P0218 - Transmission High Temperature Operation Activated
P0218 - Transmission High Temperature Operation Activated Theory of Operation The DTC is intended as an informational DTC to aid the technician in determining the root cause of a customer dirveability issue. The DTC is also intended to alert the technician to determine if a cooling system malfunction has occurred or if an additional transmission air to oil cooler is needed to support the customers driving behavior. When Monitored and Set Conditions When Monitored: • This diagnostic runs continuously when the Engine is running. Set Conditions: • Transmission temperature exceeds 116° C or 240° F Default Actions: • Overheat shift schedule is activated. Possible Causes HIGH TEMPERATURE OPERATION ACTIVATED TORQUE CONVERTER CLUTCH SLIPPING / NOT ACTIVATING OPERATING VEHICLE WITH TRANSMISSION IN LIMP-IN MODE FOR AN EXTENDED PERIOD OF TIME RESTRICTED TRANSMISSION COOLER OR COOLER LINE TRANSMISSION BYPASS COOLER VALVE (THERMOSTAT) EXCESSIVE TIME IDLING IN GEAR Always perform the Transmission PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). HIGH TEMPERATURE OPERATION NOTE: This DTC is an informational DTC designed to aid the Technician in diagnosing shift quality complaints. NOTE: This DTC indicates that the transmission has been operating in the "Overheat" shift schedule which may generate a customer complaint. NOTE: The customer driving patterns may indicate the need for an additional transmission oil cooler. NOTE: If the Transmission has experienced a catastrophic failure, the Transmission Cooler must be replaced. 1. Verify proper Engine cooling system operation which would affect proper transmission operation. 2. Verify proper operation of the Transmission Bypass Cooler Valve (Thermostat). (Refer to 07 - Cooling/Transmission/COOLER, Transmission Oil/Operation) . 3. Verify the Transmission Cooler and Cooler Lines are not restricted. 4. Verify proper torque converter clutch operation. 5. With the scan tool, check the Event Data to help identify the conditions in which the DTC was set. Were any of the above problems identified as the probable cause? Yes • Repair the cause of transmission overheating. Perform the PRELIMINARY CHECKS procedure. (Refer to 07 - Cooling - Diagnosis and Testing) . Make sure to check for any Service Bulletins pertaining to this problem. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). • Test Complete.
P0217 - Coolant Temperature Too High
P0217 - Coolant Temperature Too High Theory of Operation The Coolant Temperature Sensor is a variable resistor sensor and is used to measure the temperature of the coolant of the engine. The PCM supplies 5-Volts to the Engine Coolant Temperature Sensor (ECT) Signal circuit. The PCM monitors the change in voltage caused by changes in the resistance of the sensor to determine the coolant temperature. The engine coolant temperature value is used by the PCM for the engine protection system and engine emissions control. The Engine Coolant Temperature Sensor is located near the thermostat housing. This fault becomes active when the PCM detects a coolant temperature higher than a calibrated limit for a calibrated amount of time. The PCM illuminates the MIL lamp after the diagnostic runs and fails once. During this time the customer may experience an engine power derate, and regeneration mode will be disabled. The PCM will turn off the MIL lamp after the diagnostic runs and passes in four consecutive drive cycles. When Monitored: While the engine is running. Set Condition: The engine coolant temperature is above a calibrated value for a calibrated amount of time. Possible Causes COOLING SYSTEM FAILURE ECT SENSOR MECHANICAL FAILURE Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. COOLING SYSTEM FAILURE NOTE: If other cooling system DTCs are present, repair those DTCs before proceeding. 1. Check the engine cooling system operation. Refer to cooling, Diagnosis and Testing, Preliminary check. (Refer to 07 - Cooling - Diagnosis and Testing) . Is the Cooling system operating normally? Yes Go To 2 No Repair the cooling system failure. Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE ECT SENSOR 1. Allow the engine to reach normal operating temperature. 2. Use a temperature probe and measure the engine temperature near the ECT Sensor. 3. With the scan tool, read the Engine Coolant Temperature. 4. Compare the temperature probe reading with the scan tool reading. Are the readings within 10°F of each other? Yes Repair the cause of mechanical failure. Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No Replace the Engine Coolant Temperature Sensor in accordance with the Service Information.(Refer to 07 - Cooling/Engine/SENSOR, Coolant Temperature/Removal) Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
Pilothouse/RAM3500 build
Keep going... I wanna see this thing rolling soon.
Replacing battery
Look up voltage loss over distance. Long battery cables have less power. Colder batteries don't recharge very fast. This is why the batteries are under the hood to allow them to get warm possibly to aid in charging speed.
Xotic vs ARP Head Studs
I took the advise of @dieselautopower when I bought my ARP studs from them. Sometimes its best to discuss things with the vendors. Like myself I trust @dieselautopower completely to provide quality products. So far in all the stuff I've bought for my truck or customer trucks the failure rate is very low. Don't get me wrong nothing is absolutely perfect and crap happens but to have a vendor that stand behind there products with quality service can't go wrong.
Midna's build
As far as I've ever seen they are just push fit into the block.
Replacing battery
Yeah like here we are forecasted for single digit nights again. Sure not a time for a single battery for sure. There is a reason why Dodge ditched the single battery design in the 1st Gen and upgraded to dual batteries in 94 in the 2nd Gens.
Dripley is Okay....
Nothing current from me but I could give him a shout this morning and check in on him.
Replacing battery
Consider this... OEM batteries lasted 10 years 1st WalMart Batteries lasted 8 years (Ran dead ZERO volts twice) 2nd Walmart - Currently installed.
