Fuel Line Upgrade Question 2001 Cummins
Make sure you replace everything inlcuding the pickup tube in the fuel tank. When I first got my AirDog 11 years ago I was in a hurry to go up North to see a friend in the hospital so I installed it against my stock pickup assembly. Needless to say it ruined the AirDog 150 ability to pump fuel and keep stable fuel pressure. You much have 1/2" lines from the tank to the VP44. You may keep you stock fuel heater and filter without any impact to fuel pressure or flow.
Just A Sweet Story
Reminds me of the older folks here in Idaho. They can tell me all kinds of tales of what it was like back in the early 1900's. Today there is so few people that want to be bothered or to aid their fellow human race.
Quadzilla Adrenaline V2 Testing
That's something I want to touch on the span of cruise timing operates at. @Me78569 we need to include down to 35 MPH and just a hair below 1500 RPM's. Right now the cruise timing only operates at speeds above 45 MPH and above 1500 RPM's so if I set my cruise on at 35 MPH on long city streets I'm stuck with performance timing. Because both RPM and Speed are both below the range. So like include down to 1,200 RPM's and 35 MPH and you'll cover the entire usable cruise band. So make it two bugs to fix. Like I found this on my day trips to Boise. The truck route through McCall ID is 35 MPH with no traffic lights or stops. I can set my cruise for 35 in 4th gear. 35 MPH is below the cruise timing limit, as well the RPM's I'll have to verify the number.
Brace Box
The signature setting are up in your profile setting. Yo can access them by going to upper right clicking on your name. Then Account settings. Then select signature. Or click this link... https://mopar1973man.com/settings/signature/ Mopar1973Man.Com site shows signatures on mobile devices.
Torque Converter Lock / Unlock Issues
You might be getting marginal. I would do two other test. 1. Disconnect the field lead go for a test drive if the problem is gone the alternator fail on the AC noise. 2. Remove the Alternator and have it bench tested at a part store make sure they do the AC ripple test. Now if both failed plus you voltage test then you basically got 3 smoking guns pointing to a failed alternator.
Apple thing... Just say I got no love for Apple devices. Android / Linux no problem. Most because anything and everything for iPhone has a price tag. Where anything Android / Linux is typically free.
Most likely because the android software works off the bluetooth side not wifi like iDevices do.
Brace Box
I'm at 289k miles now home stretch to 300k miles. Never experienced death wobble on my truck yet. Steering is still tight. Still running factory steering box and tie rods ends. Only changed 1 set of ball joints and one track bar. No steering brace on my truck at all. Use quite a bit offroad and no issues to date. Mostly it's about being pro-active about steering issues not lets the little things all adding up to create the death wobble.
Help-Cummins Down............
If the code is present the ECM is dead.
Removing Crankcase Vent for Valve Adjustment?
Typically grab it with my hand and twist it off towards the left. I've only used a strap wrench once to remove a vent. Now you never want to put anything in the hose neck to twist it loose. It will break the vent cover as a poor gent did in my driveway last year.
That's hard to do... I would look in your local area and find out what is available. Like up here in Idaho I've got Module Masters that might be able to handle a ECM. So folks mention Go ECM as a rebuilder but all have pro's and con's. Basically I would look for a local module builder and then ask about turn around time and warranty coverage.
Brace Box
What size tires are you running? What size wheels too? Lot of the death wobble start with oversized tires that are way out of balance. Then I dig into the shocks and suspension.
There is the only choice of rebuilt. There is no aftermarket ECM that I know of and ECM are no longer manufactured at all. How are you to know that the ECM you just picked from a junkyard up isn't already fried from AC noise from a bad alternator? You can't buy ECM's from Cummins because of a license agreement set by Dodge. Neither can Cummins do any reflashing of ECM because of EPA regulation and also once again license agreement by Dodge.
Real Jake brake
Here you go... http://www.thunderbrake.com/
ATF and 2 stroke in fuel?
Here is what ATF will do... Now 80k miles of 2 cycle oil... Now tell me that ATF is a good thing to put in the fuel... ATF is high in ash content, high in anti-scorching compounds (which retards burning or ignition quality), friction modifier which is not exactly good for injection systems. Now 2 cycle oil is just oil. It contains no ash so deposits will occur. No friction modifers, no anti-scorching compounds. Again just oil that is design to completely. burn. ATF is not designed to burn at all.
Brakes
Mine are standard hex head metric bolts for both the caliper and the caliper frame.
Shrader valve leaking
- Brakes
2500 and 3500 are the same.- ATF and 2 stroke in fuel?
That product actually scored rather high in the HFRR score. Lower the HFRR number the better. There is an article in the database on HFRR scores on common additives.- Fuel Pressure Gauge needed on 12 Valves too
What about the pressure limitations of the VE pumps? Wouldn't piston pump be too much pressure?- Brakes
Mine just slide on and off. No other hardware to remove. It could be the parking brake shoea hooking the drum. You might have to loosen the parking brake starwheel turn it towards the axle to loosen.- White smoke
It could be injection pump issues. I just ran into a truck the white smokes on start as well. Then the magic P0216 code popped up.- Brakes
??? Why would you? Rotors just slide off the hub. Like I said just remove the caliper then caliper frame then slide the rotor off the hub.- Brakes
Just remove the calipers and caliper frames then remove the rotor.- 2016 Silverado
Quadzilla tuner... Too bad you truck isn't diesel. - Brakes
