Quadzilla won't connect grrrr
What kind of mobile device are you using? Double check the transmitter head to be sure its connected. Does the Quadzilla have good +12V BATT, +12V Keyed, and Ground?
I need to vent before my head explodes
@JAG1 requested that I post this photo. what good is going green if you gotta drag a diesel generator.
Rear Seal for NV5600
That would be agood one for the vendor directory here on the website.
It wasn't till about 4 years ago I bought a new flat screen TV and got Hulu. There is very little I actually do watch. Lately it's mostly NewsMax.
Replacing battery
For the ground I would try to keep it short by jumping off on to the frame rail and the jump from the frame rail again back to the block. That would only have a single long cable to the starter then you can jump off the starter back up to the PDC. That way you don't have overly long runs or attempt to keep them short.
Replacing battery
Battery temp sensor no problem... Battery cables will be a problem... There will be losses for the battery cables. Sensor is going to be nothing being there is no current flow. Reason I know this is after doing solar set ups and even though its a mere 24V system and the panels only give 20 Amps of charge I still had to have 2 ought cable because of the losses of distance. Now kepe in mind the current is much higher and distance will be longer than factory.
Replacing battery
Take a peak at the sensor in the driver tray and figure it out if you can move it but the length of cables from the bed ot the engine and PDC are going to be longer and there will be voltage losses for the length of cable too. Have to remember that starter can pull 700 amps on average.
Pilothouse/RAM3500 build
Some days I wish I had that kind of patience, knowledge, and resources. I'll admit this is quite the project vehicle and will be quite the sight when its done for sure.
Replacing battery
Battery temp sensor started 1994 and always been in the driver side battery tray.
P02E9 - Diesel Intake Air Flow Position Sensor Circuit High
P02E9 - Diesel Intake Air Flow Position Sensor Circuit High Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed-loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: Ignition on. Set Condition: The PCM detects that the Air Intake Throttle Sensor Signal circuit is above a calibrated threshold for a calibrated amount of time. Possible Causes AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT SHORTED TO THE 5-VOLT SUPPLY CIRCUIT AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT OPEN/HIGH RESISTANCE SENSOR GROUND CIRCUIT OPEN/HIGH RESISTANCE EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If there are Mass Airflow Sensor and Turbocharger DTCs present with this DTC, repair the 12- volt Supply circuit for an open or short to ground condition. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds 5. Start the engine and let idle. 6. With the scan tool, read DTCs. Did the DTC reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT FOR A SHORT TO VOLTAGE 1. Turn the ignition off. 2. Disconnect the EGR Airflow Control Valve harness connector. 3. Measure the voltage on the (K672) Air Intake Throttle Sensor Signal circuit at the EGR Airflow Control Valve harness connector. Is the voltage reading above 5.1 Volts? Yes • Repair the (K672) Air Intake Throttle Sensor Signal circuit for a short to voltage. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK FOR THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT SHORTED TO THE (K834) 5-VOLT SUPPLY CIRCUIT 1. Disconnect the PCM C1 harness connector. 2. Measure the resistance between the (K672) Air Intake Throttle Sensor Signal circuit and the (K834) 5-Volt Sensor Supply Circuit at the EGR Airflow Control Valve harness connector. Is the resistance below 10k Ohms? Yes • Repair the short between the (K672) Air Intake Throttle Sensor Signal circuit and the (K834) 5-Volt Sensor Supply Circuit. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K672) Air Intake Throttle Sensor Signal circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance above 5.0 Ohms? Yes • Repair the (K672) Air Intake Throttle Sensor Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. CHECK THE (K934) SENSOR GROUND CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K934) Sensor Ground circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance above 5.0 Ohms? Yes • Repair the (K934) Sensor Ground circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 6 6. CHECK THE EGR AIRFLOW CONTROL VALVE 1. Turn the ignition off. 2. Reconnect the PCM harness connector. 3. Reconnect the EGR Airflow Control Valve harness connector. 4. Ignition on, engine not running. 5. With the scan tool, erase DTCs. 6. While monitoring the scan tool, disconnect the EGR Airflow Control Valve harness connector. 7. With the scan tool, read DTCs. Is DTC P02E9 active? Yes • Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 7 7. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7.Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P02E8 - Diesel Intake Air Flow Position Sensor Circuit Low
