  1. Got my vote I wanna see this vehicle too.
  2. No. Don't bother with a hot rod pump. Only roughly 20 HP gain. Makes a problem for tuning being the hot rod pump mechanically advanced internally. Better of with stock SO pump
  3. Me I only run 7 levels being it splits the wire tap up by 25% per level. Actually level 2 is the best for MPG. Level 3 is better for all around driving. 4 and up is all wire tap. Again the biggest feature to my tunes is no extra power is giving below 15 PSI which makes for more daily driver fueling. Now if you in it for performance then you should make a second tune that is economy and then the other for performance so you can pour on the fuel early and heavy. Then like when spring get here I'll be towing my RV more and have a 3rd tune for strictly for towing. So power levels... 0 - Stock ECM 1 - Valet mode 2 - Stock Fuel no added fuel above 100% 3 - CANBus fuel 4 and up is all wire tap settings. You can break this up and have 10% per level or anything in between.
  4. I've been doing the chat on the phone and build tunes too. I've helped @Sycostang67 build his tune. There are a few here I've been helping setup Quadzillas and diagnose performance issues.
  5. There is articles on how to build tunes here in the article section. Then in the download section there are some pre-made tunes including my current tune I'm running.
  6. I run level 2 and can still smoke the tires. Tame ha! Now go 425 miles on a half tank of fuel.
  7. Stock tune is pretty derated in timing. Once you build a good timing curve it will be even better. Fuel map is fairly easy but there is a few tricks.
  8. Same here I did my own service all these years to keep my Mom alive. My part is I feel guilty for just doing my job and not doing it slower and doing write ups like I did in the past. Part of that is the weather and the mess I'm still dealing with between my ex-gf and her son. Now I want to get back to what made the website great too. Start doing 3rd Gen write ups.
  9. Well finally might get above freezing from here out. Highs near 50°F and raining maybe 0.1 to 0.25 inches. Be nice for once be like a heat wave.
  10. I know the feeling at times. For me it the point that I can't go any where without someone asking me about their truck or vehicle. The other half is just being greasy dirty everyday.
  11. Wow. You need to get on a creeper and roll under there a bit more often. Seriously...
  12. Yup. One the scale it's 7,300 pound empty curb weight. Just added the two numbers together.
  13. Might read W-T original article which goes into more detail.
  14. Door sticker is inflation for max weight capacity. Kind of like my truck 65 PSI in the front then 80 PSI in the rear. Now doing it correct. Front axle is 4,440 pounds, and 2860 pounds in the rear. Tires are Es with 3,042 PSI at 80 PSI. (4,440 / 2) = 2,220 / 3,042 = 0.72 × 80 = 58.3 PSI Front inflation (2,860 / 2) = 1,430 / 3,042 = 0.47 × 80 = 37.6 PSI Rear inflation Smooth ride and no impact on performance or economy.
  15. Nope. That will work but make sure to make a sleeve for the inserting of the new seal. I think I got a chunk of exhaust pipe wrapped electrical tape around the edge for padding.
  16. @Silverwolf2691 hey if I want to know what is coming at me I just call @JAG1 he gets the weather before I do.
  17. I did and was going through my parents stuff and found all the photos. So time machine back to 1987 and I was 17 years old work on my 1973 Dodge Charger SE.
  18. You want a bit of slack in the cable to ensure that the brake arms are returned FULLY. Now you can adjust your slack in the shoes using the starwheel. Once the brake shoes are lightly dragging. Now you can re-adjust the cable slack till it is just about ready to pull the cable. Why? Because I've seen cases where people adjusted the parking brake using the cable slack adjustment and have the cable pulled half the stroke and wonder why it will not hold on a slope. You gotta make sure the brake arms are FULLY returned before adjusting the slack of the shoes. Now you get a full pull and the truck holds much better than just wheeling up the slack adjustment and find out you only getting half pull and won't stay parked.
  19. That job right now is closed till spring time. Being McCall / Donnelly is still cold and snowing and I've got to work outside no shop. I still do small task for the group but right now its just been cold and slow for everything even here. Again this morning looking at the weather tower and 17*F this morning there is nothing at this time that requires me to head out in the bitter cold it can wait. After doing a start 2 days ago on a 7.3L Ford I was have issues in a very short order trying to even pick up the tiny 8mm nut for the starter because my fingers froze up quick. Gloves... Worthless then I lose all my dexterity so right now I'm just holding and waiting.
  20. Starwheel is use to take up slack in the shoes to drum clearance. Do not adjust the cable for this. The cable adjustment is only take slack out of the cable. This adjust should allow for full return of both arms in the hubs. If not it's TOO TIGHT.
  21. W-T is suggesting adding a second ground across the radiator to the driver side. Measuring voltage drop between the battery and block won't change. Way to test, is use jumper cables and jump between both negative terminals and check for volt age drop again. So far I've not found any gains.
  22. Ha! I did the same thing ordered a set of brake shoes for the parking brake and found out I just needed to adjust them. It might be worth doing a quick inspect before ordering parts so you not buying stuff you really don't need. Like myself I've got a 125 mile trip to return my brake shoes which I'll just keep them for now.
  23. You get what you pay for you want cheap your going to get cheap quality. I'll admit Autometer and ISSPro are expensive BUT you get the quality behind that price. Still to this day I would rather build using ISSPro EV2 series gauges over even the ISSPro EV (Mechanical). Being the is no tubing or live fuel in the cab. The electrical is extremely easy to set up and even daisy chain gauges together, huge bonus. The programmable relay option of the EV2 is cool for thing like trans temp gauge to have the relay to control your cooling fan. All USB adjustable inluding warning lights for out of range values. For example EGT gauge set the warning light for above 1,200*F temps. That way you will see that little red LED glow when temp are out of range and don't need to watch close just mind the light position and you'll know which gauge it is.
  24. +11*F here this morning and with a wind of 8 to 12 MPH makes it feel like -2*F with a Wind chill of -2*F. Nope. I'm going to sit right here for a while longer before heading out to the shop to work. I don't get paid enough to work in that cold of temps. Ugh. Yeah, I'm going to move a vehicle out of the shop start a fire and move the other in for a new pan gasket. (1996 Chevy 1500 with a 350 CID). Sloppy job but gotta be done.
  25. If diodes are damaged either replace the diodes or just replace the alternator. Might look up local alternator rebuilder for diodes.
