06 Dodge stuck in a field...
@TazOnly 17 one ton hay bails on the trailer and one soft muddy field Here is even a picture of my little trailer...
1998.5 UP Speedo calibration and service manual tire size selection confusion?
(Graciously bows) Thank you sir!
You can do it. It's mathed out from the MAP sensor. Then using offset percentage to correct. The ECM does not have GPH flow rates. Put me on your list...
Now the other bug you CAN'T resolve is the GPH flow rate given by the ECM for MPG will be majorly off when you add a tuner and injectors. No way to correct that offset. Like my truck its off by 14.5% with +50HP injectors and the Quadzilla so on a stock overhead I would show 32-35 MPG.
Be aware that tire size on the door label 99% do not match what the truck came with. My 1996 Dodge 1500 came with 235/85 R16 tires and the door label states 225/85 R16. Then my 2002 Dodge Ram 2500 came with 265/75 R16 tires but states on the sticker that its 245/75 R16. You'll have to get a build sheet from the dealer to find out what the truck came with.
Quadzilla V2 Custom Tunes
Here is my current empty truck tune for +50HP injectors. Just a light gray haze for WOT runs. I'm using my exponential curve now. Starting at 100, with a growth of 1.3% http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm Power Levels: 7 Fuel Load timing: 2 Low PSI Timing Reduct: 3 Timing Reduct Scaling: 100 Light Throttle Timing Adv:2 Light Throttle Timing Load Limit: 30 Timing vs rpm 1500: 16 2000: 18 2500: 23 3000: 25 Timing Max: 26 Pump Stretch: 1400 TPS Pump max: 100 TPS Pump Min 5 Minimum Pump Tap Fueling Percentage:0 Pump Low Boost Scale PSI: 10 Boost Scaling: 40 PSI RPM Limit: 3200 Power Reduction: 5% 0 PSI %: 100 1 PSI %: 101 2 PSI %: 102 3 PSI %: 103 4 PSI %: 105 5 PSI %: 106 6 PSI %: 108 7 PSI %: 109 8 PSI %: 110 9 PSI %: 112 10 PSI %: 113 11 PSI %: 115 12 PSI %: 116 13 PSI %: 118 14 PSI %: 119 15 PSI %: 121 16 PSI %: 122 18 PSI %: 126 20 PSI %: 129 22 PSI %: 132 24 PSI %: 136 26 PSI %: 139 28 PSI %: 143 30 PSI %: 147
Fellow Wood Burners
Pecker wood tree?
Fan Clutch
This is because the oil has settle in the bottom and requires RPM to pump it back into the hub. Mine is the same way after starting it roams for the first few seconds of leaving the driveway but once its unlocked it just like my video above. I've done this hundreds of times for people. I'll start it rev it to 1,500 to 1,800 RPM for about 10 seconds and bring it back to idle. Then I can grab a rubber hose and stop the blades every time. That first few seconds is the oil being pumped back into the hub of the fan.
Important MessageTo all forum Members
Really???
Quadzilla Adrenaline V2 Testing
No. Can't be that is a regulated 5V signal from the ECM. The only thing I can think off is crappy offset of the MAP sensor values or possibly a bad or weak ground lead on the MAP sensor. Which this is a internal floating ground of the ECM. The master ground (or real ground) of the ECM is the passenger side battery terminal.
Issue that has everyone stumped!! Rough Running truck
Skip at idle is typically more of injector issue than a VP44 issue. This will show more as the engine is hot than cold. I would say pull the injector and have them pop tested.
Running Delo oil in older flat tappet Gas Hot rod /classic
I ran 15w-40 in my 1983 Goldwing for years no problems.
Fan Clutch
It shouldn't spin cold. The oil should be settle to the bottom and thick and it should be extremely stiff. Once started and driving a short distance the oil will spin back to the hub unlocking. As for my clutch...
The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
Correct. Canceling high idle... 1. Speed >0 MPH 2. Coolant Temperature >170*F 3. APPS Sensor Off Idle State 4. Brake pedal pressed To reset completely you need to shut down completely and count to 10.
MoparMom's white LG G4 phone...
I had a nice 4 hour conversation with MoparMom on the phone for Thanksgiving. Now I've done something else for MoparMom. I just bought a new LG G4 phone and going to set up my previous phone for MoparMom so she can stay in touch easier with me. All I got to do is get a new SIM's card from TracFone and get her new phone number.
What are the best headlight packages?
100w x 2 = 200w = 14.4 x 13.88 amps. I know the headlight fuses are 15 amp.
Opps I missed it...
@IBMobile are you by chance using relays with your lights or just directly plugging 100w bulbs in?
Fuel Temperature
So why is the Quad designed for 2050*F??? Spencer needs to reconsider that idea...
AC Ripple Test
AC ripple test.
Fuel Temperature
Yes. The fuel heater will automatically attempt to heat the fuel to 65-75*F for normal operation.
Cooling the VP44
Remove your cooler from your VP44. As long as the VP44 allowed to cool by fuel flow it fine.Use fans and coolers you taking the risk of the run backwards problem. Simply the colder the fuel the more risk of starting backwards because the VP44 automatically advances timing for colder fuel so if the fuel.
Cooling the VP44
I've seen a few cases here locally where it's happen even with an older 2 1/2 ton military trucks. Where the exhaust burned up the air filter and ran like crap. Also all forward gears are reverse and reverse gear is forward. The gent that did it was wondering why he could not find forward gear.
