hold it? Naw... I typically go over at 20-25 PSI in 4th Gear holding 53-55 MPH... Not a problem!
Got my 5" exhaust in what's next
I'm at 147K miles and going for 200K...* 2 Cycle Oil (128:1 Ratio)* AirDog Filter (3 Micron)* Stock Filter (10 micron)* 17-19 PSI Fuel Pressure or cold temp pressure 15-17 PSI (<+32*F)
I'm not too worried about the coolant passages as much as like the heater core, oil cooler, head gasket, etc. These are THIN items and take very little to ruin. So that why I suggest talking to a radiator shop about the coolant flush so not to make things worse... :smart:As for the callipers that points out what I've always said about full break down of the caliper and cleaning to remove the debris. Over time water and debris build up in the bottom start rusting. 197K miles and still got factory callipers and rotors...
time for the oil change
I've been using Fleetguard filters since the begining. No problems here... As for the filter guru talk to AH64ID...
:doh:Actually you goofed on the brakes. The piston should of been cleaned and not bore honed. Then the piston should of fell to the bottom of the bore without the seals in place. Normally I do have to use a C clamp to push the assembled pistons back in. But the dissembled callipers should allow the piston to fall to the bottom. Honing is only required if the bore is rusted.Now as for the coolant system that was caused from acid or basic coolant erroding the block and other metals. What your looking at is the oxides of those metals. Just because the coolant is still clean and the freeze point is good doesn't mean the pH level is good. As for the cooling system I would ask a local radiator shop on how to clean that up. (Boiling, acid wash, etc.)
Dumping station?
I know where a bunch of RV dump are close to home. But I've also got a clean out on the septic system to allows me to dump at home or clean up the tanks.Just a nasty job no matter how you want to deal with it...
Will tires throw off factory mpg counter
Yes... Oversize tire will effect the overhead computer. The bad part is there is no way for you to recalibrate the output (Flow rate GPH) of the fuel system after changes. So you might be able to correct the speed and distance but you have trouble with flow rates.
Describe timing
All I remember its one of AH64ID's post about the smarty...
Auto batteries for rv
They will work... The difference in design is that starting batteries are more for short high amps where deep cycles are for low long amp draws. Then the starting batteries don't have a well for sulphation where deep cycle batteries have a extra space below the plate for sulphated pate material to drop. So yes they will work but won't last as long as deep cycles...
Fan clutch
:shrug:I change coolant and thermostats yearly and never seen a overheat nor underheat issue yet. This thermostat I got now is a bit low but not bad 185-195*F range still. I may wander a bit on cold days but seem very steady now with summer coming.
Describe timing
Sorry... Wikipedia.org... http://en.wikipedia.org/wiki/Autoignition_temperature
Describe timing
How early or late the injection pulse will occur. But remember as boost rises timing retards. Somewhere around the site in the CR stuff there is a timing map of a stock timing and it got a huge drop in timing.
Coolant flushing
No... Still use a 190*F even towing. Closer you get to 200*F the more efficient the engine runs.
Coolant flushing
Well the only cost there is would be the Anti-freeze (3 gallons) and a thermostat. As for a coolant filter it would be good idea if you can hook it up properly and remember to change the filter every 30K or once a year. 190*F is better. Hotter the better for MPG's reasons. Pulling / Towing has nothing to do with it. It's the age of the coolant. As coolant ages it will drift from neutral pH (7) toward acidic (lower number) or basic (highier number). With 3 year the coolant starts to get corrosive. By 5 years you seeing the rusty color and now its too late oxidation of all the part that the coolant touches in now breaking down. (Radiator, heater core, oil cooler, head gasket, water pump seal and bearings, etc) This is why my block is still spotless and there is no scale blooms in the radiator. All this occurs after the pH level drifts away from 7. So if you want to you can buy a bottle of strips and test your coolant on a regular basis and when it drifts then you can change it. But since the yearly changes (covering 25-30K miles a year) works here perfectly why not?
It not so much the bolts that are a problem because there is several people that push 45-50 PSI of boost with standard head bolts and no problems with the gasket. The problem with the head gasket failing is either coolant or drug based. People that use high levels of Water/meth, nitrous, propane, etc. are more prone to head gasket failure. Kind of like you John I know your setup with Water/Meth so as long as your using more water and less meth your fine.Cylinder pressures are sharply increased with these drugs... Then coupled with weak gaskets from lack of coolant changes and BAM! Now you got a crowd of people claiming you can't make past 30-35 PSI towing without blowing a head gasket.Your right John there is a bunch of different factors the will reduce the longevity of the head gasket...
Fan clutch
Like this? http://forum.mopar1973man.com/downloads.php?do=cat&id=19
Coolant flushing
Drain the system. Pull the thermostat Put a garden hose in the radiator on high flow. Start engine and allow the engine to idle till the water is clear. Drain the system. Re-install thermostat. Re-load with 50/50 coolant and water. 9 years and 180K miles...
vents not moving
Vacuum line is disconnected or broken. Its a safety thing for the defroster vents to be the only thing to operate.
Coolant flushing
Yes I split it out of the other thread to prevent hijacking... (Doing my job!)
Coolant flushing
Any coolant will work. I'm using a prestone, WalMart SuperTech, or Napa coolant.
Door bushing
Years ago I convert a older Dodge Ram Charger to a doorless hunting rig for a friend. What I did was pulled the door pop the pins out and put then in from the other side and sanded the pins slightly. So it was easy to take a small hammer pop the pins and load the door in back and cruise the mountain roads doorless...