P02E8 - Diesel Intake Air Flow Position Sensor Circuit Low Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed-loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: Ignition on. Set Condition: The PCM detects that the Air Intake Throttle Sensor Signal circuit is below a calibrated threshold for a calibrated amount of time. Possible Causes AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT SHORTED TO GROUND AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT OPEN/HIGH RESISTANCE EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If there are Mass Airflow Sensor and Turbocharger DTCs present with this DTC, repair the 12-volt Supply circuit for an open or short to ground condition. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the engine and let idle. 6. With the scan tool, read DTCs. Did the DTC reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT FOR A SHORT TO GROUND 1. Ignition on. 2. Disconnect the EGR Airflow Control Valve harness connector. 3. Disconnect the PCM C1 harness connector. 4. Measure the resistance between ground and the (K672) Air Intake Throttle Sensor Signal circuit at the EGR Airflow Control Valve harness connector. Is the resistance below 10k Ohms? Yes • Repair the (K672) Air Intake Throttle Sensor Signal circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K672) Air Intake Throttle Sensor Signal circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance above 5.0 Ohms? Yes • Repair the (K672) Air Intake Throttle Sensor Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE EGR AIRFLOW CONTROL VALVE 1. Turn the ignition off. 2. Reconnect the PCM harness connector. 3. Reconnect the EGR Airflow Control Valve harness connector. 4. Ignition on, engine not running. 5. With the scan tool, erase DTCs. 6. While monitoring the scan tool, disconnect the EGR Airflow Control Valve harness connector. 7. With the scan tool, read DTCs. Is DTC P02E9 active? Yes • Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
Replacing battery
I know but there is a sensor under the driver side battery that controls the charging rate. Battery temp sensor also controls the high idle and grid heater systems too. Yeah it sound easy to just relocate batteries but it comes with a cost of voltage drop, computer sensor (battery temp).
P02E7 - Diesel Intake Air Flow Position Sensor Performance
P02E7 - Diesel Intake Air Flow Position Sensor Performance h2> Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed-loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: With the engine running. Set Condition: Actual EGR Airflow Control Valve position differs from Commanded EGR Airflow Control Valve position by more than 8% on average, over a 15 second diagnostic window. Possible Causes HIGH RESISTANCE IN THE AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT EGR AIRFLOW CONTROL VALVE OBSTRUCTED/STICKING EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC 1. Start the engine and allow it to idle. 2. With the scan tool, read DTCs. Is the DTC active? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE EGR AIRFLOW THROTTLE CONTROL VALVE 1. Remove the boot from the EGR Throttle Control Valve. Using a mirror, look at the butterfly valve on the inside of the EGR Throttle Control Valve. 2. Start the vehicle, let idle for 10 seconds. 3. Turn ignition off. NOTE: If functioning properly the EGR Throttle Control Valve will close immediately after the engine is shut down. Did the EGR Throttle Control Valve close immediately after the engine was shut down? Yes • Go To 4 No • Go To 3 3. CHECK THE EGR AIRFLOW CONTROL VALVE FOR BINDING OR STICKING 1. Turn the ignition off. 2. Check the butterfly valve for signs of a physical obstruction. Was there an obstruction found? Yes • Repair as necessary. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Replace the EGR Airflow Control Valve in accordance with the service information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. CHECK THE (K672) AIR INTAKE THROTTLE SENSOR SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Disconnect the EGR Airflow Control Valve harness connector. 2. Disconnect the PCM C1 harness connector. 