  1. No, you are not bound to name brand synthetics nor high priced lubricants...
  2. Like with my OEM transmission the lower 5th gear had to be replaced because of the fact I wore the hard facing out of the inner hub of the gear where bearing rode. What was shocking was when I got it open up there was no metal in the fluid and just light dust on the magnet. In your case are you get a good sample from inside the transmission and not a junk sample from the fill hole threads? I normally take a windshield fluid bottle (1 gallon) and using a funnel I can drain the entire transmission into the bottle and then look at the fluid condition as a whole. Let is stand over night and let the particular settle then you can see how much carbon fiber was wore off.
  3. Most hard shifting in not lube issues but clutch problems. If the clutch is not fully disengaging then the input shaft is still spinning some what, creating trouble for shift and engaging the syncro rings. This is kind of the reason people change fluids and then still things get worse because the issues was never addressed.
  4. This is where doing the axle weight method will get you the best base number for tire pressures.
  5. Just updated the article last night too...
  6. Tread pattern isn't really an issue. Like Dave said it's the circumference that is the big thing. When its different from left to right on a differential then the spider gears are rolling constantly. With a limited slip it will be putting stress on the clutch I would assume.
  7. Absolutely... I use the same thing on differentials and gear cases as well. No issues...
  8. Ok... Same trailer then... Either way stock rake with no leveling always turns near level towing.
  9. Electronics might not be calibrated to the mechanical part. Timing, fueling, etc. As I've shown the PSG isn't flashed till 3 hours of calibration and all test have passed.
  10. Unmodified suspension, but perfect level for towing. This is why I typically will not suggest any leveling kits because a heavy trailer will automatically pull the nose up even on a stock suspension. So if you using a leveling kit then it always going to be possible to have a squatting truck. Like comparing to @Taz truck to mine I'm 3/4 ton towing 1,000 pounds more without any leveling kit. He's a 1 ton truck and 2" leveling kit and it squatting with light load little utility trailer.
  11. I said the same thing to as a possible cause of the tail squatting. Now you have to remember he's got that heavy flat bed on the bad it much heavier than the stock bed too. I had him scale the truck last spring and it was like 8,9xx or 9,0xx pound truck roughly empty.
  12. Here is his forum page. He goes by @Dynamic... https://mopar1973man.com/forum/173-dynamic-transmissions/
  13. I think your getting scammed... Contact our site transmission guru and talk to him. I really doubt the entire transmission need rebuilt. Got nothing to lose in talking to Jon.
  14. Just for info value. The truck above had my BigTex towing behind it with less than 7k worth of load. The rear axle was sitting on the helper springs. I've only got 35 PSI in the trailer tires. Again that is a one ton Dodge single rear.
  15. Basically its replace what broken in the alternator test it and if it passes all test put it in the for sale pile. So brushes might be wore down to 10% but still passing. Diode is marginally passing still sell it. I'm going to see if I can round up parts to sell on the site store for quality alternator rebuilding.
  16. I'm going to start hunting for a rebuild kits that are more user friendly. LarryB's are fine but the diode pack is very expensive.
  17. Told @Taz about his 2" spacers and 35" tires and to ditch them. Change to 285 at least. It's really making a mess out of towing for him. Headlights in the sky at night, squats with even my small 7k trailer. I'll have to dig up the photo off my phone later I left my phone in my truck. There is a reason why Dodge trucks come with a nose down rake. What's bad is his truck is a 1 ton and horrible stance towing.
  18. First thing quit forcing the truck to climb using cruise control. Next drive by pyrometer. Typically I slow down on grades and gear down climb slower. Typically just pulling my RV I get 11-13 MPG and total gross weight is right at 16,800 to 17,200 pounds. Speed just adds more to the rolling resistance, wind drag, etc. Next thing is run the Edge at the highest level possible. Lower the level the worse the MPG's are going to be. What you looking for is holding the tach around 2,000 to 2,100 RPM's and best climbing gear is the direct ratio (4th of 5 speed) or (5th of 6 speed) or (3rd of a Auto).
  19. Stock trans sensor is in the pan part of the governor pressure sensor.
  20. Still not right... With so many dealers out there selling VP44's with new PSG units. Why would you pay for VP44 with a "used PSG" that is even bit more more in price than a VP44 with "new PSG" for less. Kind of like the same game with suspension parts. Everyone buys Moog parts because of the name not knowing its nothing more that foreign made parts now. What I getting at you have to take it upon yourself to find the source manufacturing and research where its made and how it made any more. Like I know that Diesel Auto Power sell two different rebuilders of injection pump. It's either Midwest Injection or Industrial Injection. I know the Midwest has the lowest price but little bit troublesome when it comes to warranty claims. Where Industrial Injection is a bit more in price but warranty cliams seem to be smoother in handling. (Personal opinion).
  21. If I had access to the 2001 Dodge I just finished this spring I could tell you. I don't remember.
  22. @pepsi71ocean there is running large injectors and has poor boost to fuel control on the current smart. It's been a constant battle of attempting to either clear up smoke or gain the power back. I still say it would be best for him to drop the smarty and got to Edge or Quadzilla with much better boost to fuel control.
  23. I've just done full replacement of the control arms so far. You are going to need to create a jig for beating them out then beat the new bushings in. Best yet, a nice shop press.
  24. Magnet is on the PTO cover on one side. Just pull covers off and wipe it clean. Pretty simple.
