  1. I want to attempt for 300k miles on this pump to prove it can be done. Hmmm... Remember 290k miles on the clock. I've got many things on my truck yet that are 290k miles and never been disturbed yet. I've got most of my replacement parts well above 100k on most. @crf450ish Personally I would look towards DAP or Vulcan Performance for injection pump. If you look at my Certified Bosch Rebuilder list you'll find Blue Chip is not listed. Like I could never list myself as a Cummins Engine rebuild because I don't have the proper machinery and tools to do the job. This doesn't mean I can't rebuild an engine just means I must send it all out to second party to do the machine work for me. So that brings up the question what is the quality of the second party? Now I know both DAP and Vulcan are mere vendors but I know the source of where both get their VP44 pumps from. DAP and Vulcan both use Industrial Injection (which is listed on my page). Then DAP also carries Midwest Fuel Injection as well (which is also listed on my page).
  2. Ummm... I think the lighthouse won the battle there...
  3. OEM replacement pump @ 50k miles under warranty. Current odometer is 290k miles so that makes 240k miles on this pump still going. Personally with Blue Chip the prices are too high for used PSG units, then the pumps with new PSG are even steeper. In either case Blue Chip does not have Bosch 815 test stand to calibrate the pumps. Both Vulcan Performance and DAP both sell VP44 pump with only new PSG units and all pump are calibrated on a Bosch 815 test stand for way less money than Blue Chip.
  4. Unhook the field lead and go for a test drive see the issues go away.
  5. Now today I took it out and ran the ever loving dog trash out of the truck trying to get it hot to miss at all today. Nope... Like yesterday was a bad dream or something. Running just fine today not even a little miss at all. Freaking weird...
  6. Same misfire I've got. Exactly what I'm fighting now. It shows up typically after the engine is fully warmed up and does this exact random skip beat we'll call it.
  7. I'm going to lean on the injectors being a cause. Just went out this morning and fire up the truck left it idle with the hood open and listening. Rather tough with a squeaky fan belt too which is brand new. The idle is still smooth and no miss can be heard as of this morning. Then I look up towards the tail pipe and it smoke white smoke with a tint of blue. When you get near the tail pipe and smell the smoke it stinks of fuel and burns your eyes. So, is it possible both sets of injectors are purely junk?
  8. The whole misfire started with semi-cold engine continue for over 40 miles and then slowly faded out. Basically once I made Payette, ID it had stopped all together and left me 110 or so miles to travel. So at that point when the misfire stopped I turned the Quadzilla back up on 6 and dropped the hammer and ran +5 MPH over all speed limits to get home at 10pm. So it had over 100 miles of pure heavy foot driving including passing other vehicles at 80-90 MPH. Power was as expected with stock injectors and Quadzilla. I had the Quadzilla turn to level 0 when I climbed the grade into Horseshoe bend then it was still missing and carrying on. Nozzle caps to protect the nozzles during shipping. What I might do today is hitch up the RV and drag it into town to abuse the truck a bit and see what happens.
  9. Been using the same fuel, fuel station and pump. Those were replaced when I got the 60's from Vulcan Performance. So between the injectors and the cross over tubes they both have less than 100k miles on them. This last swap out I changed o-rings on the cross over tubes, made sure to blow them out with brake cleaner and blew them out more with compressed air backwards to make sure the edge filters were not plugged up. When the misfire started to progress enough that it was shaking the stick in my hand I was backing down. Tried for a few block with the Quadzilla on 0 Level to see if it would change it. Nope. So the Quadzilla stayed on level 0 till after Payette when it started to clear up then I flipped it back on gave it hell to make up for last time and I was unwinding quickly and getting tired. I did try a few heavy throttle runs stock and with Quadzilla as long as the fuel rate was high enough the knock and misseem to fade. This was in traffic in Boise. By the time I got to Horsebend, ID it didn't matter. Climbing a 7% grade at 60 MPH it rattled and misfired the whole way up the grade. That had me really worried by that point because typically the misfire would go away as rail pressure came up the injector would fire now it was fading out and skipping. Then when I pull in the yard last night it was like all a bad nightmare. Idling smooth as ever and no issues. When I'm making 360 mile trips, limited cell service areas, MoparMom that can't really walk long distances at this point. I can't have a truck broke down and having to hike to cell service. Doing inspection and cleanup of my stock injectors before installing.