Replacing battery
WalMart 810 CCA. Same manufacture as OEM batteries with a small bonus over the stock 750 CCA that were installed during manufacture. Being two 750 CCAs total 1,500 CCA. Now consider WalMart 810 CCA is going to be 1,620 CCA. https://www.walmart.com/ip/EverStart-Maxx-Lead-Acid-Automotive-Battery-Group-Size-27-12-Volt-810-CCA/28275658
Thermostat for 2018
Typically the part number is prefixed with SS for those thermostats.
Replacing battery
Not long in the cold of winter being the total load of the starter is much much higher than the grid heaters. It at least 700 Amps for a cold start. This is why dual batteries should be installed and not a single being the the total load is nearly the full capacity of a single battery.
Dana 80-Yoke & Seal Info
On both front or rear vents!
AirDog 4G
I guess I've never had the chance to install a 165 Airdog yet. I've got a AirDog 165 GPH pump head mounted to my 150 GPH base and works just the same as my old 150 GPH. Same pressures no real change.
Thermostat for 2018
NAPA 375-180 - 180F thermostat NAPA 375-190 - 190F thermostat After seeing a local gent that I told to consider the Cummins thermostat and it separated. Be aware Cummins does NOT produce any thermostats but what Cummins does sell is produced by Holley / Mr. Gasket. The current Robertshaw design that I called Robertshaw and was told that Robertshaw no longer makes that thermostat but Holley / Mr. Gasket bought the design which produces Cummins thermostat as well. Only reason I prefer the NAPA is because they have been upgrading all along making improvement where Cummins went backwards and started selling junk.
Thermostat for 2018
Do not use the Cummins Thermostat its NOT a quality unit. I've seen a few fall apart and separate. Matter of fact I will not buy Cummins anything much anymore...
Up to 70° tomorrow! Can't wait.
For me... The weather warmed up for about 3 days snow is about all gone in the yard now. Now going through the mud phase where the ground thaws on top and mud central. Now its starting to dry out and firm up again...
Painting Valve Cover
Oh I could have way too much fun with this but knowing it will cost a pretty penny for this kind of powder coating.
Need a sanity check.. changing careers
Do what you have to do to be happy. That is important!!! If your not happy then everything else around you will start to fail. Trust me I do understand... I've worked several different jobs in my time. Dish pit - Cattlemen's Restaurant (2 years) Glass and mirror installer - Images in Mirror and Glass (2 years) Ranch Hand helping with branding cows - Rex Baker's Ranch 2 Body shops (motorcycle and automotive) Salvage yard & Tom's Body Shop Software distributor -Soft Kat Harness assembly for wiring 2 Tire and battery shops - Montgomery Wards & Chevron Computer tech (Windows) - Cloud 10 Computers (8 years) Computer Tech (Linux) - Mopar1973Man.Com (18 years) Car stereo installer and repair - Sights & Sounds (3 years)
Just to show where I'm thinking at... After @MoparMompassed away it's been a crazy roller coaster ride for me. Now having that stroke of luck and getting that job working for the billionaire family in McCall. But that job is seasonal being I'm working on the ground and outdoors and from Thor as a tool truck. Since winter came and set in I've been complaining about working in the cold all this winter and it sucks no doubt when you are dealing with near ZERO degrees. Now with Russian War starting I was considering doing mobile work for website members but now with the price of fuel going up even more cancel that idea. Matter of fact if I can be promised at least a full shop hour before I leave the property for a local job with Thor there is no reason to leave. Now as for the town of Riggins, Idaho doesn't get me wrong there is a lot of good people there but it's mostly retirees and social security incomes. I'm getting tired of doing jobs and waiting for payment for the jobs. So even I'm slowing down because I need to reclaim some of my monies. I'm starting to consider working more on the website and getting more done here being it costs less to keep going. So I'm patiently waiting to see what will happen by springtime if my jobs up there open back up but I'm not going to put all my eggs in that one basket just too foolish.
- Painting Valve Cover
Sounds like a solid plan. I don't think the valve cover is much more than the standard 190*F to 210*F in temperature at the worst. It should hold up to the temperature being there is several other trucks with paint matched parts under the hood.- Need a sanity check.. changing careers
Something to consider like myself since I'm self employed as well. Like here locally the money isn't here in the Riggins, ID area. I've still got to wait till the snow leaves the McCall / Donnelly, ID area and that will be some time yet. I've been traveling day trips to do jobs around my local state. Even that is getting questionable now with the "Russian War" and price of fuel heading up quickly. Now I'm considering looking toward web support more so being that travel is going to get super expensive. Idaho diesel prices are heading up fast and talks of 5, 6 or 7 dollar a gallon diesel prices coming soon. Now I'm keeping an open mind of what and where I'm even doing for employment being I want to keep my expenses low.- Bosch Alternator
I started out with a Bosch alternator from factory. Now after the first failure back at around 200k miles I replaced with ND alternators either alternator will hold up as long as the W-T ground wire mod is done. Without the W-T either Bosch or ND alternator will fail and typically take either the brushes, slip rings and/or the diodes out. After that I've had good luck with both ND and Bosch alternators.- How long to change injectors?
Tuning and driving style make impacts that may or may not improve MPG numbers. Like the combo I done with the Quadzilla tune and 150 HP injectors popped at 320 bar this made 28.04 MPG. Like the last time was 75 HP injectors and Edge Comp tuner but there was limitations. Still made 27.2 MPG. Secret is keeping the Engine load and Engine load low as possible. Anything that creates heat is where the power is lost at only because any thing creating heat is steal some of the energy to create said heat. - Painting Valve Cover
