What are the best LED headlight bulbs and housing options?
Like my fog lights (100w aircraft light) Day time I find my hi beam bulbs are complete froze over with ice. Just got to flip on the high for few seconds and the ice is gone. Day time high temps with minus numbers takes longer to shed the ice.
How's everyone doing?
Back to a normal winter. This is Dec 2016 times just yesterday. We barely made a high of -16*F here.
Flushing the coolant system and removing rust.
Since rust is heavier that water you'll never see the rust in the neck of the radiator. Most of the rigs I've drained always comes out rusty colored in the last gallon of coolant. So run your span of miles you picked and the drain it out and see if the color holds true with the last gallon. This applies to both diesel and gas engines.
Pets and bitter cold
Sad to say out here the is only one hardware store and provides only 1 brand of ice melter salt. The only way I can get that stuff is drive the 4.5 hours to Boise or 3.5 hours to Ontario, OR to get such a thing.
Quadzilla Adrenaline V2 Testing
My last run the best I could do was about 18-19 MPG it's pulling the MPG down hard when you start dropping IAT temp. The only solution I've got is to cut the total timing back even more like 1-2* degrees total. Problem is the ECM is programmed for 40-45 cetane and cranking the timing up. Here the cetane is like 50-53 so the timing is already in the fuel and not required. Bad part is the ECM and Quadzilla can't see fuel changes.
I just let him out a bit ago and he ran out fast across the walkway and got to the snow didn't bother him. Then he circled back around through the snow to hop up on the last step to get to the porch. No problems. The time before that he was lifting paws again because he just walked up the walkway in the salt path. Diesel been a house dog for all these years thin skins and light furred as well. It is what it is...
06 Cummins dead pedal
Yes sir. The APPS sensor and pedal are one piece design. 2 bolts and 1 plug you are done. So far I'm having trouble sourcing out this APPS sensor. I'm going to make phone calls to vendors I know and see who call point me in the right direction. I do have the option of the RockAuto yet but unknown where it's coming from and how long to get here. NAPA is quoting better than 7 days because the closest one is in Virgina. Not going to work for @Taz. Here is another one... https://www.carid.com/standard/accelerator-pedal-sensor-mpn-aps312.html
I've learn something today. With temperatures at about -16*F in New Meadows, Idaho at about 12-1pm. I need to drop more timing. The manifold temp drops to barely 45-50*F and the timing is getting way to aggressive and killing the MPG number. I could just flip the MPG fooler on but I'm attempting to work solely with the Quadzilla Adrenaline and figure out how to keep optimal MPG numbers.
I think I got it figured out. What I think is happening is that I salted the walkway and when Diesel bails off the steps into the snow he's fine. Then he runs through the yard no problem but if he walks back up that salted walkway his paws must start burning bad because starts limping and lifting his rear paws. I've checked the paw pads and there is no cuts that I've seen or open wounds. That's the only idea I've got now.
Not even close... This is what it looks like...
All I know that is when it dead pedals there is nothing just like mine would. There is no codes for the APPS sensor at all. Seems to be weather-related the colder the cab becomes the worse the problem is. I just check at the local NAPA and its 236 dollars for one and at least week out from Virginia. So now I'm looking for other vendors or resources to getting a new sensor for Taz truck. I see RockAuto has one for 137 which isn't bad. I was hoping for other vendors as well to crunch numbers a bit more. Rather weird the way the APPS is behaving and no codes to point it out. I've read several forum post where this is common but most of the time they report codes with it. So the only common ground is the dead pedal and cold weather.
Transmission noise
That is not a electrical issue.That is a mechanical issue. Return the electrical back to stock configuration. Remove all these mods and test the alternator if you are going to chase AC noise issues. Again this is a mechanical issue. You might want to drop the pan look for debris. Another thing it could be is the flexplate is cracked or failing.
First off I can say there is no error codes to the APPS sensor. There is a wastegate error (IIRC) P0234. Still there is a dead pedal issue but no codes. I want to verify that I should replace the APPS sensor or not first. When it does dead pedal the exhaust will set and and no throttle. @Taz said yesterday he had no exhaust brake at all and dead pedal 4 times in 15 miles. Any help?
It's only +16*F here at my place right now. I just let Diesel out to take a leak. I've never seen him do this before. He was wondering around in the snow here in the yard. You can see him not walking so good. He started limping back to the porch. The when he got there he was holding his rear paws up one at a time, like the bitter cold was burning like it would if you had your hands in the without gloves. Felt sorry for him I pick him up and carried him in the last few feet inside the house. Once stood on the warm stone in the house he was all good again. So... What do you guys do for your pets in the bitter cold? I know he's got to go back out again later but I know he's not liking the idea. Ideas, suggestions?
Wood Burners
+9*F and 81% humidty here at the house. Looking at the highway cameras... -5*F in McCall, ID. -12*F in New Meadows, ID.
Birthday present came...
I'm not worried typically I do my firewood in April or May in the early spring. I try to never haul wood at the end of the year it can't cure the firewood out hauling it home in October. Again not an issue.
Ban diesel vehicles by 2025
I was never in the military. I never had training by my parents. I was taught by a good friend on the weekends and went out into the desert of California for target practice. I live near the worse neighborhoods that gang violence was common place and shootings. I could tell all kinds of stories of gang violence and shoot and weapons I've seen through my teenage years.
I might resemble that comment... Nerdy kid with braces. Yes, I was a light weight (in jr. high I weighed 118 pounds), thin as a rail, wearing braces and shooting .22 rifles. I would have to say your comment is not valid...
Mine is not commercial use. I'm not for hire so I'm not going to even worry about. I'm under the weigh limit for requirement so I'm not going to worry. As for use I'm out in the middle of nowhere. I'm not like the other yeah whos that fly their drones in a city and crash them into building, other vehicles and people. The most I can do is lose my drone to a tree. I look forward to firewood season in the spring. I'll be able to drive to an area and the just fly the drone to check for dead trees I can harvest. Again its not like I'm going to be flying thousand feet in the air, or beyond my line of eye sight.
No power!?!
Excessive boost will cause limp mode. If you boost is exceeding 19-20 PSI it will trip limp mode without tripping a code. If you do manage to pull hard enough it will trip P0234. I've ran several times with my boost elbow and no boost fooler and it just falls on its face without tripping a code. It relies on the limp mode more so. I would inspect the turbo wastegate. Cleaning the MAP sensor will not fix anything either.
OBDLink
Under Settings go to User-Defined PID's. This will allow you to set your own custom PIDs and custom math for them as well.
No WTS light, Unable to start in 2nd.
99% of all electronic problems come from excessive AC noise from the alternator. Way too many people follow bad information on relocating or adding ground wires, adding noise filters, or just modify the wiring system. This all creates a masking effect which makes it harder to detect the AC noise problem but also allows the AC noise to do more damage.
https://www.amazon.com/gp/product/B00SH3MU0U/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 UDI U818A WiFi FPV RC Quadcopter Drone with HD Camera RTF - VR Headset Compatible - Headless Mode, Low Voltage Alarm, Gravity Induction - Includes BONUS BATTERY + Power Bank (Quadruples Flying Time) - FAA Registration NOT Required
No license required for mine... Under the weight limit.
Lund Roll Up Tonneau Cover
Just a power washer and water. That all I do for the 96 Tonneau cover. The vinyl looks dirty all the time but is actually fair clean.
