Large quantitys of black with a little white smoke mixed in
Being you don't have a box or programmer I'm going to say it going to be maybe a IAT sensor or MAP sensor problem... You might check for error codes and report back with any codes you get... The fact is your in stock form for the most part (as far I can tell from your sig). So that means you got something reporting a excessively cold signal.
OBD II Error Codes list for 6.7L Dodge Cummins
Here you go gang... I finally got a list of error codes put together for you... http://forum.mopar1973man.com/downloads.php?do=file&id=124 This should cover 2007 and up Dodge Cummins for error codes.
Turtle! Turtle!
Holy cow.. Talk about getting your grease in one shot... Wow!
Another Idea
Hmmm... There has always been a host of different adhesives out there that really do stuck to whatever... Nice to see you found one to add to the list of weird things...
Tick,Tick,Tick
I could go on and on myself of all the problem I see with just my local government... But the whole problem comes back to 2 simple words that explain the whole problem... GREED and MONEY.
cheap air compressors
Hmmm... I've always thought about the airbag idea but don't do enough hauling to worry about doing airbags... I'm real curious though of the air bag setup...
Milestone
It is...
Plug in block heater
Like here not to long from now I'll be firing up a block heater at night... Like this morning low is 50*F and by mid October I know it will be close to 32*F at night... My winter fronts will be installed by then too... Strange to still snow in the Seven Devils Mountain range at this time of the season...
my long term project
Wow there is a classic car... Nice mod with the updated fuel injected engine. I hope you keep the pulsing turn signal tail lights (if that was the year?) That was killer to see on the road... I thought of one day doing a mod like that to my old 1973 Dodge Charger sitting in the yard... Something a bit more up to date and ditch the old carburated fuel system...
Out on the mountain..
What??? I've only gone out twice and got 4 cords of wood... Try again W&F...
Strange no-start problem with '98.5 QCSB... Need help.
Ummm... Sorry... I can't help you I haven't seen a car alarm in YEARS! Where I live in Idaho no one locks there doors... The truck is normally parked on the city streets with the windows rolled down and the key in the ignition... The local kids here can spot a tourist a mile away by listen for the horn chirp... Then have fun setting off car alarms...
Well yesterday I hauled out and escaped the house for a short time... Even left the Cummins at home and took the 96 Dodge and the ATV and went for a ride.
Actually it is possible but most times out of ten the heater continues to operated even while shorted to the coolant but you know that because you feel a tingle when you touch the engine.
Yeap... That is the only way to disable the truck... But like Koyote said above its typically hooked up to shutdown the ECM or simiular...
No wayyyyyy !!!!
Here is a small beach down on the Salmon River... But I need a few better pics...:banghead:
- No wayyyyyy !!!!
No wayyyyyy !!!!
I got buried in dry sand out here in Idaho... Never got crazy enough to try wet sand.
No wayyyyyy !!!!
Good Gawd... What the hell what was he thinking...
Myself if the truck is at home I'll plug in when its parked in the garage. I use the heat in the shop to keep it from freezing so the heat not wasted being parked outside.
Boost gauge tubing
Get a chunk of 1/8 Air Line (Polyon) from NAPA for cheap... It rated to 200 PSI typically extremely flexible... I bought 10 feet and 2 ferules for $6 bucks...
fuel pressure
You don't want to look at my truck then.. Mechanical gauge direct connect to the fuel line... No isolator... But I do use a needle valve and its barely cracked open so if it did leak it would only drip... So far nearly 7 years no problems... But I did find a awesome secret... Use 1/8 air line from NAPA (Polyon) its really cheap but its oil and fuel capable. It extremely flexible and won't break. It rated for like 200 PSI so I doubt a mere 15-20 PSI fuel system will break it...
Awww... Ok! I was curious to what your doing...
basic relay wiring
Good one ISX... That is a awesome Vid on how that works!
Thanks
Sure that what its all about... Sharing information and trying to figure out the problems... Even myself I got to admit I'm not always the bright canyon in the box but I give it a honest try and if I fail or get it wrong well I learn from the experience... So like everyone here they share there experience with everyone... As you also notice there is very little talk or chatter about racing, dyno, tractor pulls, etc... I'm here to try and help the "Common Joe" or "Common Jane" that needs there truck for work and paly...
What the heck are you trying to do?
