Is Vulcan Performance out of business?
Post a link up please... Or post up a response... Or both... Please!
hello everyone
You said what? I didn't hear ya...
Well things just went from interesting to much worse... Raptor died, VP as well.
Like even my own rig I've got a old school AirDog 150 pump on my truck but I never got a warranty card so I'm screwed any ways. But I've got about 6-7 years now with my AirDog 150 I'm also still running the stock filter as well because of the fuel heater and my minus temp weather I get in Idaho. But even on you setup Raptors will fail out and drop pressure just from a air leak. So if you got a weak connection or loose fitting the air leak could create a problem just like what happen. As for fuel pressure your see way too much change from idle to WOT... Typically normal is 2-3 PSI fall period beyond that you got line restrictions, plugged filters, air leaks, or failing pump. Like my truck I idle at 19 PSI and WOT stompped I can go clean up to 85 MPH, 35 PSI of Boost and still be looking at 17 PSI...
Which fan clutch to get
Grab a cheap one and move on... Rare for fan clutches to fail really.
I just don't get it...
Its a rubber coating paint so basically you'll never get rock chips in the paint. I consider it a fad for the most part like over on RamForum.com a lot of guys are plasti-dipping there rims and other small parts on there vehicle.
Wow! That's a shocker after all these years and now VulcanPerformance has dropped there web site... They will be sorely missed by many people. In the mean time I'll going to ask around and see what I find...
ECM P/N Issues
:doh:Geez... I never gotten straight answer to the ECM problem... I've been following everyone around listening to tales but never gotten straight answer to who can rebuild or replace? I'm sure Dripley will be along today and see this he's got a paperweight ECM on his desk that can't be rebuilt but ended up buy a new one from the dealer. :banghead: I don't know what to say...
Vp whipping a dead horse.
Yes... I shimmed up the spring to give more pressure to the system. I know that both AirDog and FASS sell spring with increase pressures. But the shim idea was quick and fast for getting the pressure up. Make sure the ID of the washer will not interfere with flow and the OD will allow it hold the spring without being oversized.
ECM P/N Issues
As for R&R services I've been told several times that the parts are not available for these ECM's to be rebuilt. So usually they will send it back to you still broken. But I always ask the question why is it that Mopar/Cummins still capable of selling new ones? The parts are there but someone isn't telling a full story...
Turbo Compressor Outlet temperature
Neat calculator... But for what every reason the final temp numbers don't even come close for high boost number (30-35 PSI) for my truck it report like 170-180*F final temp. Not! I've rarely even seen 150*F (Maybe while using my exhaust brake)...:rolleyes:Mine follows the +40*F offset to outside temp rather closely and change very little while even at high boost. But I'll check again...
I "assume" its similar design like the AirDog... The return line should have a spring loaded check ball.
ECM P/N Issues
As far as I've been told that Cummins will not sell ECM's for our truck. As far as Mopar/Dodge Dealer they only sell blank ECM's. Then as from what Bob Wagner with Smarty says that regardless of ECM it can be reflashed with any software as long as it ECM for your generation. (98.5-02).Where to go?
MPG's Reports
Here it is come and claim all you want! http://weatherspark.com/#!dashboard;loc=45.2363,-116.3274;rd=12;ropts=speed:12,loop:1,alpha:0.7;fcs=0;msl=pressureAltimeterMbar;mol=radar;units=temperature:f;graphs=spaitg:1,pressure:1,precipitationRate:0,siitg:1,stidpg:0,smeisg:1,solarPosition:1,humidity:0,saf:0,subZero2:0,windIcons:1,sdpitg:0,windDirection:0,precipitation:0,windSpeed:0,clouds:0,tiles:0,precipitationAmount:0,temperature:1,dewPoint:0
Line-X ALL OF IT!
I've got a buddy just down the road that Line-X his entire Toyota Pickup...
MPG's Reports
Nope... We still got snow in the high country above the house (above 5,000 ft). I need to travel up to 7,000-7,500 ft for the wood cutting hole. Might start in June... For sure July...
