  1. Hey @Quadzilla Power take a look at the OBDLink App and how it works it will give you a clue to my ideas.
  2. Excessive timing advancement because of cold fuel plus high fuel pressure. Goo combo for starting backwards typically more so with a hot engine and cold fuel temps.
  3. I can try my old 02 MAP sensor.
  4. Mine is the same reporting 1-2 PSI at idle.
  5. I've ran into a guy that had fans on his VP44 and managed to create a condition where he could start his engine backwards from the excessive cooling of the fuel, which could over advanced the timing it would literally start the engine and run backwards. Not a good thing for the engine to do. So the whole panic of keeping the PSG cooled is no longer an issue as long as you keep 14-20 PSI of fuel pressure at all time and some sort of fuel lubricant (<520 HFRR). Yes he does...
  6. Quadzilla needs a data logger like the OBDlink App has. You don't have to import anything to excel or anything its all self-contained. The problem I've got is the limited time it logs data and the requirement to email myself where I don't have any cell service so I rather not bother fighting to get apps to export from one to another just to see logged data. If the data was saved directly to a file period I would be tickled.
  7. Which version of switch are you running? With the circuit board? Which cable are you running the white cable or the black cable?
  8. I ran around in a 1972 Dodge Power Wagon 360 CID with a 4 speed 4 wheel drive for better than 10 years. Traded it in on the 2002 I've got today.
  9. I've already got that problem with the Jayco RV hitch up and loaded.
  10. Just south of Riggins by 15 miles. Come on down...
  11. Have to... If you have people stomping around crushing down all the new fiberglass blown in then it worthless. I've already talked to "OuR Factor" and he told me the same thing to get the heat pump installed first then blow the fiberglass in so it not disturbed by people crawling around the attic space. So I'm just doing it the right way...
  12. Good view of Northern Idaho (Pollouse if I'm not mistaken).
  13. Shut down doesn't matter. Like I can lay my laptop in my pickup turned off at 160*F without harm. Now pull it out after soaking in the heat turn it on and it will work just fine. Most all electronic devices can withstand storage temperatures well above the operational temperatures. Ask yourself why does the ECM do just fine bolted to the block without any cooling system at all? As for the VP44 the biggest factor is to have at least 14 PSI of fuel pressure. Just after startup the fuel will pull the VP44 temp down rapidly and back to operational range. Like My VP44 is over 12 years old and over 200k miles and heading to 300k miles. I have summer heat of 117*F like 2 year ago and no ill effects to operation of the VP44. The other factor is AC noise levels of the alternator. The higher the AC noise levels the more heat is produced by the VP44 PSG. So if you have good clean power from the alternator (10 to 30mV AC) then you should be creating much heat from the VP44 PSG unit. So the fuel system should be able to cool it rather easy.
  14. First night. The bedrooms were set at 70*F in the master bedroom and 68*F in my bedroom. Very comfortable to sleep last night. I left the kitchen unit set to 72*F where the living room is a bit cooler this morning where it fell to 67*F during the night.
  15. I've got 3 rocker switches in my overhead console where the trip computer would of been.
  16. No. Typically the oil will be thick in the clutch so it will be stiff till the RPMs spin the oil outwards. So the try before you buy won't work.
  17. Nothing... Just factory undercoating.
  18. After a bit of tweaking and learning, I got the kitchen set for 72*F and it holding 71*F over at my computers. Very comfy. The bedrooms are set to 70*F and modules are barely blowing air but nice and warm back there. Yea it $13k for the system but when you consider @MoparMom health and medical problems she doesn't need to be worrying about running up and down the stairs to feed a wood stove. We both agreed that it was time to invest in upgrading the heating and A/C in the house. Now if I've gotta leave to take her to Boise for check ups during the winter there is no worry about freezing pipes or coming home to ice cold house like I've done the last 3 trips back from Boise. I would get home to house at about 48-52*F and would take better than 4-5 hours to heat back up to even 68-72*F that was strictly only wood heat. The next project will be in upgrading the insulation in the attic which is barely R19-R22 in depth. So hang on to your seat it going to get wild around here.
  19. Just went New Meadows for dinner tonight. Left the heat set for 75 and we'll see how it does when I get home. We started at 67 So let's see.
  20. Oh.... I thought your talking old school high idle my bad...
  21. Here you go... http://www.homedepot.com/p/ZEP-128-oz-Industrial-Purple-Degreaser-ZU0856128/100047759
  22. ??? There is only a 1 knob...
  23. Up and running. Test driving the system now. Very impressive. Louver on discharge auto swings up and down spreading the heat. The fan is auto speed so it automatically tapers back as it reaches set temperature. Even with a turbo mode to build heat or cooling quickly.
  24. Total Cost... $13,180.00