3. Measure the resistance of the (K672) Air Intake Throttle Sensor Signal circuit between the Air Intake Throttle Sensor and the PCM C1 harness connector. Is the resistance below 3.0 Ohms? Yes • Go To 5 No • Repair the (K672) Air Intake Throttle Sensor Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. CHECK THE EGR AIRFLOW CONTROL VALVE 1. Turn the ignition off. 2. Reconnect the PCM harness connector. 3. Reconnect the EGR Airflow Control Valve harness connector. 4. Ignition on, engine not running. 5. With the scan tool, erase DTCs. 6. While monitoring the scan tool, disconnect the EGR Airflow Control Valve harness connector. 7. With the scan tool, read DTCs. Is DTC P02E9 active? Yes • Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 6 6. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P02E3 - Diesel Intake Air Flow Control Circuit High
P02E3 - Diesel Intake Air Flow Control Circuit High Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed- loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: With the ignition on. Set Condition: The Powertrain Control Module detects that the control circuit voltage for the EGR Airflow Control Valve is above the calibrated threshold. Possible Causes AIR INTAKE THROTTLE MOTOR (-) CIRCUIT OPEN/HIGH RESISTANCE AIR INTAKE THROTTLE MOTOR (-) CIRCUIT SHORT TO VOLTAGE AIR INTAKE THROTTLE MOTOR (+) CIRCUIT OPEN/HIGH RESISTANCE AIR INTAKE THROTTLE MOTOR (+) CIRCUIT SHORT TO VOLTAGE EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the engine and let idle for one minute. 6. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K673) AIR INTAKE THROTTLE MOTOR (+) CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the PCM C1 harness connector. 2. Disconnect the EGR Airflow Control Valve harness connector. 3. Measure the voltage on the (K673) Air Intake Throttle Motor (+) circuit at the EGR Airflow Control Valve harness connector. Is there voltage present? Yes • Repair the (K673) Air Intake Throttle Motor (+) circuit for a short to voltage. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (K673) AIR INTAKE THROTTLE MOTOR (+) CIRCUIT FOR A SHORT TO THE (K834) 5 VOLT SUPPLY CIRCUIT 1. Measure the resistance between the (K673) Air Intake Throttle Motor (+) circuit and the (K834) 5 Volt Supply circuit. Is the resistance below 5.0 Ohms? Yes • Repair the short between the (K673) Air Intake Throttle Motor (+) circuit and the (K834) 5 Volt Supply circuit.. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE (K674) AIR INTAKE THROTTLE MOTOR (-) CIRCUIT FOR A SHORT TO VOLTAGE 1. Measure the voltage on the (K674) Air Intake Throttle Motor (-) circuit at the EGR Airflow Control Valve harness connector. Is there voltage present? Yes • Repair the (K674) Air Intake Throttle Motor (-) circuit for a short to voltage. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. CHECK THE (K674) AIR INTAKE THROTTLE MOTOR (-) CIRCUIT FOR A SHORT TO THE (K834) 5 VOLT SUPPLY CIRCUIT 1. Measure the resistance between the (K674) Air Intake Throttle Motor (-) circuit and the (K834) 5 Volt Supply circuit. Is the resistance below 5.0 Ohms? Yes • Repair the short between the (K674) Air Intake Throttle Motor (-) circuit and the (K834) 5 Volt Supply circuit. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 6 6. CHECK THE (K674) AIR INTAKE THROTTLE MOTOR (-) CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K674) Air Intake Throttle Motor (-)circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 7 No • Repair the (K674) Air Intake Throttle Motor (-) circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 7. CHECK THE (K673) AIR INTAKE THROTTLE MOTOR (+) CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K673) Air Intake Throttle Motor (+) circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 8 No • Repair the (K673) Air Intake Throttle Motor (+) circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 8. EGR AIRFLOW CONTROL VALVE 1. Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) 2. Reconnect the EGR Airflow Control Valve harness connector. 3. Reconnect the PCM C1 harness connector. 4. Turn the ignition on. 5. With the scan tool, erase DTCs. 6. Start the engine and allow it to idle for one minute. 7. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 9 No • Repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 9. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P02E2- Diesel Intake Air Flow Control Circuit Low
