  1. Try an experiment... Reset it back to where ot was roughly and then go for test drive and see what happens.
  2. https://en.wikipedia.org/wiki/Caster_angle https://en.wikipedia.org/wiki/Camber_angle Just some info...
  3. The whole "Death wobble" experience thing. Why is it that people like myself gone nearly 300k miles and never had one problem with it? Stock suspension and the only thing I've got is Rancho shocks with over 100k miles on them. Then all of sudden someone gets "Death Wobble" then always seems like now that person need high dollar shocks (Bilsteins), high dollar suspension upgrade (3rd gen track bar), etc. What I'm trying to figure out what is the magic that has prevented me from ever getting the problem vs. someone like @leathermaneod that now is spending big money on trying to stop the "Death Wobble" problem.
  4. Just to show progress... I've got a bag of parts and @Me78569 has got a bag of parts. So now I'm waiting on the circuit boards to be produced. Sometime around mid October we'll have circuit boards in hand.
  5. I've seen bad brushes, bad rear case where the bearing and shaft jumps, I've seen bad diode the most, but also bad wiring to the field lead can cause issues. I'm trying to source out diode kits and other things for sale here for rebuilding the alternators possibly.
  6. @Taz happens to have double hernias right now just lost the throw out bearing in his truck. I would have to classify him as a best friend I've known him for over 25 years. While he's fighting with the insurance company I'll get a clutch jammed in his truck this weekend. 4 hour drive to get there for me. I use to love going out and walking the woods when I younger and more carefree. Now I've got plenty of responsibilities and can't seem to get much of a day off. When I do I either doing home work (splitting firewood, laundry, etc) or catch some extra sleep. Then I could tell the tale of being held by law efforcement (Fish & Game , County and State police) for 4 hours over one stupid grouse and Dodge Ram Charger. Another reason I'm not too fond of hunting any more. No tickets, nothing illegal but harassed.
  7. That what I love about the Ol' AirDog 150. My draw draw is within 1/16 from the bottom I rarely ever let the tank to drop below 1/4. I never have slosh issues where the pressure gauge drops. Even then the air is purged back off to the tank again not interfering with engine function. The biggest problem here is the install of the drawstraw and how everyone tends to cut them too short.
  8. Most electronics are killed by high AC noise. 0.4 AC volts is a automatic fail... Normal good alternator is 0.01 to 0.03 AC volts. Marginal is 0.05 AC volts. Then a complete fail is 0.1 and above. I've got a 10 year old AirDog 150 still never been an issue. Also have ran a Edge Comp for over 10 year no issues even with a wire tap. ECM and VP44 still going. Battery terminal can play a role in this problem. The lead contact between the cable and the battery post should be clean and bright. As for keeping it that way light coat the terminal with engine oil they will never corrode again. Grease is OK but uo all way get it on your clothes and your arm while working where oil will not. I could tell a story of what happened but it would take to much time to type the entire thing. As for the electronics failure main problem is excessive AC noise. You above test was a FAIL and you cause to way things are frying out. Like My only lost in my truck was ABS computer so far. I've been through 4 alternators now.
  9. If you pulled the fuse and the problem is gone then you still have an bad alternator.
  10. I seen that one in the PM but that was from the first tune. I have no idea what the last one looks like. Shoot you've made like 4 or 5 flash files now.
  11. Since you've got it all figured out you can go to Walla Walla, WA and install a clutch for can't you? I'll take the weekend and go hunting...
  12. Don't have time to just walk the woods... Too much work on the list. Sad but true...
  13. Grouse season starts soon too up here in Idaho. Sad thing is, I've not gone hunting in 10 plus years...
  14. Can't hold speed at all on grades very well with level 3. Feels like I keep the pedal matted way too much to just hold 55 MPH which is still 10 under the speed limit. Lvl 4 has just enough power to hold the grades with cruise set for 60 MPH. Remember this is not the factory tune from Quadzilla this is a Custom tune by @Me78569 so there is bug and issues yet to iron out. Then myself getting use to the changes and the way the truck drive drives now.
  15. I'm not use to the way Quadzilla creates power. I was so used to the Edge Comp where I could run 5x3 and not have a problem typically could hold traction as long as I didn't mat the skinny pedal. Now with the Quadzilla it not even 50% throttle the truck arcs up and the rear tires just spin loose. The first time I thought fluke. Second time I was like really? Third time is like enough of that. Thing is level 3 launches really weak. Level 4 is pretty darn good bit laggy though from what I used to. Level 6 better hang on it going some where. I knoww what I got to switch I do it right now...
  16. That sound really easy... After so many years of riving with thee Edge Comp and how it powers up. Then flip over to Quadzilla and still been learning to control the power and how it reacts with the throttle. This was my first trailer pull on the Quadzilla very different is all I can say right now.
  17. That's good to hear. I just found out running the Quadzilla Adrenaline on level 6 towing the trailer I was very capable from light to light to spin the rear tires out from under the truck. Not just a fluke thing... It happened more than once. Then I had to turn down to Level 4 to stop that from happening.
  18. Talk about so 70's wow....
  19. We discussed this last year but never had the product in time. So it might be a great idea for BoD to discuss and see if we can raise the funds to do such. (Time to head to the BoD forum...)
  20. She gets to keep the money too...
  21. Like I've got mine set to as low shut off point of 300*F. Once I get my ISSPro Pyrometer dealt with that failed I will drill and tap a second hole in the 4-6 position of the manifold and just stack it up. I considered doing the 1-3 position to study the differences but don't think it worth it to have to drill and tap a 3rd hole and plug the 1-3 hole.
  22. At idle time they are going to be close to the same. It only hotter on the back when loaded and climbing hard up a grade. Also if you running the high idle kit you'll want to monitor your 4-6 cylinders on your gauge. 1-3 is dead and cold on 3 CYL mode. Again if your not packing the device to monitor consider the actually gauge for your hot point.
