  1. Naw... But I was fretting rather well trying to figure out a solution to a nasty problem.
  2. That is being very honest. Got home from Saturday's run to dialysis with MoparMom and it was snowing on our way home. Not bad but glad to be home for the weekend. Got up Sunday morning sat around working the website thought I'll jump in the shower and get started today. About 5 minutes into my shower the water started backing up. Oh No! So I jump out and grab the plunger and give it couple good hits and the black soup came back up another not good sign. So I got dressed and started calling around and found a company that does drain cleaning. Come to find out he's in the southern part of the state doing another job. He said Monday at noon. Monday at 11am I'm calling to verify with him and find out he's stuck in a traffic accident and the highway is closed. So he shows up at 3pm and gets started. Well found out the big problem is the drain lines had over 54 years of grease build up. The main lines were necked down rather small. After 3 hours of power washing my drain lines they are clean now and flowing good water. $750 bill for this adventure. So between not being able to wash dishes, clothes, flush a toilet its been a rather crappy weekend.
  3. Time to test the alternator for excessive AC noise and then contact an ECM rebuilder to test and service your ECM and see what's going on.
  4. Still wrong. If you pull the fuse the circuit is OPEN. Now touch both red and black probes to the contacts in the fuse socket on DC Amp and you should see the current draw for just that circuit. When you see the circuit that is drawing heavy load you'll know what you have to deal with by looking at the power distribution layout in the articles. You should never bridge a fuse with any metal or wire. You opening the circuit to isolate the loads and measure that's all.
  5. You are going at this the wrong way. Systematically pull each fuse and measure the Amp Draw of each fuse socket. Now you know which circuit is drawing that heavy load and can isolate what is going on.
  6. Simple there is less than 0 PSI in the system. If you heading towards a vacuum the system is empty. Hook it up and open the lo pressure valve with the vacuum pump hooked up on the center yellow hose. The blue line is the lo pressure and the red line is hi pressure.
  7. Same type of kit I've got. Little 1/3 HP vacuum pump and manifold gauge set.
  8. @AH64ID Got any suggestions for this 3rd Gen owner?
  9. Thermostatic heater all embedded in the filter housing.
  10. IiRC 60*F. Non computer controlled.
  11. Mopar1973Man replied to BMC330's topic in Introductions
    I've been trying to make people feel at home like one big happy family. Newbies are exactly that new to the Cummins Diesel world it would rude to just tell them to "Go use the search". Do they even know what they are searching for? Do they even know what has failed? Most likely not. Everyone here attempts to the best of their ability to aid whoever is need assistance. If one person doesn't know they will refer you to another person that does know what to do.
  12. Quadzilla Adrenaline - Light Throttle Load Limit I've personally seen a lot of confusion in regards to proper setting of this value. The first thing is to find a piece of highway that is quiet with little traffic and with a speed limit of 65 MPH. Now find a piece of that highway that is flat as possible you can double check this with a GPS. Now that you have your test bed for at least a good mile. Make sure you mark your start and end of the highway so your testing is accurate. Now you want to reach highway speed of 65 MPH before you reach your test highway. Now set your cruise control to 65 MPH. As you cross over your test highway at your cruise speed take notice of the engine load percentage. Be aware that changes in timing setting will impact this setting. If your getting closer to your correct timing you'll notice your cruise load will continue to go down. If you are going too far retarded or advanced in timing you'll see the engine load rise you know that you are going the wrong direction. Proper setting of this value you should notice the vehicle reach a small grade or hill and the engine load will rise over your threshold and timing should fall and the boost should build rapidly. What is the correct number load percentage each vehicle and fuel system is different like my truck with +75HP (VCO 7 x 0.0085) injectors my 65 MPH cruise load is right about 23% I've got my load limit set for 25%. Stock injectors might have a much longer duration than my +75HP so your percentage will be higher. This why you need to do the highway measurement find your load limit percentage. As for testing speed I suggest anything between 55 and 65 MPH no higher or lower. Do not attempt to get get the Quadzilla to hold cruise timing beyond 70 MPH after this point it should flip-flop in and out and may just stay out of cruise timing. Like my truck even with my low drag I can reach cruise timing at 80 MPH but I can't hold it for long.
  13. Yes. I've got an article for that. No. The key is stamped with a number and so is the case of the pump. So you can order replacement keys if needed. There is other factor like worn injectors or worn injection pump that could produce the low MPG. The only problem is the only clue we've got right now is the P0216 code and possibly of a timing issue. Still highly suggest having the alternator tested too.
  14. Injection pump issues. I would collect on the warranty of that injection pump. Did a shop install the pump or did you install it? Was the key lined up before torquing the shaft nut? I've seen sloppy installs where people shear the key off or plain out crush it because it wasn't lined up. Possibly a ECM issue and alternator AC noise issue. I would suggest testing the alternator for excessive AC noise. Do you have any delays for the WAIT TO START light? Does it come on instantly with the key?
  15. No fix. This is normal because of the ECM flash. As ECT is cold temperature the oil pressure will show higher. Then when temperature goes up to operating temperature then it goes down again. But checking my actual oil pressure against the Gauge isn't to far off from actual really.
  16. Here is the LMC truck... http://www.lmctruck.com/icatalog/de/full.aspx?Page=45
  17. Took me a bit to remember where I started out with my plugs and stuff. Try these two places. Casper if you can shot a picture of the plugs and socket the guys there are typically pretty good about finding a mate for the photo. http://www.casperselectronics.com/cart/ https://www.mouser.com/
  18. Pump does run @JAG1 . If here jumps the relay socket. So this still points back to an ECM failure of the pump circuit. You could wire up a toggle switch for the temporary fix but I do not suggest that. to easy to forget to turn it on or leave it on and create issues. Not to mention safety issue of the fuel pump continuing to pump if you are in an accident. Like I said a toggle switch or wiring to the keyed side of the ignition switch is a temporary fix at best. We do have a ECM/PCM rebuilder list on the site so you can get your ECM repaired.
  19. Really? You are going to move forward to 4th Gen?
  20. Any error codes? Might give a clue as well to something that might not be plugged in fully?
  21. Mopar1973Man replied to BMC330's topic in Introductions
    Don't mind the two jokers here. It typical every acts like one big happy family here. So make sure to ask plenty of questions and there is no such thing as a dumb question here. Dave and Michael have been tagging each other for years. Being Dave is our Chick Fil A man building these stores and Michael happens to be in construction as well. So you can see good ol' family bantering back and forth...
  22. Boost and fuel pressure. The reason also is if i have to test either gauge I can hook a tee and second gauge for testing. Much easier than digging at the VP44 or the back of the head. Right there easy access.
  23. Sounds like there is ECM issue delivering power to the relay.