P02E2- Diesel Intake Air Flow Control Circuit Low Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed- loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: With the ignition on. Set Condition: The Powertrain Control Module detects that the control circuit voltage for the EGR Airflow Control Valve is below the calibrated threshold. Possible Causes AIR INTAKE THROTTLE MOTOR (-) CIRCUIT SHORTED TO GROUND AIR INTAKE THROTTLE MOTOR (+) CIRCUIT SHORTED TO GROUND EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. DTC ACTIVE 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the engine and let idle for one minute. 6. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K674) AIR INTAKE THROTTLE MOTOR (-) CIRCUIT FOR A SHORT TO GROUND 1. Turn the ignition off. 2. Disconnect the EGR Airflow Control Valve harness connector. 3. Disconnect the PCM C1 harness connector. 4. Measure the resistance between ground and the (K674) Air Intake Throttle Motor (-) circuit at the EGR Airflow Control Valve harness connector. Is the resistance below 10k Ohms? Yes • Repair the (K674) Air Intake Throttle Motor (-) circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (K673) AIR INTAKE THROTTLE MOTOR (+) CIRCUIT FOR A SHORT TO GROUND 1. Measure the resistance between ground and the (K673) Air Intake Throttle Motor (+) circuit at the EGR Airflow Control Valve harness connector. Is the resistance below 10k Ohms? Yes • Repair the (K673) Air Intake Throttle Motor (+) circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. EGR AIRFLOW CONTROL VALVE 1. Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) 2. Reconnect the EGR Airflow Control Valve harness connector. 3. Reconnect the PCM C1 harness connector. 4. Turn the ignition on. 5. With the scan tool, erase DTCs. 6. Start the engine and allow it to idle for one minute. 7. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 5 No • Repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6.Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P02E1 - Diesel Intake Air Flow Control Performance
P02E1 - Diesel Intake Air Flow Control Performance Theory of Operation The Exhaust Gas Recirculation (EGR) Airflow Control Valve is controlled by the Powertrain Control Module (PCM) and is actuated by an electric motor. A spring internal to the actuator assembly attempts to drive the valve to the fully-open position. The electric motor works to overcome the spring force when the engine control module commands the valve to close. Position feedback from the valve is sent to the PCM to allow for closed- loop control. Discrepancy in position feedback sent to the PCM, and commanded position sent to the EGR Airflow Control Valve by more than a prescribed amount will result in failure of device rationality diagnostics. Failure to properly actuate the EGR Airflow Control Valve can result in poor engine performance. This may cause active Exhaust Aftertreatment regenerations to last longer. When Monitored: With the ignition on. Set Condition: The Powertrain Control Module (PCM) detects that the EGR Airflow Control Valve is sticking or out of calibration. Possible Causes AIR INTAKE THROTTLE MOTOR (-) CIRCUIT OPEN/HIGH RESISTANCE AIR INTAKE THROTTLE MOTOR (-) CIRCUIT OPEN/HIGH RESISTANCE EGR AIRFLOW CONTROL VALVE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. DTC ACTIVE 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. NOTE: If DTC P02E2 or P02E3 are active, perform diagnosis and repair on those DTCs before continuing with this diagnostic tree. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the engine and let idle for one minute. 6. With the scan tool, read DTCs. Is DTC P02E1 active? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K674) AIR INTAKE THROTTLE MOTOR (-) CIRCUIT FOR HIGH RESISTANCE 1. 2. Turn the ignition off. 3. Disconnect the EGR Airflow Control Valve harness connector. 4. Disconnect the PCM C1 harness connector. NOTE: Check connectors - Clean/repair as necessary. 5. Measure the resistance of the (K674) Air Intake Throttle Motor (-) circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 3 No • Repair the (K674) Air Intake Throttle Motor (-) circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE (K673) AIR INTAKE THROTTLE MOTOR (+) CIRCUIT FOR HIGH RESISTANCE 1. 2. Measure the resistance of the (K673) Air Intake Throttle Motor (+) circuit between the EGR Airflow Control Valve harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 4 No • Repair the (K673) Air Intake Throttle Motor (+) circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. EGR AIRFLOW CONTROL VALVE 1. Turn the ignition off. 2. Reconnect the PCM C1 harness connector. 3. Ignition on, engine not running. 4. Using a voltmeter connected to ground, measure the voltage on the: • (K673) Air Intake Throttle Motor (+) circuit at the EGR Airflow Control Valve harness connector. • (K674) Air Intake Throttle Motor (-) circuit at the EGR Airflow Control Valve harness connector. NOTE: The voltage on the control circuits should read approximately battery voltage. Are both measurements equal to battery voltage? Yes • Replace the EGR Airflow Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Overheating due to a poor connection (terminal may be discolored due to excessive current draw). Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0219 - Engine Overspeed
