  1. That's a bug that I know of @Me78569 says there is a bug about what data is displayed while in cruise control state for fly by wire systems. So to see actual timing you have to lightly place your foot on the throttle and put 1-2% worth of throttle sense on the Quad and it will now show the proper timing.
  2. Might need a high quality crows foot, pipe wrench style to get that #5 loose. Use plenty of PB blaster on it. Might have to shock the fitting to get it moving so look for that crows foot for that purpose and might try rattling a impact against it a little bit.
  3. From everything I know of OEM fans are discontinued and no longer manufactured. Might try doing some searches on the EBay for used one. I know the electric fan don't have the CFM's to keep up with towing.
  4. Ummm... The injectors are swimming in engine oil... Then the other side of the o-ring has diesel fuel. My crazy idea of getting them out...
  5. Most likely would never get the injector in or lined up being it would stand up so much taller and the crossover tube won't line up right and spray pattern would be most likely wrong. I know there is a wide range of copper shims but I really doubt you could get 2 stacked and get a injector lined up in the hole. Anyways the copper shim crush to the injector not the head. So the injector will still lift out. The o-ring is the only thing that would hang it up. So if the o-ring burnt to the head is will stick and hang up. All I've ever done is screw that short intake bolt in the head and then using that flat blade screwdriver and pry them out. I've even use small nail bars before.
  6. It could be the o-ring is burnt to the head and stuck. Again just need to pry harder. That injector is harden steel you not going to hurt the injector.
  7. That's on a 12V where the injector is exposed to the elements. Different story when the 24V has the injector buried in engine oil and diesel fuel.
  8. The only thing that is holding that injector in is the o-ring on top. The only thing I can say is more leverage it will pry out. The nozzle and copper shim will not hold the injector in. The cross over tube might if it not pull out enough.
  9. Like I'm already looking at converting my current fog light setup over to the PDC so I can ditch the fuse hanging off the PDC positive post and ditching a switch on my overhead console. I'll need to change head light switches then add a terminal for the hi beam fog lamps. This way everything is back to stock controls as closely as possible and way less hanging hack wiring in my engine area. Left most switch is my current fog light switch. https://mopar1973man.com/garage/modification/212-overhead-console-switches/ So looking at the fog lamp relay you'll see the normally open contact is void. So if I add the terminal that would power my pair of fog light on the hi beam setting. Then ditch the fuse on the PDC positive and install it at Fuse O in the PDC. So then the headlight switch would have control of the fog lights once again like it was stock but with the add function of hi/lo selectable for lights. So now looking at the Quad High Beam relay you'll see the normally close contact is void of a lead so if I add the lo beam back to the Quad Bulbs now you'll have quad hi and lo beam on both bulbs using only 1 fuse and 1 relay compared to 4 relays and 4 fuses like all the other kits do. The only reason the voltage is lower on the stock headlight is you have to understand Dodge's weird idea of wire gauge size and running the headlight ground all the way into the cab to the multi-function switch then to the headlight switch to terminate the ground lead at the driver side kick panel. So majority of vehicles I know of have rusted out ground connections at the driver side kick panels and then to make matter worse the headlight switch and multifunction switch contacts age and not a perfect 0 volt drop any longer. Then toss on top the small wire used to power the headlight plus the long run into the cab. So there is some voltage drop this why the kits are created. Again instead of solving the problem people toss another hack on to band-aid the issue. Like on my truck all my ground and wiring connection are in solid condition so my amount of voltage drop is nothing like what other trucks might be.
  10. I always just use a grid heater bolt (smaller or the 2) and screw it in and pry up with a screwdriver against the rocker arms.Yes the crossover tube must be pull out a fair amount at least 1 inch to be safe.
  11. Hua? The only thing different is the Quad hi beams is relay controlled. Uses the same multifunction switch and the same headlight switch. Basically wired the same way. As for a module... I don't see where the module you speak of is. No such module exist in either lighting systems. Stock Plain Headlights Then Sport Quad Headlights .
  12. Simple! Edit your first post. At the top, it will give the box for the topic title and you can change the title. You might want to change it to something about lift pumps and relay protection.
  13. Interesting Idea for heavier canopies.
  14. I'd love to... But... I would like to have @klcammie retitle the thread and I'll stick it to the top for the time being. Eventually, it should be converted into an Article for safe keeping.
