  1. You can even custom pop pressures too. In stead of the stock 305 or 310 bar I jumped to 320 bar for cleaner burning, slightly less fuel in the start but going to last over 100k miles.
  2. Close... 190 amp for both elements, 95 amps for one element. That alternator fuse can now be used for other accessories. Personally that fuse is just to big for anything.
  3. Too many people use sealant like silicone and over torque the gasket. This ends up distorting the metal of the pan, the gasket, and still have a leak you can't rid of. Rubber gaskets will typically do very well but the torque is extremely light like mere inch pounds 8 to 12 range roughly. I've got use to just using the ratchet head and not using the handle to tighten pan bolts. I've done enough transmissions lately. (Dodge and Chevy's)
  4. Yeah the "MySQL fulltext" search has been known for absolutely poor results. This is why the Elasticsearch was added it responds more like Google does. Yes there was issues for the What New function but I'll dive in and check and see if that has been fixed in the last few software updates. Manufacture of the software use to display what bugs they were working on and now is all closed to the public so you never know if the issue is fixed or not till you just try again.
  5. I'm moving forward. Even with crappy days like yesterday I just chalk it up to poor day. I ran to town to finish out a A/C job but being so cold outside I was not able to get the new compressor to fire up and have to force it to start to finish the charging with freon. I'm not sure if its going to fire up in the spring we will see. Then go home grab the Cummins drive down to the shop and rack it on the two post. Spin around and smack my head on the passenger side front lift arm. OUCH! That hurt big time enough to make me bleed. Thankfully, I call Eileen and got her to call me back on Facebook and look at my forehead. She gathered up supplies and came down to the shop and cleaned me up and doctored my wound. Still pulled the transmission in just about 3 hours, with about 30 minute slowdown with the blood running down my nose. Even with all that I managed to have all all the driveline pulled and start loosen up the transfer case before Eileen got there. As for the clutch I'll pull it down and check it all over closely. So as for this morning I'm up super early at 4:30am sad to say. Rough night of sleep for me. Too much on my mind. I've got the transmission loaded up and ready for Boise. During that trip I've got to stop by Weiser and pay the bill for Mom. I'm starting to adjust to my new life. Enjoying the thought of not having to drive long distances. Waiting to see a few months go back and re-math out the month budget for the house. Like I've shut down the heat pump completely. Been burning firewood more, don't have a ton of light on like Mom use to, doing laundry less often, everything should be less expensive than the last 4 years. Nice to get up and spend time on the forum and been working on the server a little bit to improve things and update softwares. Mornings are much more relaxed and less stressful being I can just stay home if the weather is bad. I'm no longer forced to drive in poor weather. Fuel in the trucks last much longer, and repairs should be less being the average is about 10 miles a day now at the best. Weird in between part of the season here, cold in the mornings and warming up during the day getting closer to 50's very soon. Snow is mostly gone here. I'm looking forward to traveling again, camping, being outdoors getting firewood. I'm working on gaining back my weekends and holidays so I can rest too now. Been playing catch up most of the week.
  6. which might be fixed by now... year later practically...
  7. Yup. Just like my HX35/40 Hybrid (60/60/12) is the same as a HE351 (60/60/9). Well not exactly. Comparing HX35W (54/60/12) to my hybrid. Small changes but better flow. Common upgrade is (62/68/12) turbo most upgrade too.
  8. There was a result problem with the first go about it. It been missing for nearly a year now and I should revisit the software and fire it back up with updates. https://www.elastic.co/ That is the software we were using while back.
  9. I was using a OBDLink LX dongle but I killed it with a a bad flash update. I will be buying two OBDLink MX series dongles for one in the shop and the other in my truck. https://www.obdlink.com/
  10. Kind of rough to invite friends over to split up mom clothing but still in all there is nothing I could do with it. We have to clear out all the stuff from the closets. One at a time and slowly, donate, give away, etc. before anything get pitched in the trash. As for today I've got a job in town to do or finish up with A/C recharge and then come back home and grab the Cummins and take it down to the two post. I'll get to remove my transmission again and ship it down to Weller to have 2nd Gear syncro replaced. Get this all bundled up and get the the check book ready to pay for cremation of Mom. Then on Tuesday I can just go down Weiser, ID and Boise, ID and kill to bird with one stone. Really don't want to drive that road anymore.
