  1. Well gang... I've touched 24.0 MPG on this last run back to Boise, Idaho. I do need to back down my timing more again the idle misfire is back again. I'm going to change up my timing curve on this performance tune some to see if I can resolve the misfire at idle.
  2. Returned back to Boise today made a cool even 24.0 MPGs...
  3. Again this follows my IAT optimal range. 100-140*F is the optimal temperature for the 24V engine.
  4. What I'm finding out is the steeper the fuel curve is the better the MPG will become. Timing isn't so much of the picture but the CANBus fuel curve is more important.
  5. Timing is more retard. Fuel map starts at 105% and exponential growth of 1.5% vs the economy tune that starts at 100% and exponential growth of 1.2%. So that being said I might try bumping the fuel map harder and heading for 1.6% which will make it more smokey. My 1.2% curve is smoke free. My 1.5% I can see like haze to small clouds.
  6. As far as I've seen between my two trucks once you've saved the first profile for each one it automatically picks up the profile the truck and uses it. I'll double check again and see if there is a bug or something changed. I'll be a few days before I can test this.
  7. Today I made a mistake and left my performance tune up and forgot to change before going home. It netted me 23.1 MPG when I hit the door tonight. No bad. Here is my data log from the OBDLink. This is my last log in the pile, 62.08 miles of logged MPG. OBDLink data logs and saves all the files to the tablet and I can pick and choose the files I want to look at. Also talked to Spencer about that and he'll see what he can do about adding that into the logging feature.
  8. Yes. Helps A bunch with the cold mornings. Funny I made the mistake of leavimy my Performance tune loaded and it's doing better MPGs than my economy tune.
  9. No need. The app will reconize the vehicle and rehook to its own profile. I've got my 96 and 02 Dodge.
  10. Live day of the sensors would be more helpful of want data the ECM is seeing. @dripley closed loop is when the ECM considers its warmed up and ready.
  11. Ok gang... Performance side what would be the best settings with my current setup? I want to play a little now the snow and ice are gone for most part.
  12. I've been using Dextron ATF in my transfer case for years now. No issues to date.
  13. Might be true I was trying to remember the number the last time I rebuilt a unit. My last one was on Ford truck and I've might be quote that number.
  14. Funny this thread is going... I got another member that just called me just now and had to replace the pressure hose from the hydro booster to the steering box. He wasn't sure if the line was tight so he sends me a picture of the line. The first thing I pick up on is the amount of dirt in the photo. I made the comment to him that he should of power washed the unit off before starting. Now he calls me back tell me the hydro booster and brakes are fine but the steering is extremely stiff. What has happened he's got dirt in the power value of the steering box and the fluid can do its job to assist in steering so it stiff. So induction of dirt and grit in the system is a problem being there is no filter. As for slop in the boxes just because a chain store sells a box I've been know to re-adjust the box after installing. I've seen some sloppy right out of the box and was just poorly adjusted. As for the guts there is very little to actual wear out or go wrong there is only 2 bearing in the entire box one on the input shaft but a flat style bearing and a shaft bearing on the output. Typically the slop is the over center adjustment but also seen a few that had excessive bearing preload slop. As for the parts... You can see the output bearing in the pile on the left. The input bearing is hanging on the worm gear. The only thing no shown is the 22 BB's that go in around the worm gear and power piston. The loop cover in the piston is where the BB's go. Here is the power valve on the input assembly opened up...
  15. What's funny is that the box can be adjusted to remove all the play by so few people even know this trick. I will most likely rebuild my OEM steering box if and when it does finally give up or get sloppy. 15 years old and still leak free and tight like the day I bought the truck.
  16. I might lose it again tonight. Water starting to flow in the canyon behind the main house again...
  17. Very common where people upgrade turbo way before needed. Like one gent I talked to upgraded turbos with +50HP injectors. He's wondering why it won't build boost like the old stock HX35W turbo did. Too big of a turbo will create much more lag and more issue with smoke because you'll have to build more drive pressure to build boost. Like myself I could upgrade but it leaves me hanging with even bigger problem of replacing the exhaust brake.
  18. Ok... I thought it was rather weird to see the heavy spike.
  19. I finally updated the flash on the Quadzilla. I figure tonight while I was adjusting headlight again I would play with the defuel features. The boost defuel... I set it for 30 PSI which I know I can hammer past without a doubt. Well, what happens is I can build boost so fast that it still tips off my gauge light at 38 PSI but quickly reels back the power as it falls on its face attempting to hold 30 but keeps pushing past it slightly. With the +2 lead on the Quadzilla it should be -2 on my gauge it's not though... I wanted to test the logging feature tonight too but forget to hit EXPORT before shutting down. Try again another day...
  20. Finally someone found the DOT laws on gravity fed tanks. Thanks to Pcarlson15 over on CF. http://www.cumminsforum.com/forum/98-5-02-non-powertrain/2210985-cutting-up-bed.html#post25696489 GRAVITY FEEDING IS ILLEGAL Here are some laws (regulations) which pertain to gravity feed fuel tanks, and why they are illegal. 1. 49 CFR CH.III (393.65) 6d; Gravity or syphon feeding is prohibited. 2. 49 CFR CH.III (393.67) 7.4.5.; Fuel withdrawal fittings. The fittings through which fuel is withdrawn from a tank must be located above the normal level of fuel in the tank when the tank is full. In other words, the fuel must come from the top of the tank and not from a fitting on the bottom. For safety reasons. When in doubt, look at your factory tank. There also the venting laws: FMVSS 301 1. Safety Venting System. A liquid fuel tank with a capacity of more than 25 gallons of fuel must have a venting system which, in the event of fire, will prevent internal pressure from rupturing the tank's body, or seams. 2. Each fuel tank must be equipped with a non-spill air vent (such as a ball check valve). The air vent may be combined with the fill-pipe cap or safetry vent. ATTA tanks have a minimum of two sources of vents. Atta sending units come with an anti-siphon ball check valve vent and we use an OEM style pressure relief cap. 3. Fuel tanks must be clearly and permanently marked with the manufacture's name, manufacture date, gallon size, and must state "Meets all FMCSA requirements for non-side mounted fuel tank", and "not to exceed 95% of capacity." And the fuel fitting and connection laws: VESC-22 1. The fuel connections from the auxiliary fuel tank to the primary system, including a selection control valve, shall not render inoperative any of the functions of the primary system. The auxiliary fuel tank lines, fittings, valves, and connections shall, for purposes of fuel flow, be of a size at least equal to the primary system. Basically, No connections or selector valve can prevent the factory fuel system from working in normal functions from any part failure. if the selector valve fails, it cannot prevent the factory system from working. No portion of the selector valve or fittings shall be of smaller size than the factory fuel lines that might restrict fuel flow.
  21. Currently running 6* cruise timing which is 20* total at 55 MPH and just about 21* at 65 MPH. Trying a @Me78569 idea...
