  1. Mopar1973Man replied to JOHNFAK's topic in Ford
    Here is a small beach down on the Salmon River... But I need a few better pics...:banghead:
  2. Mopar1973Man replied to JOHNFAK's topic in Ford
    Ummmm...
  3. Mopar1973Man replied to JOHNFAK's topic in Ford
    I got buried in dry sand out here in Idaho... Never got crazy enough to try wet sand.
  4. Mopar1973Man replied to JOHNFAK's topic in Ford
    Good Gawd... What the hell what was he thinking...
  5. Myself if the truck is at home I'll plug in when its parked in the garage. I use the heat in the shop to keep it from freezing so the heat not wasted being parked outside.
  6. Get a chunk of 1/8 Air Line (Polyon) from NAPA for cheap... It rated to 200 PSI typically extremely flexible... I bought 10 feet and 2 ferules for $6 bucks...
  7. You don't want to look at my truck then.. Mechanical gauge direct connect to the fuel line... No isolator... But I do use a needle valve and its barely cracked open so if it did leak it would only drip... So far nearly 7 years no problems... But I did find a awesome secret... Use 1/8 air line from NAPA (Polyon) its really cheap but its oil and fuel capable. It extremely flexible and won't break. It rated for like 200 PSI so I doubt a mere 15-20 PSI fuel system will break it...
  8. Awww... Ok! I was curious to what your doing...
  9. Good one ISX... That is a awesome Vid on how that works!
  10. Sure that what its all about... Sharing information and trying to figure out the problems... Even myself I got to admit I'm not always the bright canyon in the box but I give it a honest try and if I fail or get it wrong well I learn from the experience... So like everyone here they share there experience with everyone... As you also notice there is very little talk or chatter about racing, dyno, tractor pulls, etc... I'm here to try and help the "Common Joe" or "Common Jane" that needs there truck for work and paly...
  11. What the heck are you trying to do?
  12. Yeah but you know if the cheater box is used then the problem is gone... So if the VP44 and ECM are new then that leaves the wiring in between that is faulty...
  13. Hmmm... I would double check the connector on the ECM and see if there is moisture in the socket or the pin are corroded... From what I'm seeing in the error codes I think there is some truth to it but I think its a loose or poor connection...
  14. Really simple... first lets read the TSB... http://mopar.mopar1973man.com/cummins/2ndgen24v/high-idle/tsb18-019-01.htm So I got smart and figure out how to control the high idle by using toggle switches and a few resistors to fool the ECM into believing the engine is colder than it actual is causing the high idle or the 3 cylinder high idle to start. But there is the rest of the article... http://mopar.mopar1973man.com/cummins/2ndgen24v/high-idle/high-idle.htm
  15. I hate to say it but found another flaw... I've been studying the connections and there is a crossing of the IAT sensor with the ECM leads... On your 3 cylinder relay you pulling your signal from the IAT instead of the ECM... So it would but IAT + the resistor 56K ohm...
  16. This design has a flaw... What happens when you flip both 3 cylinder and high idle both?
  17. List out the codes it might give a clue...
  18. I'm leaning towards starter contacts...
  19. Welcome to the backroom... See your hard work and system bugs tend to help you get the status huh? Actually you earned the right fair and square but here is several bugs I'm still fighting with about promotion and demotion of ranks. So if you get knocked down for some reason let me know I'll doubt check the software again... :banghead: Great... Information is always a good thing to share with others that need to keep there trucks going. As you learning and finding out Mopar1973Man.Com is mostly of older folks and Common Joe types there is very little racing crowd here... So all the tidbit or secrets are always welcomed...
  20. Yes you can... I remember long long time ago over at Cummins Forum I remember a guy that tore his center console lid and desided to redo it himself well it turned out awesome... But there was a trick about taking it apart... Which today I don't know... But there is a way of doing it...
  21. Could you list places to get some of these tools like the torque multiplier and pullers and such?
  22. Yeah but I look at one thing... 5 Speed 0.75:1 ratio 6 Speed 0.73:1 Ratio So even if it had a 7th gear it would most likely be around the same...
  23. Yeah but I bet the air temp will be close to the outside air temp by the time you get to the driver side of the IC. Then it will also be based of speed too... So if you stuck in traffic crawling won't matter much... --- Update to the previous post... There is a mod called the stinky slinky where you drill a 3 or 4 inch hole in the cowling and route a short piece of drier tubing or sewer hose from the stock box to the cowling..
  24. Whats your fuel pressure while its cranking? If it below 7 PSI you got air in the system or a lift pump problem...