P0219-ENGINE OVERSPEED Theory of Operation The Crankshaft Position (CKP) and Camshaft Position (CMP) Sensors are hall effect type sensors. The Powertrain Control Module (PCM) provides a 5-Volt supply to the position sensor and return circuit. A notch on the crankshaft gear is used to determine the speed of the engine by the PCM. As the notch on the crankshaft speed ring or the windows in the back of the camshaft gear move past the position sensor, a signal is generated on the position sensor circuit. The PCM interprets this signal and converts it to an engine speed. When Monitored: While the engine is running. Set Condition: The Powertrain Control Module (PCM) detects engine speed is above a calibrated threshold. Possible Causes MECHANICAL OVERSPEED OF ENGINE Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. OTHER DTCS 1. Turn the ignition on. 2. With the scan tool, read and record the freeze frame data. 3. With the scan tool, read the Engine DTCs. Are there other Crankshaft Position Sensor DTCs set? Yes Repair any other Crankshaft Position Sensor DTCs. No Go To 2 2. MECHANICAL OVERSPEED OF ENGINE NOTE: The most likely cause of this DTC is a mechanical overspeed. Examples of this could be downshifting into to low of a gear on a manual transmission or pulling a heavy load on a steep downgrade. 1. Visually inspect the engine for signs of mechanical overspeed. Such as, bent push rod, broken rocker arms, bent valves, flywheel bolts backing out, etc. Did you notice any overspeed damage? Yes • Repair or replace any damaged components. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test Complete.
P0218 - Transmission High Temperature Operation Activated
P0218 - Transmission High Temperature Operation Activated Theory of Operation The DTC is intended as an informational DTC to aid the technician in determining the root cause of a customer dirveability issue. The DTC is also intended to alert the technician to determine if a cooling system malfunction has occurred or if an additional transmission air to oil cooler is needed to support the customers driving behavior. When Monitored and Set Conditions When Monitored: • This diagnostic runs continuously when the Engine is running. Set Conditions: • Transmission temperature exceeds 116° C or 240° F Default Actions: • Overheat shift schedule is activated. Possible Causes HIGH TEMPERATURE OPERATION ACTIVATED TORQUE CONVERTER CLUTCH SLIPPING / NOT ACTIVATING OPERATING VEHICLE WITH TRANSMISSION IN LIMP-IN MODE FOR AN EXTENDED PERIOD OF TIME RESTRICTED TRANSMISSION COOLER OR COOLER LINE TRANSMISSION BYPASS COOLER VALVE (THERMOSTAT) EXCESSIVE TIME IDLING IN GEAR Always perform the Transmission PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). HIGH TEMPERATURE OPERATION NOTE: This DTC is an informational DTC designed to aid the Technician in diagnosing shift quality complaints. NOTE: This DTC indicates that the transmission has been operating in the "Overheat" shift schedule which may generate a customer complaint. NOTE: The customer driving patterns may indicate the need for an additional transmission oil cooler. NOTE: If the Transmission has experienced a catastrophic failure, the Transmission Cooler must be replaced. 1. Verify proper Engine cooling system operation which would affect proper transmission operation. 2. Verify proper operation of the Transmission Bypass Cooler Valve (Thermostat). (Refer to 07 - Cooling/Transmission/COOLER, Transmission Oil/Operation) . 3. Verify the Transmission Cooler and Cooler Lines are not restricted. 4. Verify proper torque converter clutch operation. 5. With the scan tool, check the Event Data to help identify the conditions in which the DTC was set. Were any of the above problems identified as the probable cause? Yes • Repair the cause of transmission overheating. Perform the PRELIMINARY CHECKS procedure. (Refer to 07 - Cooling - Diagnosis and Testing) . Make sure to check for any Service Bulletins pertaining to this problem. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). • Test Complete.
