  1. Best off going direct plumbed to the gauge. Very few people have gotten an isolator to work right and accurately.
  2. The sensor is the on in the manifold that the live data tool will see. The one in the airbox as far as I know is not readable with a OBDII live data tool.
  3. Is a IAT sensor is off it won't trip a code because it failed within normal operating range. This why we need the live data from the ECM at key On then we can see what the ECM is doing.
  4. Need to get a live data tool from some one. You could buy a OBDLink for cheap... http://www.obdlink.com/lxbt/ Then you'll be able to read live data then. This is my current layout...
  5. Again, we need to know what the IAT temperature is showing when you turn the key on. Like I've got either ScanGauge II, OBDLink LX, or Quadzilla Adrenaline that will display the IAT temperature. This is the key factor in how long grid heaters fires or if the don't fire at all. I typically compare against the engine coolant sensor for accuracy. So if you IAT temperature3 is showing 65*F at key on while it actually colder then it not going to fire the grid heater at all. It does just the bulb check and that's it.
  6. My first thought is the BATT +12V lead on the Quadzilla Adrenaline isn't hooked up.
  7. What is your measured IAT temperature at the time you turn the ignition key on? This is critical to know. You might of just replaced a IAT sensor for nothing...
  8. Here you go gang. I found an easy way to build fuel maps for the Quadzilla. http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm So I started out by setting my "Enter initial value (x0)" to 100 which is where I want my starting point of my fuel map. I set my "Enter growth/decay rate (r)" to 1.3% then enter 30 to "Enter time (t)" to see when the max value hit. Then start at 0 and work your way up plugging the numbers into Quadzilla. Makes a nice clean curve for the fuel map. If you want it steeper you can increase growth rate 0.1 or 0.2 higher. Works good. Now I'm just a gray haze in lvl 3 or lvl 6. So I've got it nailed down just about right for my truck. This calculator makes a nice exponential curve for the fuel map. Here is what I've got now. 101 102 103 105 106 108 109 110 112 113 115 116 118 119 121 122 126 129 132 136 139 143 147
  9. You might look in the download area... I'm not sure what we've got anymore for books...
  10. Like myself I've got rather smallish injectors where I can ramp up aggressively and still be rather smokeless running. Now like @TFaoro he's got to ramp up slow and be more careful about settings because of the larger injectors. Name of the game is to feed as much fuel as possible across the full fuel and boost map without smoking excessively. When you get smoke then your basically flooding the cylinder without enough boost pressure to ignite the fuel completely. I'm still attempting to get better handle on all the setting and relearning with every flash upgrade. Like with my set up I enjoy the idea that the injectors are small and need to use the Quadzilla Adrenaline to push beyond the stock rates. This makes for good control yet and MPG values. I'm still waiting for @Me78569 and @TFaoro to catch me in the MPG game. The horse power game has already been played out we all know how far these trucks will go with HP/TQ but has anyone play the efficiency game to 30 MPG? Not yet on the 24 valved trucks. I'm going to attempt to beat my previous 27.2 MPG by any amount.
  11. Personally, when @hex0rz told me that DAP sent the new nozzle and pintle for him to install I knew there was going to be issues. It always mandatory to re-pop test and flow match when you change nozzles. How is the owner to know that the nozzle and pintle are exactly the same as the other 5 injectors for pop pressure and flow rates? They don't. I would of boxed up the injectors and had sent them back to have the new nozzle installed and all 6 retested and flow matched.
  12. Stock tire size is 265/75 R16.
  13. 235mm = 9.25 265mm = 10.43 10.43 - 9.25 = 1.18 inch difference. Math doesn't lie... 235mm x 85% = 199.75mm 265mm x 75% = 198.75mm 199.75 -198.75 = 1.00mm difference in height... Math doesn't lie...
  14. There is very little difference is size. Width 1.1" inches narrow, Height it's 0.04" taller. But the key feature is 235's are 23-25 pounds lighter! Only 1 rev/mile difference. Way less rotational mass.
  15. Here go read over the diagnostics for the code...
  16. Just a light puff just as the wire tap hits then clears right up. I might bump the wire tap back to 10 PSI. Pulls like a mule getting on the interstate. Gotta be careful it's been known to break the tires loose getting to the top end of 3rd gear.
  17. Mopar1973Man posted an Cummins article in Fuel
    Here you go gang. This is the Bosch VP44 injection pump rotor disassembled. All I've done is taken the snap ring off the infamous diaphragm and pried it out. Not much inside the rotor body. Here is the rotor shaft, injection pump, fuel pin and solenoid. Here is all the parts disassembled out of the rotor head.
  18. Just to kill off the whole Bosch VP44 diaphragm failures and voiding of warranties. This diaphragm is out of a Revision 027 pump. As you'll see it's a harden steel plate with plastic on the inside holding a o-ring seal. Here is the inside of the diaphragm and the o-ring seal. This is the top cover of the diaphragm. This steel plate is harden steel and held in place with a snap ring. Looking through the hole and you can see the plastic and steel sandwich.
  19. Correction. It retards timing. The ECM programming is excessively advanced timing in with cold coolant and IAT temps. Like @Me78569 and myself found that it can retard roughly 3-4* on the cold start. As it warms up it reverts to the normal timing seemlessly. Even if you leave MPG fooler on it will still work just fine when fully warmed up. This is why the rattle seems to be reduced when the fooler is turned on. Just remember colder the IAT the more timing. The warm the IAT the less timing. Reason why is ECM assumes that the air, fuel and everything is cold so it adds timing to give better chances to ignite. The only factor the ECM can't see is the fuel chemistry so if the cetane is already high then the advanced timing doesn't help MPG's at all. It actually hurts the MPG number.
  20. Sound like a shaft bearing going bad. Have you bothered to check the fluid in the transmission since it started happening? Check for glitter in the oil.
  21. Most likely the pedal bushing are wore out. There is a member here that posted up how he changed his.
  22. I used to be a big Artic Cat fan. When all my sled friends left the area I gave away my sled to a friend and never looked back. It needed work being the oil pump cable broke I rode quite a distance without knowing that it happened.
  23. Just at the bottom of your screen drag upwards and the many different data icon are present. Just drag them to a placement that you want. As for reading errors I've not seen it either. Turbo timer I've got set for 300*F but if I want to leave it idling I just set the 6 cylinder high idle and it floats just above the 300*F and won't shut down. That way you don't have to keep changing the tune. Daily driver I use my levle 6 or MAX tune. As for level 3 it doesn't use the power reduction setting. That is Level 1. I've got mine set to 5% so if I'm in Boise I set my tune to level 1 and the truck only drives 5 MPH. It make it a complete turd and I don't think anyone will steal it then. As for my MPG tune again I use Level 6 and got my timing adjusted not just 19-20* but for what the truck requires. The 19-20* is a good starting place but there is way to many variables that are involved to just say 19-20* is optimal. Larger injectors might need this kind of timing but like myself with smaller injectors I'm use a base timing of only 6*.
  24. Gotta have that feature...
  25. Take a look at my post above and my settings that's what I was running for 20+ MPG at 80 MPH.
