An uncertain noise...
... or maybe your driving a Cummins Diesel! Seriously... Most noises you can isolate by seeing if it changes by acceleration, coasting, putting the transmission in neutral, etc. So if the noise changes it might give a clue to its location.
New Kid From Texas. . .
Welcome to the family... You happen to be from the biggest state that supports the site... Yep Texas is my number #1 state...
Better MPG with Edge EZ on level 3 ???
Something about see someone type fuel prices in a thread and it just "Oh Humm..." but its seem so much more realistic when you see pictures of the pump prices... :wow:Tell you the truth I would do the ScanGauge II before the injectors because even changing your driving habits will improve the MPG's really fast...
Abbreviations ......
Here you go... http://www.dodgeram.org/tech/specs/glossary.htm
1996 Dodge Ram 1500 - Fuel Gauge Sender
Does anyone know if the fuel gauge sender is like the Cummins version? May even a lead on where to get one for a good price? I've got a bad spot in the sender up near the 7/8 of a tank where the gauge drops to empty and then at about 3/4 of tank it pops back up and works again...
scan gauge
But remember ScanGauge II has a new feature coming soon... Datalogging USB function http://www.pureenergysystems.com/store/ScanGauge/USB.htm I'm not sure if UltraGauge can do this??? XGauges http://www.scangauge.com/support/x-gauge-commands/
ScanGauge or UltraGauge is a ultimate tool for MPG's... I can look at the instant display and train my right foot to get what every MPG's I want. Like I can now get 16-17 MPG in the 1996 Dodge Ram 1500 or 21-22 MPG in the 2002 Dodge Ram 2500 (Cummins). When fuel is this expensive you must do what you can to gain all the MPG's you can... Diesel - $4.599 Unleaded - $3.929 Plus - $4.039 Supreme - $4.159 This picture was shot from the pump at New Meadows, ID - Chevron - April, 24 2012
Any hand math to confirm this or even a calibrated ScanGauge II?
1996 Dodge Ram - Stealth Fog/Driving Lights
Well they work awesome the grill has very little impact on the lighting. I've got video of it but working at figuring out Linux ways before firing up the Windows machine (yuk). I'll post the video ASAP... --- Update to the previous post... http-~~-//youtu.be/e0TfquTPNX8
scan gauge
XGauge is preferred... Ultra Gauge is another version of data tool like Scan with different features...
Putting the truck into the shop...
I'm surprised you did find a complete axle from a wrecking yard...
scan gauge
I've got the standard ScanGauge II... So far it worked awesome on both trucks (1996 and 2002). Like today I manage to make a loop down to Ontario, OR over to Nampa, ID and then back to New Meadows, ID at 16.7 MPG on the 1996 Dodge Ram 1500 5.9L V8 Gasser...
ECM compatible?
THRacing is right you got to be careful of the truck of truck your running against. There is roughly 47 different ECM's out there so some may work good for testing and others might not work good at all...HO (6 speed)SO (5 Speed)SO (Automatic Trans)FederalCaliforniaCanadianList goes on...
Russ remember this is the 1996 Dodge Ram 1500 (Gasser) there is lot more room behind that grill compared to the Cummins which has ZERO room...
Getting back into the camper projects...
That truely is awesome work... Wow! You are a handy man for RV projects. :wow:I'm sure that's going to be much nicer RV now because its built your way!
Holy Cow Russ...I love the cabinet owrk that's awesome. Even better yet the fact of where you stuffed the TP roll that is awesome. Heck sitting on my can I have a tough time with where the TP roll where its hanging now... :rolleyes:Then if you get any of those mega rolls you got to remove the roll to lift the lid...
Couple AirDog100 questions
As for the quick connects there has been issues with them leaking air in the past. So yes most people just cut the hose and hose clamp into place on the stock sender. But you'll be looking towards a drawstraw anyways.As for the extra plug...That's for the optional low pressure light that nobody wants to buy...
Mopar1973Man's Crankcase Vent Modification
I know you all know I've got four 100w bulbs on the bottom of both Dodge Ram trucks I have. Well over at RamForum I've seen a few Trucks with hidden fog/driving lights behind the grill. So I went to building the poor mans version from a piece of re-bar and flat stock. So now here is the stealth lights...
What fuel pressure do you run if you have a gauge?
Ok flatlander...
Yes... Bring it on...
I'd love to see pics of this... It gives me ideas too...
New to Cummins, need some possible fuel diagnostics
No... 1/4" ID (6 mm) pipe will only flow roughly 75 GPH and the fitting on the sender is small and restrictive. When I got my AD150 I cheated because I had to travel ASAP and did have the time to install the draw straw. I was having serious issues with fuel pressure and just keeping the pressure up even with 1/2" line hose clampped to the stock sender. As for most people I talk to even with drawstraws inside the stock sender still have problems with the pump drawing out fuel quicker than it can be replenished... But that's what I know...
Newbie in need of advise.
Lift pump is dead... VP44 might have some damage on it. The VP44 should rev clear to 3K or a bit more. But free rev is not a proper fuel pressure test... As in my video you only see about 2-3 PSI drop from idle to WOt which is normal any more that 5 PSI drop or pressure drop below 10 PSI is a instant fail. http-~~-//www.youtube.com/watch?v=grl72Up-8T0 You want to keep it in the green.
A lot of people cut them way too short affraid of the straw sucking to the bottom of the tank. But actually its the reverse as the tank is filled diesel weighs about 6.1 pounds per gallon so the bottom of the tank deflects another 3/8 of a inch and now with a overly short drawstraw a simple sloosh action will give the 1/4 tank issue. Since my drawstraw is cut so close the tank will pull up tight ot the straw as the fuel level drops preventing the 1/4 tank issues as much. Also don't cut the tip at a 45* anlge must be FLAT! You may notch the tip but only 1/16 to 1/8" deep that's all.Don't get me wrong I can still see quarter tank issue but I understand what causes it... This video was shot at about a 1/4 tank...(2:53 is where it falls) http://www.youtube.com/watch?v=grl72Up-8T0
