Summer refresh thread
1. I got the economy brakes from RockAuto and still going on them I'm going to most likely exceed the OEM in mileage I might just make 200k miles on these brakes. 2. I got AC Delco ball joints from RockAuto and still tight and no issues. The other factor I'm not running oversized tires either. 3. 2002 the rotors just slide off. 4. I did a NEW starter from NAPA and no issues to report. I kept my old starter to rebuild but just not had the time to do it yet. 5. I'm running the aluminum swivel end heater core and no issues to report.
Quadzilla app and opinions on it
What device are you using?
100hp 7x.009 injectors EXHAUST POP?
Time to pressure test the system.
ABS failure found!
Yes. You can program speedometer settings or different tires.
ABS failure found!
@Chris O. is the one to talk to... He's in the beta test phase now. As for the BoD here we are in full support of him and hoping to get this to market. What I can use so far is the ABS tests, CTM is for high line modules I've got a standard, Air Bag code reading, then displaying info from the CCD network like battery temp etc.
ABS failure found!
LED Headlights
I hate to admit it but sport headights so far Are just OK. My aircraft landing lights are far better than my headlights. I've still got to wire in the relays for the second bulbs. Even sport headlights scatter the light but it is better than the stock signal bulbs.
Isspro trans temp gauge
Mine did the same thing and I greased it up and the problem is gone. Idaho is 7sing a lot of salt so little salt water Will foul the gauge. I want to Michael at ISSPro about this.
ABS failure found!
First off I got to say Thank You to @Chris O. for producing a wonderful tool for me to beta test for him. I've managed to test the speed sensors and see the right front is dropping out below 30 to 40 MPH. It drops to zero while the left shows signal. This produces weird ABS action and pulling left fairly hard. Everyone knows I've changed sensors and tested wiring. I've talked to several tire shops and found an answer. The tone ring has most likely broke free on the hub. So I'm hunting for a used unit bearing for testing purposes. Anyone have old bearing laying around?
New Cummins owner - Intro and beating the dead horse on fuel delivery
Be aware that any sump kit or bottom tank feed is illegal for highway use.
Hello All
Nice truck looks like @JAG1 truck....
Diagnostic Option Missing From iQuad App?
Now being down that road I would suggest you think about pop testing your injectors. This is not a Quadzilla issue at all. Injectors are either sticking a bit at idle or getting pissy.
That is still the iQuad app that is freezing up. I would suggest checking over at the download area for possible updated app. Maybe you just unlucky and got a bad download of the app for your device.
Front driveshaft rebuild
Thanks for all the Likes... Moved to the article database here...
Front Driveshaft Rebuilding
Part numbersNAPA U-J617 (1)F NAPA UJ354 (3) Tools8 mm Socket, 1/4" 16 mm Socket, 3/8" (or 1/2") Ratchets Extensions Snap Ring or Needle Nose Pliers I just got done rebuilding the front driveshaft. Rather easy task and the parts are easy to come by even to rebuild the double cardan joint ball. Before you break down the double cardan joint, mark it to enable you to get it back together the same way. I used a file to scratch a line across all the pieces. (Beware, using paint or a permanent marker will rub off) It is hard to see, but there is a line across the left Ujoint cap, the middle Ujoint and the rear Ujoint cap. Now, using my Harbor Freight Ball Joint Press, I'm simply driving the cap out the other side and disassembling the double cardan joint from the flange end, working towards the shaft. When you take it all apart, now...check your centering ball and bearing. Mine was in sad shape. As you'll see all the needle bearing fell out (ashtray) and no grease was left. So I made a call to the local NAPA store, and they had the centering ball in stock but it may be pricey. It is made by SKF and part number is UJ617. Now you need to clean up your old end, just remove all the grease and dirt. I piled up a good gob of grease in the bottom before installing the ball. Use a socket to drive the ball into the Ujoint end. Then drive your seal in place with the same socket, but do it with a very light tapping using your hammer or small ball peen. The grease should have been shoved into the needle bearings. You will notice there is a small hole for the grease to ooze out of on the bottom which filled the needle bearings. Then, start to assemble your Ujoint in the driveshaft. Again, I was using a Harbor Freight Ball Joint Press which is awesome because you'll never have to strike the driveshaft with a hammer or worry about needle bearings falling out. Drive the first cap in deeply using the Harbor Freight Ball Joint Press. You should have the trunion sticking out slightly. Install the 2nd cap and press the bearing cap until the Ujoint is centered. Install both retaining clips. Then, I did things a bit different and assembled my last Ujoint in the rear flange. What you have to do is place your spring in the driveshaft with a bit a of grease to hold it in place. Tilt the ball just enough so it will go through onto the shaft over the spring of the center shaft. Align the trunion with the yoke of the Ujoint and the centering ball at the same time. Be patient, there is enough room and it will then go in. Now, install the two bearing caps. Finished product... So when you are done it should move in all directions freely without binding. Make sure to grease all your Ujoints before installing the shaft. For the front Ujoint, I just used the vice and pumped grease until the red is seen in all ends. Green marine grease may be suitable for areas where salt is used in the winter or along beach areas. Now install the front driveshaft... What a double cardan joint looks like moving...
