Texas Hail Storms
Holy Hail... Wow!
oil cooler
That looks like oil on the outside are you sure you did spill oil there adding it to the crankcase? I'd clean it up with some simple green and check it later on and see if it returns...Because that gasket should leak coolant not oil...
What fuel pressure do you run if you have a gauge?
Reason why... Because you got to remember the return line is tiny compared to the 1/2" supply line going to the injection pump. So increasing the fuel pressure over 14 PSI will open the overflow valve which is good but excessive pressure will eventually presurize the return line because its too small to handle the return flow. So like with my setup with cold fuel I see 17 PSI @ idle and 15 @ WOT. But with warm fuel its 19 @ idle and 17 @ WOT... Remember I see much colder temps than most of you flat landers...
Mopar1973Man's Crankcase Vent Modification
No...
RV Tires
Wow! $360 for all four TowMax tires on my Jayco...
Fuel Pressure Gauge Install
1/8" air brake line...
First off you need a truck that spits... Mine don't... Yeah I might drip on the floor now and then from the pipe but I don't have a oil loss problem. Then if I was to do that I would have a huge ball of muddy oil on all the parts from the many many miles of dirt road travel.
Ubuntu/Linux/...
- Good quality body parts?
Have you tried asking your local body shop on where they get there body panels at?- Fuel Pressure Gauge Install
You should mount the sender as far from the VP44 as possible to reduce water hammer damge to the sender. You'd been better off with a mechaincal gauge because the electric sender tend to lose there accuracy over time and mis-read pressure. Mechanical gauges just never seem to wear out. http://articles.mopar1973man.com/general-cummins/36-fuel-system/34-fuel-pressure-gauge-and-water-hammer-effects As for tubing I use Air Brake line (Polyon)...- 4WD CAD questions
I agree with ISX it sound like a vacuum issue...- Slincer Ring Removal
Funny... I just put my silencer ring back in ... :lmao:But yes a pair of small screwdrivers and lift the ring up and the other to push it out of the groove. The is no gain/loss to taking it out or putting it back in... Just extra noise...- RV Tires
Have to look up speed rating with the manufacture or dealer site page...- RV Tires
Yeap those are done... :rolleyes:I've got a set of towmax tire on my Jayco Eagle and absolutely no problems. 235/75 R15 Load Range D's... I know my tires have a 65 MPH speed limit and so does the state of Idaho for towing. But since I live in the mountain its just easier to tow at 55 MPH... Like I said no tire issues... :thumbup2:Just to stir the pot more... :stirthepot:I've got 235/85 R16's ST trailer tires on the truck that are a load range G and zero issues... (Speed rated for 100 MPH)- Most HP on stock clutch
100 HP injectors are a bit big for MPG purpose...As for the clutch its most likely going if its slipping. So the best thing you can do now is put the money away for a new clutch and ready ready to yank it out. Because a clutch should never slip.Quick question is there any fuel leaking or oil leaking around the bellhousing?- quiet down mbpr 4inch
It has something to do with the pure size and length of the pipe that causes them to be loud. It seem the larger diameter tend to drone and amplify sound the longer and larger diameters. After riding in Relentless70 92 Dodge truck with a hood stack proved that to me instantly.- quiet down mbpr 4inch
Could go back to 3" and straight pipe... It not as loud...- Edge Comp and Scangauge
Mine starts out at about 28.6 and goes to 33.7 if I remember right... I never used the SGII for boost reading but its was good for seeing if the sensor actual changes... That's about it... Actually the SG displays PSIa (atomphere) so at idle it should be 14.3 PSIa (0 Boost) and then go up to about 22-25 PSI or 25+14.3=39.3 PSIa --- Update to the previous post... I've got video coming really soon! Processing as we speak! --- Update to the previous post... Here you go... http-~~-//youtu.be/7RhrgFWaIvY- Hmm Starter??
Hmmm... Won't work for me... Closest OReilly's is 180 miles away... So figuring in fuel cost to go get it it would be more like $300 figuring against $4.609 a gallon... When a LarryB contact rebuild is cheap and comes in the mail...- starter
Your welcome... I've used LarryB in both the 96 Dodge Ram 1500 and in the 2002 Dodge Ram 2500 (Cummins) both worked excellent... Also be aware there is a brush kit too for these starters so you really have to break something before needing a replacement...- exhaust
I'm a straight piped 3" for over 7 years and never had a noise complaint and local sheriff doesn't care nor does the state police... As a matter of fact Relentless70 has a 4" hood stack and its fairly quiet. Then to top it off a turbo is considered a muffling device in Idaho so muffler are optional. Might check you local codes to see if turbo is considered a muffling device...- State By State trailer laws for size, speed, etc...
I had to post this up for people... I know there is a lot of guys towing trailers out there and I figure it would be great sticky for the site. http://www.hitchemup.com/statetowinglaws.htm- starter
Yeap... Those are really simple things to rebuild... I remember all those years of buying a starter for my old Charger... Now what I know about starters I'd rather rebuild them myself...- Kickdown linkage
After driving to McCall, ID to take care a few things I relized the transmission shifts much more milder and hold the gear much longer before kicking down ro gear changing. Really a pleasure to drive now and I wonder if the MPG's are rising a bit from it...- Radiator hoses
At about 150K miles I changed my hoses and replaced them I kept the old ones because they look just fine. So as for part store hose are fine... - Good quality body parts?