Oh... :doh:Your still stock? Wow you do need a box of some sort like a Edge or Quadzilla then a set of RV275 injectors (+40 HP) or maybe +50 HP injectors. If you adding a enhancement box I would go for a Stealth Plate to tap the wire.But your fuel pressure will have to be turned up more for added mods you dropping too low now to add anything to it because it will drop more as you demand more fuel. It time to consider how much your looking to get out of the truck and plan now BEFORE you buy anything. So if you say you going for 350-375 HP total then look at everything on the truck for weak point fix them first before adding the power. The prevents future failures.
MPG's Reports
Sorry if he's looking for mileage he's going to have to get off the interstates and find the back roads and slow down. 70 MPH even in my truck I might get 14-15 MPG at 70-75 MPH even with all the current mods. Speed is a killer...
hello everyone
Welcome to the family... Pull up a chair grab your favorite beverage and do some reading and posting to the other family members here. Sure to make friends in a quick hurry!
That's good news!
MPG's Reports
By next week I'll have some tow time on the RV so I'll post up how ugly that is too...
MPG's Reports
Ok... So what are you paying for diesel right now? Riggins, Idaho - $4.139 New Meadows, Idaho - $4.259 McCall, Idaho - $4.299 Payette, Idaho - $4.149 How far do you have to travel to get fuel? (Round Trip) Riggins, Idaho - 30 miles New Meadows, Idaho - 40 Miles McCall, Idaho - 70 Miles Payette, Idaho - 240 miles You said what?
Cover the WIF lead with a plastic bag and zip tie. The Fuel heater can just hang...
Tranny runnin hot
Are you getting torque converter lockup?Is there any error codes present?Auto's aren't my cup of tea...
One a warm morning above 65-70*F there shouldn't be any grid heaters and both ECT (Engine Coolant) and IAT (Intake Air) should be the same temp. FACT: Both ECT sensor and IAT senor are the same thermosistor. So they both have the same values for resistance and the only difference is the plug and the housing.All this talk about IAT temp no longer even bothers me for fairly stock trucks. The fact is yes after the turbo the air is warmer but after passing through the intercooler it now same temp as the air outside. So now when you enter the manifold that has a coolant passage running with inches of the IAT sensor it hard to get "Cold Air" in the engine. The only way you truly can is mill the entire manifold off, plug the coolant passages and use a racing manifold.But after all my studying of IAT and Intake Air Temps I still say warmer the better for MPG's. When the IAT reaches 100-140*F is the sweet spot for MPG reasons. For racing/performance you'll want to shoot lower like 60-100*F...
Check it... Check your IAT and ECT temp at startup and see if they are the same or close. Or you could break out a DVM and ohm it out... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/59-intake-air-temperature-sensor-iat-sensor [TABLE] [TR] [TD=width: 50%, bgcolor: #3870cc, align: center]Temperature[/TD] [TD=width: 50%, bgcolor: #3870cc, align: center] Resistance[/TD] [/TR] [TR] [TD=width: 50%, align: center] 13°F[/TD] [TD=width: 50%, align: center] 56K ohms[/TD] [/TR] [TR] [TD=align: center] 26°F[/TD] [TD=align: center] 39K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 87ºF[/TD] [TD=width: 50%, align: center] 7.4K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 91°F[/TD] [TD=width: 50%, align: center] 6.8K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 100°F[/TD] [TD=width: 50%, align: center] 5.6k ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 107°F[/TD] [TD=width: 50%, align: center] 4.7K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 112°F[/TD] [TD=width: 50%, align: center] 4.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 119ºF[/TD] [TD=width: 50%, align: center] 3.6K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 123ºF[/TD] [TD=width: 50%, align: center] 3.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 127ºF[/TD] [TD=width: 50%, align: center] 3.0K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 132ºF[/TD] [TD=width: 50%, align: center] 2.7k ohms[/TD] [/TR] [TR] [TD=align: center] 143°F[/TD] [TD=align: center] 2.2k ohms[/TD] [/TR] [TR] [TD=align: center] 148°F[/TD] [TD=align: center] 2.0k ohms[/TD] [/TR] [TR] [TD=align: center] 163°F[/TD] [TD=align: center] 1.5k ohms[/TD] [/TR] [TR] [TD=align: center] 173°F[/TD] [TD=align: center] 1.2k ohms[/TD] [/TR] [TR] [TD=align: center] 184°F[/TD] [TD=align: center] 1.0k ohms[/TD] [/TR] [/TABLE]
