  1. Design fault. When Ed Grafton @Yankneck696 created those everything was soldered to the legs of the switch in return placed all the cable weight on the legs as well causing the switch contacts to pull out of the base causing P codes to start showing up. The problem is you would have unsolder everything replace the switch then resolder everything back on and end up back here again when it fails. This why the whole design was changed over to circuit board design this reduced the strain on the switch and made it serviceable. If the switch fails at this point it's easy to unsolder the damaged switch and solder in a new switch.
  2. Very nicely done job there. Just increased the value of your truck... I've seen a bunch of trucks with a broken dash sure makes them look cheap and worthless. Just changing out that broken plastic for a fresh dash looks really good!
  3. Actually something went wrong this time. @Me78569 his last two tunes are acting goofy. So I'm going to back down to the last working tune. Depending on your phone screen size the cog is very tiny, hard to hit with your finger tip, in the upper left and very dim hard to even notice it. The 3 dot menu will not even show up. Now on my Azpen A729 Tablet the cog is good sized and easy to see, easy to hit with your finger tip and the 3 dot menu button is also very visible. Here is a screenshot of the LG 4GLTE phone I'm using.
  4. Like my truck is also 2002 as well like @JAG1 and I cleared over 150k miles with OEM ball joint on all this rough country and dirt road travels including trailer towing. I'm on my way to 300k miles now and I'm pretty sure my cheapo ball joints (not Moog) will make it to 300k they are still tight yet.
  5. The security forum is in place for all those wish to join. First off its only visible for members that have donated. So now if you click on the forum it will error out showing the process of joining the forum. Be aware your phone number must be accurate because a staff member will be calling that number to verify the member by phone.
  6. Like I've got my little 1996 Dodge Ram 1500 with a 46RE that tows a 7,000 pound trailer without a thought either with a 46RE transmission. Quite impressive to see the little truck tugging a fully loaded trailer full of firewood down the highway. So you don't have to swap if you don't want to. Just you have to consider upgrading the guts a bit. As for @Dynamic you don't have to go for a full rebuild you could pull the torque converter and valve body and swap new updated ones in. You could mail your valve body to @Dynamic he'll modify your valve body and mail it back.
  7. Good point. Automatics are not exactly a strong transmission in stock form. There is a solution to that Dynamic is quite the transmission builder too.
  8. That's why I using smaller injectors and allowing the electronics to make up the short comings. This gives me a better range of control over my fuel. Where as large injectors your already big fuel and stack a module on your just getting bigger yet. This speaking more so Edge Products. Now seeing the Quadzilla there is hope for the large injectors because of the @Me78569 "The Wizard" of Quadzilla tuning. There is ways of pulling down below stock rate to keeping things happy with the truck where Edge Products everything is above stock rate.
  9. Now I can do the same thing with @Mopars Mistress turn it down to level 2 or 3 and let her take the truck... LOL. I'm also very happy with the turbo cool down timer that is really handy. Wiring is so darn simple and how it holds the ignition power on till it cool and then disconnect.
  10. That what this next flash is jumping back up to 12 PSI to clean up the wire tap transition.
  11. Not exactly something I would brag about... But it true your living proof of that...
  12. @IBMobile place is anywhere he parks his RV.
  13. Yes, bigger injectors need a bigger turbo. Bigger the turbo more smoke and lag. Yes, he is running 100 HP injectors but running a custom fitted VGT turbo with his own home built controller. Way different animal compared to a large fixed geometry turbo. The only thing I could think of to try is custom fit a HE351 turbo in and then it should support the 100 HP injectors. Still in all... It's all based on customizing beyond just bolt in turbos.
  14. Most likely why @Me78569 has to bump my tune to 12 PSI on the wire tap because I watch the boost gauge not the phone display. I know I need 10 PSI for clean run but if the MAP sensor is off then that why I still hold that small puff smoke on my wire tap levels.
