Midna's build
As far as I've ever seen they are just push fit into the block.
Replacing battery
Yeah like here we are forecasted for single digit nights again. Sure not a time for a single battery for sure. There is a reason why Dodge ditched the single battery design in the 1st Gen and upgraded to dual batteries in 94 in the 2nd Gens.
Dripley is Okay....
Nothing current from me but I could give him a shout this morning and check in on him.
Replacing battery
Consider this... OEM batteries lasted 10 years 1st WalMart Batteries lasted 8 years (Ran dead ZERO volts twice) 2nd Walmart - Currently installed.
Replacing battery
WalMart 810 CCA. Same manufacture as OEM batteries with a small bonus over the stock 750 CCA that were installed during manufacture. Being two 750 CCAs total 1,500 CCA. Now consider WalMart 810 CCA is going to be 1,620 CCA. https://www.walmart.com/ip/EverStart-Maxx-Lead-Acid-Automotive-Battery-Group-Size-27-12-Volt-810-CCA/28275658
Thermostat for 2018
Typically the part number is prefixed with SS for those thermostats.
Replacing battery
Not long in the cold of winter being the total load of the starter is much much higher than the grid heaters. It at least 700 Amps for a cold start. This is why dual batteries should be installed and not a single being the the total load is nearly the full capacity of a single battery.
Dana 80-Yoke & Seal Info
On both front or rear vents!
AirDog 4G
I guess I've never had the chance to install a 165 Airdog yet. I've got a AirDog 165 GPH pump head mounted to my 150 GPH base and works just the same as my old 150 GPH. Same pressures no real change.
Thermostat for 2018
NAPA 375-180 - 180F thermostat NAPA 375-190 - 190F thermostat After seeing a local gent that I told to consider the Cummins thermostat and it separated. Be aware Cummins does NOT produce any thermostats but what Cummins does sell is produced by Holley / Mr. Gasket. The current Robertshaw design that I called Robertshaw and was told that Robertshaw no longer makes that thermostat but Holley / Mr. Gasket bought the design which produces Cummins thermostat as well. Only reason I prefer the NAPA is because they have been upgrading all along making improvement where Cummins went backwards and started selling junk.
Thermostat for 2018
Do not use the Cummins Thermostat its NOT a quality unit. I've seen a few fall apart and separate. Matter of fact I will not buy Cummins anything much anymore...
Up to 70° tomorrow! Can't wait.
For me... The weather warmed up for about 3 days snow is about all gone in the yard now. Now going through the mud phase where the ground thaws on top and mud central. Now its starting to dry out and firm up again...
Painting Valve Cover
Oh I could have way too much fun with this but knowing it will cost a pretty penny for this kind of powder coating.
Need a sanity check.. changing careers
Do what you have to do to be happy. That is important!!! If your not happy then everything else around you will start to fail. Trust me I do understand... I've worked several different jobs in my time. Dish pit - Cattlemen's Restaurant (2 years) Glass and mirror installer - Images in Mirror and Glass (2 years) Ranch Hand helping with branding cows - Rex Baker's Ranch 2 Body shops (motorcycle and automotive) Salvage yard & Tom's Body Shop Software distributor -Soft Kat Harness assembly for wiring 2 Tire and battery shops - Montgomery Wards & Chevron Computer tech (Windows) - Cloud 10 Computers (8 years) Computer Tech (Linux) - Mopar1973Man.Com (18 years) Car stereo installer and repair - Sights & Sounds (3 years)
Just to show where I'm thinking at... After @MoparMompassed away it's been a crazy roller coaster ride for me. Now having that stroke of luck and getting that job working for the billionaire family in McCall. But that job is seasonal being I'm working on the ground and outdoors and from Thor as a tool truck. Since winter came and set in I've been complaining about working in the cold all this winter and it sucks no doubt when you are dealing with near ZERO degrees. Now with Russian War starting I was considering doing mobile work for website members but now with the price of fuel going up even more cancel that idea. Matter of fact if I can be promised at least a full shop hour before I leave the property for a local job with Thor there is no reason to leave. Now as for the town of Riggins, Idaho doesn't get me wrong there is a lot of good people there but it's mostly retirees and social security incomes. I'm getting tired of doing jobs and waiting for payment for the jobs. So even I'm slowing down because I need to reclaim some of my monies. I'm starting to consider working more on the website and getting more done here being it costs less to keep going. So I'm patiently waiting to see what will happen by springtime if my jobs up there open back up but I'm not going to put all my eggs in that one basket just too foolish.
- Painting Valve Cover
Sounds like a solid plan. I don't think the valve cover is much more than the standard 190*F to 210*F in temperature at the worst. It should hold up to the temperature being there is several other trucks with paint matched parts under the hood.- Need a sanity check.. changing careers
Something to consider like myself since I'm self employed as well. Like here locally the money isn't here in the Riggins, ID area. I've still got to wait till the snow leaves the McCall / Donnelly, ID area and that will be some time yet. I've been traveling day trips to do jobs around my local state. Even that is getting questionable now with the "Russian War" and price of fuel heading up quickly. Now I'm considering looking toward web support more so being that travel is going to get super expensive. Idaho diesel prices are heading up fast and talks of 5, 6 or 7 dollar a gallon diesel prices coming soon. Now I'm keeping an open mind of what and where I'm even doing for employment being I want to keep my expenses low.- Bosch Alternator
I started out with a Bosch alternator from factory. Now after the first failure back at around 200k miles I replaced with ND alternators either alternator will hold up as long as the W-T ground wire mod is done. Without the W-T either Bosch or ND alternator will fail and typically take either the brushes, slip rings and/or the diodes out. After that I've had good luck with both ND and Bosch alternators.- How long to change injectors?
Tuning and driving style make impacts that may or may not improve MPG numbers. Like the combo I done with the Quadzilla tune and 150 HP injectors popped at 320 bar this made 28.04 MPG. Like the last time was 75 HP injectors and Edge Comp tuner but there was limitations. Still made 27.2 MPG. Secret is keeping the Engine load and Engine load low as possible. Anything that creates heat is where the power is lost at only because any thing creating heat is steal some of the energy to create said heat.- Pilothouse/RAM3500 build
Got my vote I wanna see this vehicle too.- DAP Hot Rod VP44
No. Don't bother with a hot rod pump. Only roughly 20 HP gain. Makes a problem for tuning being the hot rod pump mechanically advanced internally. Better of with stock SO pump- Head studs, valve springs, what else?
Me I only run 7 levels being it splits the wire tap up by 25% per level. Actually level 2 is the best for MPG. Level 3 is better for all around driving. 4 and up is all wire tap. Again the biggest feature to my tunes is no extra power is giving below 15 PSI which makes for more daily driver fueling. Now if you in it for performance then you should make a second tune that is economy and then the other for performance so you can pour on the fuel early and heavy. Then like when spring get here I'll be towing my RV more and have a 3rd tune for strictly for towing. So power levels... 0 - Stock ECM 1 - Valet mode 2 - Stock Fuel no added fuel above 100% 3 - CANBus fuel 4 and up is all wire tap settings. You can break this up and have 10% per level or anything in between.- Head studs, valve springs, what else?
I've been doing the chat on the phone and build tunes too. I've helped @Sycostang67 build his tune. There are a few here I've been helping setup Quadzillas and diagnose performance issues.- Head studs, valve springs, what else?
There is articles on how to build tunes here in the article section. Then in the download section there are some pre-made tunes including my current tune I'm running. - Painting Valve Cover