P0217 - Coolant Temperature Too High
P0217 - Coolant Temperature Too High Theory of Operation The Coolant Temperature Sensor is a variable resistor sensor and is used to measure the temperature of the coolant of the engine. The PCM supplies 5-Volts to the Engine Coolant Temperature Sensor (ECT) Signal circuit. The PCM monitors the change in voltage caused by changes in the resistance of the sensor to determine the coolant temperature. The engine coolant temperature value is used by the PCM for the engine protection system and engine emissions control. The Engine Coolant Temperature Sensor is located near the thermostat housing. This fault becomes active when the PCM detects a coolant temperature higher than a calibrated limit for a calibrated amount of time. The PCM illuminates the MIL lamp after the diagnostic runs and fails once. During this time the customer may experience an engine power derate, and regeneration mode will be disabled. The PCM will turn off the MIL lamp after the diagnostic runs and passes in four consecutive drive cycles. When Monitored: While the engine is running. Set Condition: The engine coolant temperature is above a calibrated value for a calibrated amount of time. Possible Causes COOLING SYSTEM FAILURE ECT SENSOR MECHANICAL FAILURE Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. COOLING SYSTEM FAILURE NOTE: If other cooling system DTCs are present, repair those DTCs before proceeding. 1. Check the engine cooling system operation. Refer to cooling, Diagnosis and Testing, Preliminary check. (Refer to 07 - Cooling - Diagnosis and Testing) . Is the Cooling system operating normally? Yes Go To 2 No Repair the cooling system failure. Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE ECT SENSOR 1. Allow the engine to reach normal operating temperature. 2. Use a temperature probe and measure the engine temperature near the ECT Sensor. 3. With the scan tool, read the Engine Coolant Temperature. 4. Compare the temperature probe reading with the scan tool reading. Are the readings within 10°F of each other? Yes Repair the cause of mechanical failure. Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No Replace the Engine Coolant Temperature Sensor in accordance with the Service Information.(Refer to 07 - Cooling/Engine/SENSOR, Coolant Temperature/Removal) Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
Keep going... I wanna see this thing rolling soon.
Replacing battery
Look up voltage loss over distance. Long battery cables have less power. Colder batteries don't recharge very fast. This is why the batteries are under the hood to allow them to get warm possibly to aid in charging speed.
Xotic vs ARP Head Studs
I took the advise of @dieselautopower when I bought my ARP studs from them. Sometimes its best to discuss things with the vendors. Like myself I trust @dieselautopower completely to provide quality products. So far in all the stuff I've bought for my truck or customer trucks the failure rate is very low. Don't get me wrong nothing is absolutely perfect and crap happens but to have a vendor that stand behind there products with quality service can't go wrong.
Midna's build
As far as I've ever seen they are just push fit into the block.
Replacing battery
Yeah like here we are forecasted for single digit nights again. Sure not a time for a single battery for sure. There is a reason why Dodge ditched the single battery design in the 1st Gen and upgraded to dual batteries in 94 in the 2nd Gens.
Dripley is Okay....
Nothing current from me but I could give him a shout this morning and check in on him.
