Quadzilla Adrenaline V2 Testing
True...I've got my old 02 sensor because I thought I had a bad one come to find out the stealth plate nut came loose. So I kept the old 02 Sensor and install the 01 sensor and the adapter.
You are the rarity then..
I'm talking about the Cummins MAP sensor. Not your boost gauge. As for mine, I've push well into the 40's a few times now with the Quadzilla. As far as what I done research on more people lose accuracy after about 40-45 PSI.
I don't think it accurate to 62 PSI. The best I've hear is about 40-45 PSI its starts to drift.
Cleaning sensors does nothing... It NEVER fixes any problems. The stock sensor only goes so far any ways. I know it won't make 60 PSI.
ATF in fuel
Highly suggest against using motor oil or ATF for any kind of fuel additive because of the high ash content. I advise replacing the ATF and motor oil with 2 cycle oil. As for power service that is cetane booster and 2 cycle oil is gets a reducer. So mixing is just neutralizing effect. Highly suggest against mixing products together because of possible negative effects. If you want to keep your system clean use better filters. As for cleaning you injectors you have to full disassemble each one and clean by hand. There is not a product that can clean a injector.
Should of been on you truck...
Birthday present came...
It's doing good. I'm getting rather good at flying it. I've got a fun game with the dog. He get mad at the drone and barks at it. So I tell him to get it. He'll go out and chase it in the yard. I fly it back to me. Fun way to get practise and the dog gets exercise too.
G56 rattles horribly after switching to a dual disk clutch and SMF
Android and Linux all the way... Still going with Ubuntu 16.04.1 and training people one at a time in my spare time. As for fluid I broke away from the old 75w-85 Mopar fluid and went to the 50 SAE transmission fluid GL-4 Synthetic.
NV4500 Fluid Change
Holds 1 gallon of 75w-85 GL-4 fluid. Being it's no longer manufactured I'm using 50 SAE transmission fluid GL-4. 12k miles no issues.
6.7 ISB Surging issue with H&S Mini Max
Why a live data tool so you can watch rail pressure and fuel pressure gauge so you can watch the supply to the CP3 is good idea. I had one come in that had a bad lift pump still won't run after warming up. Come to find out the #4 connector tube was loose and as the heat expands the head the leak was in the head and was losing rail pressure. Again the live data tool spotted this.
P1689 - 1999 Ram 2500 - Idle @ 800rpm & start easy- touch pedal rpm jumps to 1400????
Like I said ask the members here I'm sure someone would be nice enough to help you out. If I lived closer I'd be on your door step to help out. I've done plenty of VP44 swaps. Like my last two job I've had @hex0rz show up at my place to have injectors swapped out and then gone over to Walla Walla, WA to @Taz place to do a clutch for him. So like I said ask around I'm sure someone would help you out.
Nope, the transmission was a G56 on this truck.
Killer dowel pin and type of blocks
All I did was pull the cover clean everything up. Installed my front crank seal. While the cover is off, just retorque the bolts you can get at with the cover off. Clean your mating face up and with ultra gray silicone glue your gear cover back on. As for the KDP I've got the same thing of the updated case. As for odd report I've seen a single reported 2002 Dodge Ram with a KDP repair and seen the actual Dodge Dealer repair bill. Very rare, but there were a few that got in the pile.
Nice to see you back @Rogan Something isn't right. I just done a dual mass to single mass flywheel on a 2006 Dodge and just a standard single disc clutch works very well and no noise at all. All I think of is the added mass of the dual disc clutch is causing the problems.
If you have to, ask around, I'm sure there are other members around you that might be able to help you finish it up.
Ambient Temperature Depending Performance
Time to break out a live data tool and see what your IAT and ECT temperatures are actually doing when this occurs. Most likely the foooler won't resolve it but I'm curious if there a data problem being fed to the ECM creating this issue. Just with winter fronts and running 65 in 40-50*F weather...
Remove the radiator completely and power wash from both sides. You might want to use a better quality degreaser that really clean up the caked greasy oil. This stuff really works good. http://www.homedepot.com/p/ZEP-128-oz-Industrial-Purple-Degreaser-ZU0856128/100047759 Front seal would be a good thing. Double check all your gear case bolts on the inside too. I highly suggest you buy a 36mm fan wrench and a fan pulley holder. I know of people using a punch rod and knocking the fans off with a hammer. Not a good idea being it puts stress on the hub bearing do that. Just shortens the life of the bearing. It is a left hand thread so think backwards.
Good ol' Linux/Android to rescue...
I've seen another youtube of a gent that did an Android Stereo and loaded his Quadzilla App on as well. He had it all custom with DVD movie player as well in 3rd Gen truck.
Vp44 going out!!!!!!!!
I would suggest you just consider replacing the injectors. Good time for upgrading...
P0123?
I highly suggest you do a AC noise test on the truck if the VP44 failed. If you don't resolve that issue the new VP44 will go down that road again and fail.
Nv5600
Either way, I highly suggest fully disassemble and rebuild the transmission again. Since something is wore out it best to fully disassemble so you can inspect all parts for damage. Like mine I broke the main shaft but found out the bearing were wore out and so was the 5th gear on the bearing face. The inside of the 5th gear wore the hard facing off.
Correction 1/2" PVC pipe.
