Degreasing Motor
Now put this in the spray bottle... http://www.homedepot.com/p/ZEP-128-oz-Industrial-Purple-Degreaser-ZU0856128/100047759 This stuff is super strong and takes little time at full strength to clean a pretty ugly engine. It will shine up your aluminum wheels too. For my stuff I normally mix it down 50/50 with water. Just don't leave it on aluminum long it will start to foam up and if you do it will turn it black. It's truely a acid based cleaner.
trreed's upgrade thread
DAP is just a vendor of Industrial Injection or Midwest Injection. Both II and MI both have Bosch 815 test stand.
Done... You now have one...
Quadzilla Adrenaline Economy and MPG
How about using level 1 could that be played the same way? Nevermind I'll build a full stocker tune just for the article purpose. This way newbies jumping in have some sort of base tune for pure stock injectors.
Ok... Now that I've been on stock injectors for about 3 days now. I can for sure tell everyone that @Me78569 suggested 19-20* timing is about right for stock injectors and nearly the same as stock timing. So what you are looking for 19-20* at the 55-65 MPH range. I will admit that stock injectors are not good at all for MPG numbers. I'm about 2-3 MPG (calibrated) lower now than my old +60 HP Vulcan Injectors. Power is lower of course and it's smoke free tune for either my performance or my economy. As for the misfire issue it's completely gone on the stock injectors I've covered over 500 miles now without a single issue of missed beat. @Me78569 is asking me to build a fat tune and find out how hard I can push stock injector till they get smoky. So later on today I'll build a tune to see how far stock injectors will go.
Fuel Pressure Gauge needed on 12 Valves too
So when you say they are stake the seal in you merely just using a chisel and deforming the outter lip of the seal hole on the injection pump body.
Real Jake brake
@dripley Time for a upgrade to PacBrake. I know if mine gives up that's going to be my replacement.
Isspro trans temp gauge
Pull the sensor connector pack the plug with di-electric grease and cycle it in the socket 3 times. The problem will go away. I had the same problem this winter in -20*F weather showing my transmission being over 200*F. Not likely. This is all caused by salt water off the highway.
True both are just vendors.... BUT! Both sell injection pumps from Industrial Injection then DAP also sells Midwest Injection. Both companies have Bosch 815 test stands and are certified Bosch rebuilders.
Vulcan performance or DAP. Those are the two I would call for VP44 pump. https://mopar1973man.com/forum/151-vulcan-performance/ https://mopar1973man.com/forum/149-diesel-auto-power/
Interesting solution... Is it a solid solution though?
Nv5600 becareful who you let build
Ask @TFaoro he did the conversion.
Real Jake brake
Yup... I'm the same way. Touch of the service brake to correct but rare to do that.
Suspension
I say hitch up a trailer it will level out on its own. Make it work hard.
ECM failure or wiring issue?
Marginal.... I've been getting .025 to .035 for alternators.
Suspension
I would get the new blocks and the just go to machine shop and have 4 U-bolts made to fit using the old ones for patterns.
Help-Cummins Down............
This is why I have problems with guys changing apps sensors for idling issues it's not apps issue typically. ECM is in full control at idle. Then the other is changing and/or cleaning the MAP and IAT sensors for idle problems neither really have control of idle either. ECT controls idle speed.
Real Jake brake
I tend to agree with most here that the exhaust brake is more than enough and very simple. For us manual transmission owners with exhaust brake it very capable of creating lock up conditions of the rear axle on slick surface like mud, snow, ice, or even wet highways. Even if you did have the ability to be like AH64ID the more pressure you can hold back using him for the example 75 PSI is just that much greater braking force. Even with just more or less stock ISB engine and Jacobs exhaust brake I've extended out my brake pads to at least 180k miles. Next due date is 360k miles and I'm currently at 290k miles and better than 50% of pads left yet. Even with that said I've got the ability to get the rear tire hopping and skidding with just the EB and factory 60 PSI exhaust pressures. Over the years I've learned on how to use my gearing to control the amount of EB strength. So need light amount row a gear up. New more row a gear down. Again I speak from a 5 speed manual perspective where a 4 speed auto is way different story being the lockup controller and only 4 gear making it rather challenging to get full use like a manual where I can continue to down shift to first pulling the truck to a near stop which an automatic trans can't do typically they EB only functions in 3rd and 4th which provides TQ converter lockup.
NV5600 transmission has its own weakness with bearing lubrication, design faults, lack of parts because of a short life span. After seeing the NV4500 guts compared to the NV5600 I'd have to say the design was more complex for the NV5600 making repairing or rebuilding more challenging.
When the idle validation switch for idle is grounded the ECM ignores the APPS sensors and then relies strictly on the ECM software for idle.Being there is 3 modes of idle. You have normal curb idle at 850 RPM's, then there is normal 6 cylinder 1,200 RPM idle then last there is 3 cylinder 1,200 RPM idle where every other cylinder fires which is typically 4, 5, 6. So no its not a closed loop by handled by the injection pump. Yes the injection pump can produce idle on its own but there is other subfunctions of idle like anti-stall for the manuals that monitors the engine RPM's and throttles accordingly to prevent engine stalling during clutch engagement.
Quadzilla Adrenaline V2 Testing
Only takes a few burst runs like that, showing off to totally kill my MPG for the tank. I do the same thing. I'm normally pretty mellow till I'm challenged, trying to show off the Quadzilla, etc.
The crf450ish random question thread.
The only thing red fuel is untaxed... I've got so many locals here than believe that red dye fuel is so much better fuel wise. Really the only difference between red dye and undyed is just the taxes. The fuel is no different than undyed. Now be aware the fines for being caught with red dye in the tank are quite steep. Last I checked in Idaho its $1,000 fine for every 1 gallon of fuel in the tank.
I can see it coming...
Sometimes the name is just a name, it doesn't specify the amount of quality.
Not losing much... Top gears are the same as well as one gear down from the top. So highway wise you not losing anything...
