Coolant temp
We will see..
1999 24 valve high idle and bucking at highway speeds
Ummm. That's too high period. ECM possibly has fueling table issues. I was think lower like 850 to 875. 1100 RPM is like the 6 cylinder high idle but typically brake pedal or touching throttle cancels. It should not be 1100 rpm at any point after touching the throttle. I've got an guy in Texas I've been working with he's got 3 trucks with the same issue. I'll post anything I learn on this too.
block heater malfunctioning
Most napa stores have them in stock.
FASS Sump Long Term Reliably
Problem is when the seal gives up will you be able to get a new seal for the sump. There has been a few that did sumps then had leaks then could not get new seals. Then the hunt is on for a replacement fuel tank. Which one member told me was a tough deal and expensive.
How old are the injectors? If the injectors are over 100k miles for sure they are shot. As injectors wear the pop pressure falls. The engine load will reach 0 and the ECM will not be able to defuel enough to get the idle down to 800 RPM. If the injectors are questionable I would have them sent for testing.
Coolant temp
Still doubt that being the sensor is INSIDE the oil. The sensor the probe tip is nearly 3/4 long inside the oil. The oil is MOVING past the sensor and oil filter into the turbo. Now I could see you point like in transmission application where people put the sensor in the accumulator piston and the fluid is not flowing. This is in a flowing oil galley and the main oil feed to the turbo. So I still doubt your comments being the fluid is moving into and out of the oil filter.
Coolant temp
We can change sensor but it not going to change the temp. I can measure the temp with my IR gun and still be the same. I cant make it hotter being the oil temp is still the oil temp.
Timbos APPS is all based on angle. That simple there is no electronics. As you can see there is just the contact strip. Voltage is only use to see if you cross the boundary from idle to throttling and then you unscrewing the stop pin till you come back to rest in the idle zone.
Came across the fourm!
Welcome to the family.
Coolant temp
Sorry. I don't know what to say. I've check it many times and it correct. Remember 24V are NOT CR engines. Might hold true for your old truck... Umm the oil is flowing through that port. That is true oil temp from the oil cooler. If not my turbo would sure hate life if the oil isn't moving.
Coolant temp
250 miles daily trips. This is my standard from New Meadows to Ontario, OR runs and back home. Photo is dated 12/31/2019 (Tuesday)
Coolant temp
It does. I can crank up the timing to make it hotter but... MPG drops out badly.. 15 to 17 MPG. Outside temps in the 10 to 20*F up here. Thermostat is closed and holding barely 192 to 195*F. The lower coolant hose is COLD to the touch. More timing the hotter the oil temp. More retard the cooler the oil tremp. This photo was a older tune my recent tune is right at 20* at 2k RPM. Remember Trans is the engine oil.
New Headlights for Big Blue
Switch back bulbs give off more light than a amber bulb. Like mine cast light for almost 200 feet very bright. Very attention grabbing with the white markers then when your turn signal used its even wicked bright amber flashing bulb. Gives that modern look of the halo driving light or as some are call it daytime driving lights. During daylight hours I typically just run my marker lights.
NAPA part number is listed in both of my articles on LED marker lights. https://www.napaonline.com/en/p/NF_EP27L
Coolant temp
Efficiency... Less heat lost the more power to the ground. All about the Quadzilla timing. Oil cooler port on the oil filter housing. Extra temp sender comes with the Quad which is labeled Trans Temp but I know it Engine oil temp. I'm running about 20* at 2k RPMs.
Boost reading 48psi at idle + no power level adjustment
Actually this particular should trip P0236 boost too high too long.
There is... Remove the box clear any codes. This test drive for 10 miles or so. If and codes are set then the map sensor is bad. If not the boost cooler is bad. Another way is to replace the map sensor and see if there is change. But map sensors are spendy.
He's going to love them...
Coolant temp
180*F alternate cooler thermostat. I tried it as a test its fine in the summer time but doesn't work very well in the winter time gets too cool. 190*F is the stock temp. You can install 6.7L 200*F thermostat and it will fit just fine and produce serious vent temperatures in the cab. It will strip the ice from a windshield rather quickly.
Moisture in headlights
Morimoto HID's... I cast light at least 40 to 50 feet in either ditch along a 2 lane highway. On hi beam I can cast light as tall as 50 feet.
I clear 1,200 miles a week. Yup I spend a good part of my morning in the dark. Like I'll be leaving here at 7:15am and heading south. I wont see good light till about council, ID. Then on my way home typically its just getting dark about the time I'm heading past Council, ID north. LEDs do work there is several seal beam solutions in LEDs. It's the dumb Ford guys that retro fit the LEDs and assume the pattern is still good without adjusting. Typically they end up with the cab full lit up from my Morimoto D2S HIDs.
2 stroke info.
Take some summer biodiesel and then stuff it in the freezer over night see if it turns solid. Then add the product to the frozen fuel then return to the freezer and see if it does the job.
Problem is the stock housing tend to be poor pattern of light and requires a full readjustment with fresh LEDs they can be made to to work as a few here have managed to do. It is not just change bulbs and roll... You MUST readjust both headlights after the change to LEDs prevent blinding people.
All I can say is it will still suck. I've got these in my 1996 Dodge now with SilverStar bulbs and very poor lighting. I'm going to be playing with LED bulbs next to see if I can improve this. Still in all a Silverstar bulb is roughly 860 lumens and the LED's are 3,000 lumens. Just for fun... PIAA LED driving lights... These are brighter than my Morimoto D2S lights. http://www.piaa.com/store/p/187-LP530-3-5-LED-Driving-Light-Kit.aspx
I'm so glad to be back to driving my Cummins with my Morimoto D2S lens. Comparing now between 1996 with Silverstar Halogens with crystal clear lens and the Morimoto D2S is huge difference. Morimoto D2S cast light much wider and farther down the road. The SilverStar halogens are scattered and very dim even on hi beam. So funny people will spend thousands for turbos, injectors, injection pumps. But when it comes to lighting. OMG!!! spend some serious money on lighting that just too expensive for lighting. Yup, it's true there is $1,000.00 worth of light on my 2002 Cummins. I'm still learning you can spend the 70 bucks for new headlights and fancy Silverstar bulbs. Lighting still sucks and weak at best. You can spend the money on sport lights with four SilverStar bulbs and relay kits and still suck for lighting. There is nothing in the halogen playground that will even come close to a HID lighting period. My 1996 is going to get a change up... Driving at night with that truck is dangerous.
