  1. Very frustrated. You got to understand we are not TV watchers. So the TV in her room is never on. The only outside information she gets is from my laptop I left her down there. She is tired of the Monday, Wednesday, Friday dialysis. 2 hours of set up and then 4 hours of laying there waiting to complete. She has some nights where she doesn't sleep very well and other nights she sleeps good. Again just another factor of being stuck in a confined room and not able to wear yourself down with normal work that you are used to. The ultimate goal is to get her home for a break from the hospital for even a short time. I'm hoping to get to talk to the doctor maybe by Wednesday and find out more information.
  2. This is one of the reason I would of asked for an outside test to be done. Now you can compare the two test and get facts of what going on. Now your stuck with just what you get from DAP.
  3. I agree... Idaho has had mild winters for years it would be awesome to see a nice deep snow year and less of the bitter cold like in the past years where it doesn't snow much.
  4. Anyone want to know what going on just reply to this thread I'll make sure to post what I know. As for today, she had her dialysis again today which kind of drains on here for the day. She is still doing good. She is getting tired of being cooped up in that hospital room. Remember this all started back on October 2nd.
  5. I'm running only 6* of timing. Then my low boost scale is set for 25%. I've taken a stock tune and tweaked it to my own liking. Power Levels: 7 Fuel Load timing: 2 Low PSI Timing Reduct: 3 Timing Reduct Scaling: 100 Light Throttle Timing Adv:2 Light Throttle Timing Load Limit: 30 Timing vs rpm 1500: 16 2000: 18 2500: 23 3000: 25 Timing Max: 26 Fuel Stretch: 1400 ** turn this up if you need more power up top TPS Pump max: 100 TPS Pump Min 20 Minimum Pump Tap Fueling Percentage:0 Pump Low Boost Scale PSI: 5 Boost Scaling: 38 RPM Limit: 3200 Power Reduction: 5 (Barely pulls at 5 MPH great security feature) 0 PSI %: 100 1 PSI %: 102 2 PSI %: 104 3 PSI %: 106 4 PSI %: 108 5 PSI %: 110 6 PSI %: 112 7 PSI %: 114 8 PSI %: 116 9 PSI %: 118 10 PSI %: 120 11 PSI %: 122 12 PSI %: 124 13 PSI %: 126 14 PSI %: 128 15 PSI %: 130 16 PSI %: 132 18 PSI %: 134 20 PSI %: 136 22 PSI %: 138 24 PSI %: 140 26 PSI %: 142 28 PSI %: 144 30 PSI %: 146
  6. Yes. 2001-2002 Beta Tune.
  7. Try finding the module first before doing the flash. This will ensure the software can see the module.
  8. No need to for rooted device it will work non-rooted as well. I'm using AirDroid to transfer and install my APK files.
  9. Very good song... Points out the the truth...
  10. At least for me doesn't matter being there is over 5 years and nearly 150k miles on the NAPA bearings.
  11. Do I need to run this as well?
  12. Just got back from spending the weekend with @MoparMom. She is doing good. She in the process of healing her peritoneal dialysis catheter. It'll be about 2 weeks of healing and then she'll be starting training for the PD. After that she'll come home. They also are making plans for getting the kidney stones out too. https://en.wikipedia.org/wiki/Peritoneal_dialysis
  13. Just like my last trip of 422 miles hauling a Cummins engine down to Caldwell, ID and come home the next day. Nove 5 & 6. This includes running the interstate at 80 MPH. There isn't a P7100 setup out there that can touch this kind of fuel mileage on 24V engine. Fuel to boost management is crude at best and static timing. You might want to hop over to the Quadzilla thread and check out the improvements we are making.
  14. Just a small correction. The tach signal is sent over the CCD Network to the PCM which controls the alternator. So if the PCM doesn't see the tach signal from the ECM then it will not apply grounding to the field on the alternator.
  15. Would of been nice to have that warmth down here. I was not anywhere near that warm in Boise when I left today.
  16. I think if I got back into my hypermiling phase again I could easily pass the old 27.2 MPG high mark. Being a daily driver the IAT temperatures are starting to fall being the boost pressure and power created is much cooler. So adding some heat to the intake improved my MPG number on this trip even though I was about 1,100 pounds heavier with the engine for the trip down (Nov. 5) Then spent a day driving in city traffic and then leaving Boise, ID without the load of the engine in the back and continued to gain MPG's on the way home (Nov. 6).
  17. http://imgur.com/r/justrolledintotheshop/7lNo19Q
  18. I've got my trip report after 422 miles. I hauled a Cummins CR engine down to Caldwell, ID. Then went over and spent the weekend with MoparMom. Needless to say I only did a few mild tweaks to the tune with @Me78569 help. Then added my winter fronts being the winter cold is setting in. When I left it was only 19-21*F in New Meadows, ID. Mild 50-55*F in Boise, ID. The winter front bumped my IAT temps up to 100-120 range back in my optimal area. As for the boost I'm never above 10 PSI unless climbing a grade. Even at 80 MPH it floats 8-10 PSI and about 700-750*F EGT's. Then at 65 MPH is more like 2-3 PSI and 550-600*F EGT's. Net results of this.... Trip across I84... Take note of the speed, Instant MPG and Total MPG. Back to US95 heading north. Then when I parked in the driveway...
  19. After a full day of driving in Boise traffic stop and go I've managed to add another 0.1MPG making it now 21.8 MPG on this tank. So city driving is not pulling my numbers down at all.
  20. 400 bar is too high. That is 5801 PSI. it should be 310 bar or 4498 PSI.
  21. No joke. NOAA has a hard time just recording temperature for the last 50 years or so in Idaho let alone for millions of years. I would have to say that is mostly scientific theory not scienctific facts. Just my opinion.
  22. I've got nearly 150k on my NAPA bearings now and they are not Timken bearings. Food is for thought.
  23. Here is a tidbit today. I rolled into New Meadows transmission temperature never rose off 100*F. Had to stop by a friend's place to check on some stuff. Even at 19*F the transmission temperature rose to 130*F. Ok. So I took back of heading south. I thought to test this theory I could roll down a grade to cool the exhaust off good the stop and see. The exhaust was cooled way down no real heat. Transmission was at 100*F when I stopped and shut down. Walked the dog for few minutes. Bam! Back to 130*F. So this shows the stock transmission has heat near the gears but the case cools just fine. Being the sensor is high and close to the gears I can see the heat after a short stop with the engine off. Also this shows that the oil doesn't flow or circulate as much as we thought. This is very repeatable.
  24. I just made a trip down to Boise Idaho hauling a Cummins engine. Made 21.7 MPG. My trip started out with temperatures at 19 to 21*F. Still did good, timing floating 19 to 20*. Still running strictly speed limit even 80 MPH on I84. No complaints here.