I know here shortly this will be added to the article database. I just got done rebuilding the front drive shaft. Rather easy task and the parts are easy to common by even to rebuild the cardan joint ball. Also forgive me I got the camera lens greasy on my phone. Before you break down the double cardan joint mark it so you get it back together the same way. I used a file a scratch a line across all the pieces. It hard to see but there is a line across the left joint cap, the middle joint and the rear joint cap. Now using my Harbor Freight Ball Joint Press I'm simple driving the cap out the other side and disassembling the double cardan joint from the flange end working towards the shaft. When you take it all apart now check your centering ball and bearing. Mine was in sad shape. As you'll see all the needle bearing fell out (ashtray) and no grease was left. So I made a cal to the local NAPA store and they had the centering ball in stock bit pricey at $80 but I needed. It made by SKF and part number is UJ617. Now you need to clean up your old end remove all the grease and dirt. I piled up a good goob of grease in the bottom before installing the ball. Now using a socket to drive the ball into the joint end. Now drive your seal in place with the same socket just do it very light tapping with your hammer or small ball peen. Now the grease should of been shoved into the needle bearings. You notice there is a small hole for the grease to ooze out the bottom and filled the needle bearings. Now start to assemble your u-joint is the shaft. Again using a Harbor Freight Ball Joint Press which is awesome because you'll never have to strike the drive shaft with a hammer or worry about needle bearing to falling over. Now during this process the first cap I will drive too far to the other side but not out of the yoke. This is to push the cross over to the other side a bit more so when you place your other cap it already started on the cross arm and less risk of the needle bearing falling out. before driving it in place your clip on the first cap. Now I did things a bit different and assembled my last joint in the rear flange. What you have to do is place your spring in the shaft with a bit a of grease to hold it. Then tilt the ball just enough to so you can start the cross of the u-joint and the centering ball at the same time. Be patient there is enough room and it will go in. Finished product... So when you are done it should move in all directions freely without binding. Make sure to grease all your joint before installing the shaft. For the front joint I just used the vise and pump grease till the red was seen in all ends. Now install the front driveshaft... What a double cardan joint looks like moving...
Choice of companies
Opps my bad I thought he was talking VP44 since we are in the 24V area... Moving to the Ford forum...
LOST POWER
I wouldn't suggest plugging the return line. Take a risk of blowing the front seal out without a return path. Heat is one factor but I'm still waiting to see summer heat. So far I've not seen anything temperature wise that would even be stress full to electronics yet.
1997 F250 7.3 diesel hpop
I've got good faith in Industrial Injection... Now Thoroughbred Diesel I'm not very impressed they had a bit more warranty issue and product issues with their lower prices.
Injectors stuck....cannot remove?
Like I'll be due to do this project very soon. I'm still running leak free be eventually Murphy's Law will get me... Suggestion pull the valve cover it will give your hand a wee bit more room to get in there.
Choice of companies
Personally I would only buy pumps from Certified Bosch rebuilders. Now you have to remember there are plenty of vendors that sell Certified pumps. Like I know DAP and Vulcan Performance both sell certified pumps.
LOST POWER
Return line is going to self drain every single time the engine turns off. Return line in the fuel basket is not suppose to be submerged in fuel. It normal for the return line to drain and have air in the line. What is not normal is the supply line draining out and get air in the line.
There is a o-ring kit for the tee on the return line and also there is 2 banjo bolt washers on the banjo at the back of the head. I never crack any line for priming. Like my last swap of injectors I just install tighten all my lines and fired it up. Never bled a single line at all. Yes it still runs like trash after it starts but a few good hard revs of the throttle and its idling smooth.
Quadzilla Adrenaline Economy and MPG
I'm not racing quarter mile. I want the pull power for 25 to 45 MPH so you regard the timing to move your torque curve down. This tune sure will eat tires.
Degreasing Motor
No... You want cool engine when washing. Leave it off.