  15. Yeah... Google Drive. Rather a pain in the butt. Kind of wish it was saved to the phone directly. I've got 64 GB (32 GB built in and 32 GB SD) of storage on my phone which I can access by USB. Since my phone always comes to my desk and is plugged into the PC. Nope... Gotta make sure the WiFi is turn on the phone so the phone can upload to Google so I can re-download the files again. I'm not fond of storing anything in the cloud. Being I run both Android and Linux I've got wonderful synchronizing software than can do a full backup of my phones contents way faster than Google Drive. 7" tablet fits the pocket by the transmission excellent. Once I'm done with programming I'll most likely quit firing up the Quadzilla app and just fire up my MP3 player on the phone for music. Being I can answer phone calls through the stereo I'll keep the location but not a requirement. This why I didn't make anything permanent.
  16. The timing curves and setup is still quite a mystery to all of us being this is the first tuner that gives a wide range of timing control vs anything else on the market. All other programmers and modules have been just a boxed tune and take it or leave it type of thing so now trying to figure out what works best are going to take all of us to figure out and share our tune. So I've created a excel spreadsheet and going to keep it updated. I've also included an exponential growth calculator so you can create smooth fuel or timing curves. Set the start point and the percentage of growth and it will lay out 0 to 30 for calculation. For timing just think 0 to 4 and those are your numbers. Yes, Quadzilla does allow decimal point numbers in both timing and fueling.
  17. UPDATE! I've now added a exponential growth calculator to my Excel sheet so no longer do you have to wander back and forth to calculate fuel maps or timing map curves. The spreadsheet is on the first post of this thread.
  18. Might take a peek at my economy tune as well. I've been keeping the Excel up to date when I make changes.
  19. Sorry, no salvage yards around me. This is why I'm trying to source out the terminals for a clean install with the possible idea of making a kit to actually sell that would give a clean install of the sport headlights. Instead of the hack kits with 4 relays, 4 fuses, etc. Why not 1 relay in the existing socket and 1 fuse in the existing socket in the PDC?
  20. I've got a lot of canyon roads that have mild up or down grades. So mild that I can keep the boost well below 10 PSI but the load can vary 10-20% typically. So like for example if the truck is traveling flat ground and the encounters a light down grade that engine loads is reduced 5% it would be nice to push like 1* more timing. Or if the reverse happened like a small knoll hill timing would retard say 1*. Would be different if I lived in Texas where everything is basically flat and then the whole set cruise timing would be fine. But then there is folks like me that live in the mountains with rolling hills and highways where a fixed timing isn't optimal. Watching stock vary up and down as small changes of load occur but Quadzilla basically holds timing to RPM that's it. So if cruise control is set then RPM doesn't really change much but engine load and boost pressure do.
  21. I've got Mark over at The Harness Shop doing some digging for the terminals and seeing if he can get them. If so it might be a nice clean Sport headlight kit that people might want to buy from "Mopar1973Man.Com Store". Possibly idea... We'll see. I've also contacted DAP and let them know the supplied splitter cable is pinned wrong on the main bulb.
  22. Just to confirm @Me78569... In cruise state... we should see timing advancement during period low engine loads. Then as load increases then the timing should retard. Based on the boost pressure setting remain in Then if it kicks out to performance mode... Keep the current fuel load timing you have now. Where timing retards with lower engine load but advances with high engine loads.
  23. Ok. My first step. I doing this from experimental point of view so nothing is finished per say. The adapter harness I managed to repin as a pass-thru lead now for the main reflector and bulb. I did find out that the supplied splitter cable is pinned wrong on the main bulb on lo beam selected it actually on the hi beam filament on the bulb. So I had to repin again to correct that. You'll find that you have to trade the white and blue on the DAP kit to correct the hi/lo problem. @WiscoRedkneck now I want to know where you got your connectors for the relay and the fuse rail? I've got the hot side of the fuse rail but the load side is missing. As for the relay socket its missing all contacts in the Quad Hi Beam socket. What I want to do is populate the relay with both the 87 and 87a contacts so both hi/lo will be functional. Being I need the truck tomorrow for another Boise run I'm going to stop right here till WiscoRedneck can provide info for connectors. I found the fuse clip for the PDC... http://www.mouser.com/ProductDetail/Delphi-Connection-Systems/12004568-L/?qs=Q2Rsuhc0qGvr8WOrkX1Eew%3D%3D Having problems finding uninsulated female spade connectors with locking tabs.Rather common connector but tough to find so far.
