Global Warming Fraud
Well if its global climate change we need some more greenhouse gasses here in Idaho! In the 20 years I've live here this is some of the coldest winter I've ever been through so far... :eek:
How Many Miles Without Alternator?
Found another good pic that shows it all...http://forum.mopar1973man.com/picture.php?albumid=15&pictureid=78
I know it late but here is the PDC... http://forum.mopar1973man.com/picture.php?albumid=15&pictureid=66
How much power steering fluid??
With a dry system I would bet around 2 quarts tops. But the steering box is loaded with fluid, so is the hydro-booster so I would flush the system out with at least a quart with the old pump in before hooking up the new pump. This way the system is clean and your not pumping dirt into your new fresh pump.
Injector upgrade
Well first off I would like to thank Cajflynn for the wonderful donation of his used RV275 injectors, which happen to show up in todays mail. i'll get some pics up soon... In the mean time I'm going to gather up a few supplies for installing them. Does anyone know where I can get copper shims and fresh O-rings for these??? Holy Cow!!! :eek: I looked up the numbers on the injector and... 0432193635 / 4183 Comes back as either a RV275 or a 300 HP injector...:confused: Still much better than stock! :thumbsup: http://forum.mopar1973man.com/attachment.php?attachmentid=60&stc=1&d=1260397958 http://forum.mopar1973man.com/attachment.php?attachmentid=61&stc=1&d=1260397958 http://forum.mopar1973man.com/attachment.php?attachmentid=62&stc=1&d=1260397958
Ouch... That hurt... :eek:
HELP!!! No power and poor fuel milage
When was the last time you changed your power steering fluid? PS fluid should be flush and changed every 30K miles. If the fluid is dark and nasty then yes it needs to be changed.
Well its a matter of chasing down all the plastics tube and checking for cracks, leaks, bad rubber, etc... Basically either the vacuum pump works or it don't but if the vacuum pump is bad its either leaking engine oil or the power steer and brakes are out... :eek:
Cold Weather Warning!
Well by Saturday we will been in the warmer temps again heading for 40*f weather with snow and rain!
Yeah I curious too...:agree:
Phantom Fuel Leak
Naw... I just fired up the truck cracked the line so it sprayed a bit then closed it down tight...
BHAF filters...
By bad... I was busy on the phone and helping other and lost my train of thought... Matter of fact look at this know I think the train jump the track. :rolleyes2:
A Dirty Word... Oil
Your still going eh? :eek:
How much blow by are you getting from the crancase vent? This is a clue of if you got a vacuum leak. When you do have a vacuum leak the vacuum pump becomes a air compressor creates excessive by blow. :eek:
Not really needed... Just run a winter front you should be good...:confused:
From Alaska-Need V44 Pump
Yeap he's a vendor here...:thumbsup: http://forum.mopar1973man.com/member.php?u=32
What I'm finding is optimal intake temp should be around 90*F to 110*F... I've got a winter front on but with -10*F weather I barely see 50*F in the intake and it gettin way too cold and MPG's are suffering... :shocked:
BHAF filters...
The chip market is a mixed bag really... There is a lot of claims but hard to prove any of them... But like myself using the Edge Comp and running it wide open and keeping the boost low and the pyro low I'm turning 21-22 avg MPG and 25 max MPG. Like mild 1/8" inch aluminum... Like a old road sign would work awesome... It's the advanced timing...
A Dirty Word... Oil
Well since I bought my truck new I've been running Exxon XD-3 15w-40 for nearly 100K miles and then switched to Rotella for a round and OMG! I now know why the nickname RoSmella... Then Start hunting for Chevron Delo 15w-40 Which my buddy has been using in his truck for over 600K miles and still going... Buty even with all petroluem based products in my truck I reach 25 MPG for a MAX and aveage 21-22 MPG..
Comes back to the basics... You need to find out what the error codes are... and what you fuel pressure is like... http://mopar.mopar1973man.com/cummins/2ndgen24v/fuel-pressure/fuel-pressure.htm http://mopar.mopar1973man.com/cummins/2ndgen24v/obd2-error-codes/obd2-error-codes.htm
BHAF filters...
I got a template for the a BHAF heatshield... Go to the BHAF link... With a BHAF it will last longer up to 5 years.... The air flow is increased because of it size.
12V Faq's comments...
It might be a wise idea to take this a step farther and teach about the independent part and how they function too. Like the one that comes to mind that is commonly talked about is injectors (not buy and selling) but the actual mechanical function of a injector and how it does it job...
your just like me I hate just excepting the typical forum information unless it backed up with a few tidbit of information. That basically how the static web pages got built I kept compiling the information as the tidbits came to me...
Wow! ISX... So far you got my attention that really good and killer right write for the 12V's... I know taz had looked at it and been reading it a bunch. Keep going... I might have to steal this and add it to the static page write ups. Then I might to cut and paste chunks of this for the 24V side too...
30w Non Detergent vs. 2 cycle oil
Most all 2 cycle oil today is ashless... TCW3... Hmmm... The only thing to consider is looking at the pour point of snowmobile 2 cycle oil over pour point of engine oil. I think ther pour point of snow mobile oil is much lower and help protect against gelling. Fuel filters for 2nd Gen 24V are rated for 12K to 15K miles (every other oil change). As for my AirDog 150 I'm going 30K miles between filters and there not stock 10 micron filters they are 2 micron fleetguards... Now I do have the stock filter housing and element and so far the stock filter is still clean!