  15. I've alway knew about the inaccuracy between MAP sensor and boost gauge. Just know that I've seen it I can clue other that are solo to a module like Edge Juice or Quadzilla Adrenaline that the gauge is not accurate for true boost pressure numbers. Not saying that Edge or Quadzilla are to blame but the MAP sensor itself being it's getting all the data from the MAP sensor for boost fooling.
  16. Kind of like myself I'd recommend "Vulcan Performance" all day long. Personally I wouldn't go much over 50-75 HP sized injectors if your towing. You can fit those against a HX35W turbo fairly safely without much issues.
  17. This comes from the 12V engine that was common for the overflow valve to become damaged and create issues. In the 24V or VP44 fuel system they are super rare to fail ever. What is you fuel pressure like? If the lift pump is no running properly or creating enough pressure then it can create these issues.
  18. Hex0rz showed up at my house to trade out his +75 HP injectors for my stockers. This allowed him to keep going on his trip. For some reason his +75HP injectors are growing oil so there is a injector issue. So I cleaned my stock injectors up and installed them for him. Hex0rz and Mrs Hex0rz wait for me to do the work. So of course the engine was hot and I plunged right in. Managed to swap all 6 injectors in 1.5 hours.
  19. Even I've ran a RV275's injectors for about a year with the Edge Comp on 5x3 and the upgraded to +50HP Vulcan Performance injectors which are flow matched and pop tested before being shipped. Now with the Edge Comp being replaced by the Quadzilla different ball game now. Very clean running, more power, EGT's seems to stay in check for the most part running @Me78569 custom tune.
  20. Yes. There is no controls other wise. @Me78569 Started me with a custom tune right out of the box. So I've never seen the factory Quadzilla tune as of yet. Power wise quite surprising how much pull this beast has now compared to the dirty tune of Edge Comp. I'm now working to understand the optimal driving method to gain the most of everything. I can tell you there is an audible difference timing wise between the Quadzilla and Edge Comp. Edge Comp was very aggressive at cold startup in cold weather. Quadzilla so far is fairly mild in cold weather startup. @Me78569 Has another custom flash for me to try out tweaking even more... Try to get that done today.
  21. Be aware the direction your sliding on the hinge. The trick I do is loosen just enough you can use a rubber hammer to tap the door in the direction you want without it falling on it own. I typically remove the striker pin so you test close the door to get the hinge lined up. Then once it shuts right then you can reinstall the striker pin and adjust for center of the notch and inward enough to pull the door closed against the seal without slamming. Remember the adjustment will move in/out and up/down as well in the closed position. Yeah, I've worked in a body shop for about 2 years and I've got basic understanding of body work.
  22. Doors... When doing doors you have to readjust the striker pin/loop. Also if the hinge bushing are shot that's why they are sagging. Open the door and lift from the outter edge. Does the hinge move at the pin/pivor point? If so you need a bushing pin kit for the hinges.
  23. The only thing I did see that is surprising is the boost gauge (Quadzilla) vs boost gauge (ISSPro EV2) there is a 5 PSI gap. So Quadzilla shows 35 PSI then ISSPro is only showing 30 PSI. To confirm this I set the boost limit on the Quadzilla so I could pound the throttle and watch both hit a limit and hang and see the difference. I would have to say the engine sensor is inaccurate than the ISSPro EV2.
  24. Yes. Level 3 is completely clean. Quad on level 4 vs. Edge Comp on 5x3. Even @Mopars Mistress agrees there is more power now than before... Here soon I've got to drag a trailer. So we'll see how the tune does. If you want go ahead build the new tune I'll gladly flash it before pulling the trailer.
  25. Level 6 seems to blow a cloud but nowhere near as dense as the Edge Comp. Yeah, just very mild short burst cloud. Actually, I was at full coolant temperature before starting any recording of the video. As for the Edge and the First Quadzilla videos those are running up hill, where the 2 Quadzilla video is running down hill the percent of grade is very mild like 1% or so.
