  1. Basically its the poor quality diodes for most of the problems. Some have bought the nations alternators but they are spendy.
  2. What I'm trying to do is source out the diodes used in the Nations Alternators. Those diodes are rated for much more amperage and should hold up much better.
  3. I'm sure you going to get a nice security alarm for your truck aren't you? Then maybe add a hidden disable switch too?
  4. Ok.. I'll make some time tomorrow in the daylight shot a video of the Quad time now.
  5. Hence the weird method I have to take to gather engine data and trip data.
  6. No injected amount provided. Load value yes is present. Here is my hunt results over the OBDII info...
  7. At least that I know from 98.5 to 02. There is no PID in the OBDII stream for GPH flow. I've not dug into 3rd or 4th gen OBDII yet. Oh dig back on my previous post about the OBDLink and look at the PID hunt I did with the Android terminal search for hidden data. If you look at PID list 5E should be present no on the 98.5 to 02. https://en.wikipedia.org/wiki/OBD-II_PIDs So since its not present on our truck the value is calculated.
  8. Right on that good news to hear you got your truck back.
  9. From what I understand there is a bug in the Android app that prevents it from uploading to the Quadzilla Adrenaline properly. I know the crew for Quadzilla are working on resolving this problem very soon. You could use a cheap tablet to run the app as well. My problem is the tablet is running my OBDLink app and it bluetooth so I use my phone of the Quadzilla app and its bluetooth signal.
  10. Very rare, I might see a slight haze or light puff of smoke on the initial stab of the skinny pedal. Power is good so far. Just seems to have a minor lag seem to be where the CANBus and wiretap cross then Bam!
  11. I've got aluminum brighter or a degreaser that will clean up aluminium wheel rather well chemically. As for the clear coat that would have to be blasted off with some media of some sort and then recoated.
  12. Percent offset with MAP sensor data. Just like OBDLink does same thing. Also, SGII is calculating GPH also from MAP sensor data. Same thing... Yes, I check off and on. So either SGII or OBDLink they both work the same. Very rare I see any need to change unless I've changed something physically on the engine like injectors. I'm not going to tweak for minor offset between pumped and reported of 0.1 difference no need. If you do a lot of idling then the numbers are not correct since neither can track idling flow rates at all. So when I check its basically fill drive to another distant fuel station fill again and check the gallons used against the gallons pumped. Either SGII or OBDLink you end up calculating an offset percent. Adjust accordingly. Nothing fancy. Cummins engines do not report GPH flow rate at all. So This is why on SGII it set to Diesela which tells the ScanGauge to calculate from MAP sensor info. Same thing on the OBDLink you have the option of GPH value (which is zero on Cummins no PID in the ODB data) or MAP sensor input.
  13. Absolutely... Few trucks have crossed the million mile mark... Then several have crossed the 500k mile mark as well...
  14. The weird quark with Edge Products is the timing typically is much greater on the higher levels. So yeah I know every suggesting against running high levels. Typically there is very little gains on lower levels like your finding out. The other factor is what sublevel your also using per main level. This will impact the fueling and timing maps too. After seeing a stock timing map from @AH64ID I would say you could use all the timing you could get. Running higher level but controlling everything by throttle can be safe as long as you watching the EGT's closely and giving some margin for error of the pyrometer. The problem is the lower tunes are less and less timing as you go down in main levels. Know the improvements with Smarty I would look that direction personally for a better tune. Even EFILive is a good solution as well vs. Edge Products.
  15. I just told you that cost you another cold beer from your fridge...
  16. Currently there is a app problem. You should be able to do all the tuning on your phone or tablet and send it back to the module via bluetooth. There is a issue that doesn't exact work correctly. So I know Spencer and gang are hard at work attempting to resolve this bug. So @Me78569 has been building my tunes and then sending them to me to flash back. This is one solution to the problem. Yes, it does work just fine even on Ubuntu 16.04.1 Linux ran in a VirtualBox of Windows 7.
  17. Not to far if you show up in my yard with a failing VP44 to be changed...
  18. So far, the tune is smoke free. Eventually we'll jump into the wire tap tuning and see how far we can stretch it out without smoking. Then take some effort and build a towing tune but that will most likely wait till spring.
  19. Hmmm... I know that you can use Oracle's VirtualBox to load up windows and go that route if need be. I'm not sure of any Mac Software at all. You'll have to ask Spencer @Quadzilla Power or Nick @Me78569 they would know.
  20. Do NOT install any noise filters...
  21. Quality of the injectors are what make for a clean injectors. So... If you do go for the Quadzilla to clean up then you might end up losing some power. I would consider a cleaner injector as well.
  22. Normal. That the timing it adds to the VP44. Gets worse as winter comes on... I like automatics for little cars and such but automatic trucks are not that good for towing at all. Only 4 gears and manuals of 5 and 6 speed flavors. Still kind of dumbfounded about Dodge design of the 5 and 6 speed and gear ratios.
  23. The whole trick we VE is it operates like the ScanGauge. So using the 63% for the stock truck value I was getting really high numbers. So as I added my offset the numbers come down to close to my log values. So more the VE number goes down the more MPG goes up. The more the VE goes up then the more MPG goes down. Fairly simple. Funny part is I assumed the VE number went down the MPG went down so my first try was subtracting from the base number which gave seriously wild high numbers like 50 MPG. So reverse it and now back on the planet earth again.
  24. Didn't really go beating it to death like the previous tune. I cranked it up on level 6 and drove like a white man to the store and back. Past a few cars along the way to the store and never seen any smoke at all. I'm going to play a bit more with this tune before next jump.
