  1. Just trying the 90% tune of @Me78569 set my cruise control and watch the instant MPG gauge for a few miles. It would produce low teens roughly. Then just set the 0-5 PSI range to 100-105% +1 for each cell. So now do the same thing go out and set the cruise control again and watch for a few miles. Now it dances back and forth through the 30-50 MPG range like it use too. So basically you cannot tune to be smoke free and have MPG at the same time really. Your cruise boost pressure needs to be high in the 100's percent range to get the MPG up.
  2. I can say that setting the CanBus fueling from 0-5 boost pressure at 100% to 105%. Now the MPG is back to the high mark again. What I'm learning is build the cruise boost pressure area for the highest fuel you can without being stupid smoky. I see some smoke under high throttle but clears rather quickly like the old Edge Comp. Started wrapping my mind around the tune and figure that I had to forget the smoke idea completely. First build your cruise boost pressure for good high fuel values, now I've got the timing back up and MPG's are nice and high again.
  3. 1/8" air brake line of any brand name will work. Don't use 1/4" too big and will allow pulses travel farther to the gauge. The 1/8" air brake line will help in snubbing the pulse out some.
  4. Most of all the smoke I see is high rev RPM's above 2,500 with heavy foot. Down low its pretty much smokeless. I drove around Walla Walla a few laps between @Taz place and my RV even with a heavy foot in town it run very strong but the smoke is always high in the RPM band.
  5. Hand math 11.5 MPG the only way I got that much was to run home with the water tank empty. Typically I get 12-13 MPG with the water tank full. So it's still lacking in MPG. Best MPG yet is 14.1 MPG with the RV with full water tank but that was with the Edge Comp. Quad is still lacking. As for the OBDLink I was going to calibrate on this fill but Bluetooth got hung up and crashed the app. Had no where to pull over so that will have to be redone. Still in all the number reported by the OBDLink is close and not far off.
  6. Find out when I get fuel today I'm Lewiston, ID. Gauge vs. Odometer appears better like closer to 90 miles for quarter tank. Quarter tank is 8.75 gallons. Compared to 65 miles in quarter with the previous tune.
  7. Right now just odometer vs fuel gauge need second fill I verify my calibration on the OBDLink.
  8. Here you go... http://www.manta.com/c/mmd0zfg/idaho-diesel-technology-inc
  9. I've got to drag the RV back from Walla Walla, WA. So far roughly watching the fuel gauge and odometer. 17.5 gallons at half and and travelling roughly 170 to 180 miles this is the lowest since I left the Edge Comp.
  10. Lift pump is directly controlled by the ECM so that means there should be an error code possibly like P0230 code. Still need to test the alternator for excessive AC noise issues. Being there is no fuse or relay controlling the lift pump.
  11. Correction. Not acidic, but basic... Still corrosive though. I'll have to agree that most people do not change coolant often enough and end up getting a offset pH number and turns corrosive eating everything in the coolant system. Head gaskets, hoses, rubber seals around the header tanks, etc. All corrosive materials tend to react with other material and change or discard something which typically settles in the bottom of the block and radiator. So this is an example of too late... When you start seeing rust in the coolant you've gone too far. The funny part is most people look at the coolant reservior and see it still clean or even look in the radiator and still looks clean. The problem is the rust is heavier than the coolant so it always sinks to the very bottom of block and radiator where you can never see it. So by the time the coolant is totally discolored it way to late and pH level have been doing damage for long time.
  12. Any error codes present? Might want to plug in OBDII code reader and check for any APPS sensor codes. Then if you got a live data tool plug it in and check for the APPS or TPS signal and see if it dives out in the position as you drive. If so the APPS might be simply wore out in one spot.
  13. P1689 is a communication issue. So there is a few things to check like ohming from end to end of the wiring from the VP44 to the ECM and check and see if there is more than 5 ohm of resistance if so repair the weak connection or wire. Then other is excessive AC noise fouling the communication. If you measure more than 0.1 volts AC on the alternator BATT terminal will running you've got a bad alternator.
  14. Don't bother with that side of testing. Load test during AC measure does do anything for us. If there was a way to produce an exact load for point of reference then the number would have meaning. Since your truck with every thing one might be different to my truck with everything on is going to be different amounts of load. This why in my video I don't ask for everything on value because it has no meaning since there is no way to load up exactly 100 amp load or 150 amp load then it would have meaning. Since there is no load reference (actual amp number) there is no way to make any sense from the loaded value AC volts loaded.
  15. I still wear the burns in my left index finger from those hot injectors. I knew time was short for him so without waiting for the engine to cool I was tearing it apart. I admit in push hard and fast I did forget to tighten the #2 line up. After he calledI started thinking about it and then (D'Oh!) Well I human I do make mistakes when I tired. At least @hex0rz can send his back in for repair and then mail back mine when he's got his fixed or replaced.
  16. Okay... Then you won't mind going over to Walla Walla, WA and installing a clutch in 06 Cummins? I'm sure you really don't wanna...
  17. Hang on guys geez.. I'm trying to do so many things.
  18. No. ECM doesn't generate heat unless you have a bad alternator with excessive AC noise issue other than that it will live a very happy life hanging off the block with 190*F coolant jacket behind it. I have to ask does the WAIT TO START light come on instantly with the key or does it delay? This is a since of Alternator AC noise damage whewre its damaged the memory on the ECM. The very first instruction on the ECm is to check the IAT temp and turn on the WAIT TO START light for either a bulb check (if warm) or actually run the grid heaters (cold). Beyond that if the WAIT TO START is not coming on instantly the ECM is brain dead till the software boots up in the processor. Other than that it will not supply power to the lift pump nor the VP44 so it will just crank and do nothing. This still does not explain your error codes but it might explain the lift pump issues. Yeah I'm studying the ECM and it guts in my spare time researching all the different chips and processors.
  19. First off there is a lift pump power directly by the ECM there is no fuse nor is there a relay for the lift pump. Typically the lift pump is on the side of the block or in the fuel tank for stock configuration. So there is no way to shut down that pump unless the ECM is damaged or the lift pump itself is damaged. As for the fuel pump relay that is the power relay to put power to the PSG on top of the VP44 injection pump. When you pull that relay that power is cut to the VP44 so that computer drops and the engine stops running period. Typically that will trip a P1689 code because of the relay being missing. So at this point you need to deal with the problem with the ASD relay. Go over the troubleshooting and check this out.
  20. Need to deal with the P1389 code first thing... The ASD relay will shut down the truck if the PCM/ECM require it too. APPS sensor might cause a dead pedal but will not affect the ECM ability to idle still.
  21. Just buy the ISSPro EV2 gauge also buy the Relay Kit. Then just program the relay to trigger at the pressure you want. I want to hook into the cluster and hit the CHECK GAGE light and trigger the stock alarm which I think is very possible. http://www.isspro.com/downloads/Instructions/IS208-EV2-Programmable-Relay-Output-Module.pdf
  22. Fuel pump relay is the power supply to the VP44. When you pulled that relay it killed the VP44 power.
  23. Patiently waiting to see the post...
  24. So far on the stock side I've not seen anything worth while that's including either remanufactured or new. There are few members Nations Alternators and Mean Green but expect to pay much more for them.
  25. The one to time I was on a Goldwing motorcycle and seen death wobble start on a 2nd Gen dodge truck... The axle was violently rotating bouncing upward motion so as one side came down the other side was up off the pavement. kind of a cranking motion left to right as the axle hops. As I watch it start and the watch the driver stomp on the brakes and as the speed slows down the axle stops and back to normal driving. After seeing from my vantage angle it was a real eye opener.