  10. I drove all the way from home to Boise, ID without a single issue. Did my shopping and meet back up with MoparMom. She had an issues during dialysis and I ended up taking here over to the hospital to checked out. After that was all done the truck was started semi-cold just below 140*F and was already misfiring. Knowing that US55 is the shorts route we start that direction. By the time I made it across town to start up US55 the misfire was getting really bad. I'd tried shutting down the Quadzilla no help. Now with it get so bad that power was starting to be affected minor amount but noticeable. I ditch the US55 route and head towards Emmett, ID to keep me in cell tower range in cases of total failure. Just as I turned off to head towards Emmett, ID the misfire was so bad it was actually creating a nasty sounding knock and had the entire engine rocking in the engine mounts. We were going to stop and get dinner in Emmett but everything was packed. I forged on... Now my next leg from Emmett to Payette the whole misfire thing started fading power was returning. By the time we stopped in Payette, ID the misfire was totally gone. The entire trip home from Payette, ID was totally trouble free. So now I'm just totally trainwreck, I'm tired I rolled in at 10pm last night. Have no idea what the heck just happened last night. Kept rolling the diesel theory in my mind. Need compression and fuel. If this was a compression related failure I would of seen excessive blow by and the misfire wouldn't go away magically. This leads me toward fuel related failure. The only thing I can thing of both sets of injectors are VP44 at one point but that would be super strange to have only a single even beat misfire of the VP44. So at this point and time my Cummins is out of service till I get some resolution to this problem. I've only got 2 days of and gotta be ready to roll again.
  11. That all I use. Pour from my gallon jug into the quart and pour in the amount needed. No funnel needed.
  12. I'm not having a good day. The misfire came back. Explain more later....
  13. I'm going to upgrade to CSMs turbo he sent to me. That happened to be HX35/40 turbo just needs bearing kit. Also I'm not the type to run wide open very long, maybe passing other vehicles. Towards the end my 60s were slamming against the 1300 limit I've set. I've got to admit the stock injectors are smooth but power is reduced quite a bit now. Dropped me From my 19 to 20 MPG to barely 16 to 17 uncalibrated.
  14. Cylinders shifted. I sed to see 800 to 1000 on 4, 5, 6. Now it like 150 to 200 because it's firing one 1, 2, 3.
  15. Maybe that's why I'm still single and unmarried...
  16. SUGGESTED http://dieselautopower.com/diesel-auto-power-75hp-performance-injectors-7x0-0085-sac-vp7x85sac75/ http://dieselautopower.com/diesel-auto-power-50hp-performance-injectors-7x0-008-vco-vp7x8vco/ So @dieselautopower is suggesting the first link for injectors. I'm kind of building this in mind with a HX35/40 turbo being installed too. This way I get a bit more bang for the buck power wise, keep the exhaust brake, and also keep the MPG tune thought in mind.
  17. Funny... When I was swapping injectors today I figure I'd go the extra step and do the valve lash today too. I couldn't get that darn vent off by hand so... I grabbed an oil filter wrench and it turned it right off easy as pie.
  18. You know you can call good friend on the other side of the US... I'm always here to listen...
  19. Not happening... I wish I could... Right now with all the driving back and forth for MoparMom is keeping the budget extremely tight. I'm not capable to work any jobs really because of the time factor. Being my travel days are 12 hour days. So my off days I end up doing maintenance on the truck and keeping it in good repair. So like today was swapping out injectors and shopping for replacement injectors. FEB. fuel logs... So it doesn't give me much for buying tools...
  20. I pulled my Vulcan injectors out and installed my stock injectors back in. I just about ate the grid heater gaskets so I made a run to McCall, ID to get the new gasket. Even after hard pulls (what you would expect with stock) it was idling fine and smooth in town. EGT's a bit higher than the +50 HP injectors. Timing rattle is nearly gone like I need to crank up more timing. Runs very smooth absolutely smoke free. Now last trip down to Bosie, ID when I fired up in the morning the exhuast was just lightly smoking white and smelled of fuel. Another clue something was wrong. I basically gave in swap back to stock and problems are gone. My problem is I don't really want to play the pop test game much and end back up pulling them all over again in a few months having to deal with another misfire or injector issue. Made a few phone calls to see what I've got for options for injectors. @dieselautopower is trying to set me up with injectors... Might be closer to +90 HP SAC's...
  21. I just found out my injectors are indeed done. I changed out to my stock injectors and no longer having any issues.
  22. Exactly what I'm going to do today I'm going to warm up the engine a bit and then get busy pulling my 50's out and putting my stockers back in. I'm sick and tired of the old 1950 tractor misfire.
  23. I attempt to listen to the members and keep adding things that are needed...
  24. Dang...........
