Biofuels emit 400 percent more CO2 than regular fuels
Kind of hard to do when the US don't have any industry left... It all been moved to foreign countries... Give you an idea... Here is a large normal city like Denver Co. Now here is Detroit, MI... Now you can clearly see that Detriot is got a lot of vacant ground and all the big 3 auto builder are gone for the most part. I got a old high school friend living with his grandmother in Detroit and he calls me off and on and his comments is jobs are hard to find and pay very little...
firewood splitting...
No pottery kiln... That is only half of my winter firewood... I burn right around 7-9 cords a season. The last pic of the wood shed that holds 12 cords to the last post or 15 cords at the roofs edge... Last winter I used 8 cords... The ATV has my 20 ton splitter hooked the the back so I got to do is back it into place and get busy... The pile now is a total of about 8 hours of work and 1 1/2 tanks of fuel on the splitter... Doing the math on the winter heating... It cost me about $35-40 a cord to get so say $40 times 8 equals $320 bucks for the whole winter... One year shortly after my Dad's death I took a short cut and used a electric heater in the guest house and it was right around $200 a month in electric to heat. (Now figure a main house at double square footage and nightly low at 0*F for a low) So wood is much cheaper in the long run... Neighbor is heating with propane at $2.49 and hes got to reload the tank twice a winter... Ekkk! Central what???
Red Dye Fuel
Hmmm... Here in Idaho it like $1,000 dollar per gallon fine... So for a 35 gallon tank it would be at least $35,000 fine... Ugh!
Well here is a few pics of the firewood pile I've been working on splitting... My somewhat empty wood shed... Each row is a cord...
Switched Grid Heater
I'll test that out tomorrow I got a A/C job to do so when I run out I'll test both ways...
Start Up Issue
Few things to look at... [*]Battery connections [*]Starter contacts [*]Solenoid fuse [*]Solenoid relay [*]Solenoid wiring [*]Starter brushes Here is a handy way to test for wiring issues... http://mopar.mopar1973man.com/cummins/general/voltage-drop/voltage-drop.htm
Fender Repair
Not bad... We need to see pics of this wonder work of yours...
Yes... P0380 or P0382... It can detect a open circuit... P0380 Intake Air Heater Relay #1 Control Circuit Problem detected in #1 air heater solenoid/relay circuit (not heater element) P0382 Intake Air Heater Relay #2 Control Circuit Problem detected in #2 air heater solenoid/relay circuit (not heater element) That why I disconnect the positive lead going to the grid heater supply...
Problem is some has to create a better battery... Or... Produce a better fuel with more BTU's... So far everything anyone has done as far a alternate fuels (biofuels) has always produce a fuel that is 10-20% less BTU value requires more fuel to do the same distance or work. Then on top of it the price for these "Biofuels" happen to be higher than standard petroluem fuels... (Double loss)... There is lot of option out there for AC power but as for vehicle power well there isn't much options...
Not a truck or Diesel Post
Interesting... I might actually be a good idea for losing weight too.. (Empty calories)
Ummm... ISX how about dispose of the lead acid batteries? How about the replace price of them? The batteries cost nearly as much as the car does... I figure the biofuel craze will come to close now...
Puppy Pix
Yeap they go from tiny cute furniture eating monster to big oversize lazy dogs...
Red Dye Fuel
Oh gawd... I shut my mouth now...
How the P7100 works
Nice find! You should add that to the download library for other to find!
Red Dye Fuel
Till you get to Idaho and the pull your fuel filter and the filter is stained red...
Final Follow up on new lift pump with my rebuilt vp44
I typically like to see above 14 at a idle... But 10 PSI is the minimum limit for WOT and is not very safe to be that low... Stay in the green...
Gauges
As you can see I tossed it right back... Actually mine get rather dusty really quick on the dash from all the dirt roads and firewood hauling... Just to make you feel better next time my truck is dirty I get you a pic of it...
cold running issue
Black smoke is sign of lack of boost so is the wastegate stucking open? Exhaust leak in the manifold? Hmmm... IAT sensor? You might think off changing it out or if you can get ahold of a live data tool and see if it shows a normal temp of some sort...
Paypal !
Well you all know I got the paypal here for the site and it takes care of the server cost, etc... I'm unverified at this time but don't plan on using the paypal for much than a few server bills...
Oil
Hmmm... I buy 6-9 gallons of engine oil a year... and 3 gallons of 2 cycle oil every 6 months... Not too bad...
Red Dye Fuel
Don't whine... Please... I'm the highest price state in the union... $3.25 to $3.35 a gallon...
Gauges
- There is nothing girly about my beast... I like the overhead Idea too it is way cool to have them up high...
Puppy Pix
There adorable... Cute as hell...
New Miles & Mileage Records
Wow now you got something to crow about there congrads on the 23.3 MPG I know you've been trying hard and long to get it up there...
grid heater by i.s.x.
I must be the only odd duck in the group that ditches the grid heater for the summer months... Typically I do hook them back up in the fall of the year when morning temps are as low as 40*F then I hook them up.. But while back I was doing alot of short trips and sometimes now I still do... I'm also got my stock batteries as well and they are getting weaker... Sitting at 12.5 V after sitting all night.. I might sqeak 9 years out of them but I think this winter is going to be the end of them... --- Update to the previous post... Ummm... Feeling so guilty about this I hooked mine back up..