  11. Yeah I was looking a black folder on my bed. It was glamor shot of mom while back. BOOM! It hits like a bomb. Lost myself to the memory of mom back then. That is really tough.
  12. Agreed the P1688 is the dead code for the PSG on top.
  13. We've pulled out the search engine function so we are back to basic fulltext search from the MySQL server. I could attempt to see if there is an update or fix to the previous search engine and try again.
  14. Ok... I'm all ears. Canyon gets rather sparse heading south of me. Milepost?
  15. I would just call Quadzilla and send the unit in for testing.
  16. As for yesterday it was nice to just be back at normal work. I had a busy shop for part the day. I went into town first installed the A/C compressor in a Dodge Durango, I've got to first with the freon yet. Ran into @Taz in Riggins, ID. Had a interesting conversation. There is a job opportunity that I going to look into. It a local job and pays quite well... That is far as I'm going to say at this time on this. I was awesome catching up with my best friend after 7 months. Made some plans for going camping and riding ATVs towards spring time. I had to get moving on for the day and headed back to my shop. Finished up the Chevy with an salvage transmission. Needless to say fired it up and found the rear of the transmission housing is cracked. This truck was shoved out the door. Then started the W-T ground wire mod on the Landlord's Cummins. Shop was hopping for me. Then after all this I help Russ tear down a Chevy pickup pulled the truck apart and then pull the engine and transmission in one piece. WeeHaw... My first Sunday to sit around the house and go nowhere. Actually get to just be at home for once. Eileen just took off for the store for fixin' for lunch today. One of her daughters (Jessica) is coming out today to see if there is any of Mom's clothes she would want. Then right around noon I should see @Taz show up and hang out for a bit. This will be the first gathering we have had at this house in a long time. I'm enjoying my life of getting back to work and coming home. Strange to see the fuel last a lot longer and not have the huge fuel bill every month. Getting nice not having to get up early and driving in the dark. Life is getting simpler but also having to learn to live for "me" now, well to be correct live for "us" Eileen and myself. Eileen has been huge help in just tending to the house, sorting stuff, helping setup our stuff, etc. I's been a huge task and she has done quite a bit and we have so much more to do. She is totally awesome woman. Every day we mesh together in a task and can knock out things left and right. For me as soon as we can get thing sorted out a bit I know we plan on making a trip south to Susanville, CA to see Eileen's mother. Then a few other stops to see grandparents. Kind of healing process with me to just break away for a time. I find the more time I'm alone the tougher it is for me to keep form thinking of Mom. As long as I can stay busy working with other like yesterday I don't even think of Mom. Monday should be fun I'm planning on hauling the Cummins down to the shop and use the two post to pull my transmission and get it repaired again. While its there I'll replace all the brake cables on the underside. I should grab a few cans of Rustoleum and cover up some of the rust on the frame.
  17. Quadzilla and the 150 HP Injectors (7 x 0.010) @ 320 bar is bit smokey clean without a tuner. With the Quadzilla and my tunes I can roll completely smoke free on Level 3, but haze to light smoke with full wire tap, exhaust and tires.
  18. Thanks Dave... that means a lot to me. Yeah I have different triggers and deal with the heartache and loss. The only thing I'm happy with is mom is no longer suffering.
  19. Engine load is at 0% and Idle speed is too high Injectors are shot. TP% should show ZERO at true idle because Idle validation switch in the APPS should flipped over and trigger the idle software. This typically displays ZERO% for TPS position.
  20. Well on Thursday I made the trip back down to Weiser, ID to start the process of the death certificate and the cremation of Mom remains. This went smoothly till I asked to say my goodbye to Mom once again. Yeah I lost it and know she was with the Good Lord and no longer suffering. After getting done there I told Eileen lets go over to the Weiser Famer's Cafe and get breakfast. This was my old breakfast spot but know the food is good. Went in as usual and the I jumped up to catch the manager of the store. Talking to her and then Eileen steps around the corner to tell me my truck had rolled off. I go outside and look sure enough it rolled out if its parking spot and collided with a 4th Gen Dodge right at the flat bed. The 4th gen was fine with a few scratches in the flatbed rail. My truck on the other hand hit twice. Once it hit just above the bumper tweaked the passenger light light, corner of the bed and the tailgate. Then hit a second time and came to rest on the bumper which is also bent too pretty good. I look down and the brake cable separated are the clip of the middle cable under the cab. As I unlock the truck and look down the hydro-booster at some point has been pissing power steering fluid on the floor mat. WTH? Geez! Now things get a bit crazy... I called about the body damage on my truck to the insurance company. The problem I'm faced with is Mom and Dad both have there names on the title of my truck. So the insurance company would send the check to my Mom. So now I need to change the title of my truck to my name. Problem Power of Attorney only works with the person living. Now I got to complete the death certificate and file other paperwork to change the title of my truck. Then I can file my insurance claim which I've got full coverage on my truck. Yup... Just doesn't get any easier. Instead of doing the next step which is why I took the truck I was going to continue to Nampa, ID and pull more of Eileen's stuff from storage. Eileen popped up there is just too many things says its just time to go home. We've already had a long week leaving on Monday evening and stayed till Wednesday afternoon with medical appointments. Came home and I went to work on Friday. Trying to finish my Chevy transmission project. All done but the starter is bad and Russ has got one some where on the property with all his junk and spare parts. I've got a A/C compressor I picked pu to install for today. I'm right now aiming for a normal week of being at home. Get up go to work and come home. I'm so glad to not have to make that long drive for dialysis anymore. Now I've got to fix all the damage to my truck and repair the transmission which is under warranty still. I'll get things sorted out and caught up. As for me I'm still doing good. Mentally I have troubles keeping Mom out of my thoughts but that what happens when you care for someone so long. The other thing I keep hearing is all the comments from people of how well I took care of my Mother. Doctors, friends, just people passing in restaurants. Everyone has alway mention that I've done a awesome job of tending to her dialysis needs and medical requirements. I don't regret letting go. I've managed to save her life 3 different times. This time the good Lord said, "No more she is coming with me!". I accept that. Like yesterday after work I came home and cleaned up Mom's little prayer shine she has out the Kitchen Window. This hit hard and had me crying. Yeah I said my prayers asking for the Good Lord to tend to my Mother.
  21. 13 years and 250k miles roughly.
  22. Same here. But the only difference is I change fluids every 30k miles and used petroleum products. No issues as of yet at 409k miles and still rolling.
  23. I had 150k miles on my stock injectors. Had them tested 260 bar on average this is 30 bar below minimum. Then the engine load was zero and idled at 875 RPM. These where completely wasted and unusable even though it start runs smooth but MPG is down some and bit more smokey than normal. First set of RV275's I got had serious mileage on them and I took them apart and clean them and got bad to 290 bar barely. Then ran them for 9 months and they fell to 260 bar in a short time. Only lasted a year. Then I had +50 HP from Vulcan performance they were popped at 305 bar and only lasted 75k miles and was wasted below 280 bar. Then jumped +75 HP from DAP and these again where popped at 305 bar and only last barely 70k miles and started missing at warm idle. (another sign of failing injectors). Now I got smart had had a custom set of +150 HP made by DAP from my stock injector bodies. Had them raise the pop pressure to 320 bar. Now I'm still going after 75k miles engine load is still 6 to 7% at an idle, very clean injectors, and will last more than 100k miles for sure.
  24. Time to flush and refill. Only good for30k miles then the fluid starts to moan when cold. Just changing typically fixes the problem for me. Still using cheap SuperTech power steering fluid. Do it right with a full flush. just using a baster will only pull barely pint maybe? There is just about 2 quarts of fluid in the system. Like draining 1.5 gallon out of the crankcase and topping off again.
  25. Smarty does not have enough top end timing to handle 80 MPH. Caps out way to early. Quadzilla I've done it multiple times but I was running around 23* cruise timing at 2,500 RPMs turning out 21 MPG at 80 MPH. Smarty I think caps out at 19* and that is it. Remember Smarty has to play by the rules of the ECM and VP44. Quadzilla does not have to play by those rules completely. It highjacks the commands and send a priority message with the new timing and CAN Bus fuel message. So the problem is IAT drops below 80*F and the Smarty will have an extra +4* of timing where the Quadzilla doesn't use IAT temp. Again we don't have to play by all the rules just some...
