NV4500 and 50 SAE GL-4 Synthetic Trans Fluid
I'm done even trying... No sense in even posting anymore so far I've lost 3 threads to oil related argument I'm done...
Actually you are just hell bent on selling me AMSOil... Sorry No.
Sorry I'll have to agree to disagree. So many way I can alter you "delta" values that I make it look good..
That's the thing AH64ID is quote Delta value which to me is meaningless. To may factors involved to this "Delta" make it even valuable. Like starting temperature of the fluid, length of climb, then at what speed, what gear, how much hp & tq applied to the transmission, etc. All have an impact on the out come of the "Delta". So yeah I could hook up a heavy load climb a short 7% grade and turn a better delta too. I can stop before a grade have picnic and the climb it after it cooled still have wonderful delta. Too many thing to impact the outcome more than just weight... Me78569 like you said not even a comparsion unless everything is equal and side by side. Then we can talk delta.
Time... So let look at it 7 miles of grade at 35 MPH takes 12 minutes (35 MPH in 3rd gear) to climb vs 7.6 minutes (55 MPH in 4th gear). Nearly doubling the time climbing then also with gear reduction adding heat for double amount of time. Then looking at 55 MPH its half the amount of time in 4th gear and 4th is a cooler gear. Again compare side by side it might be different. Again ditch the cooler on his and the exhaust blank I bet it closer together.
AC not quite as cold
There are a few weird animals out there. About the Ford it's with rear evaporator.
Need Towing Trans
After seeing the difference between the 46RE, 47RE and 48RE they are basically the same but with subtle differences. Mostly has to do with amount of clutches in the stack.
Need Towing Trans
I'm very impressed with the transmission work he done on my 46RE on the 1996 Dodge Ram 1500. Pretty aggressive transmission now.
Well we are next year right?
@IBMobile Just a fair warning... I ran across a few weird vehicles with different standards of pressure or functions. Like I found a Honda that operates at as lo side of 15 but cycles automatically by computer control not pressure. I've seen some Ford vans as high as 55-60 PSI getting the full 4 pounds of freon in the system. I will admit for most vehicle A/C work I do follow the chart you provided but still highly suggest using a good manifold setup with both hi and lo pressure gauges is the safest way to go.
Hua?
CHEAP EBAY APPS?????
Here... Look closely there is a break in the contact patches on the outer rings. The short pad is idle position and the long patch is throttling. The right set is the IVS set and then the left is the APPS. This why I love the Timbo's APPS over anything else there is no electronics and just a contact fingers that sweep the range. It's fully mechanical setup. As for P0222 that is both IVS switches are low or in other words shorted to ground at the same time. So the ECM could tell if it was throttling or idling because both switch where selected at the same time.
What would be a better comparsion would be to take two trucks and the only difference would be the fluid one with 50 SAE and the other Castrol Syntorq. No other mods. Then both truck towing the same amount of weight up the same hill together at the same time. Then you'd have some data. There is all kinds of variables not considered in AH64ID comment. Winds, tire differences, loads (weight), tire inflation, etc. All these thing can impact the outcome of the transmission temperature. I bet that if I go back to driving the way I normally do I never reach that 225*F mark again. Just did the 3rd gear climb to prove that reduced ratio gearing and lower road speeds does produce a lot of heat in the transmission and that was the only purpose of the post.
ECM information
I'm sure someone could make new boards if they had a original board to produce from.
ECM information
If you can scrap off the original mylar circuit board some how.
ECM information
You can do solder repairs and part replaces yet it just a surface mounted / solder thing. It the case is made with a crease in it so it folds up during assembly. But now unfold it to access the board and try to refold it again is crazy as you watch the aluminum case start to crack. Then attempting to get water tight seal again is also tough I bet.
Can't use his data to compare. KATOOM is running insulated exhaust pipe. I'm also pretty sure using fast coolers as well. So it not a true apple to apple comparison. I'm truly stock no coolers and no pipe insulation.
ECM information
Spending most of my days running to Riggins, ID doing air conditioning repairs and recharging.
ECM information
Well I got to thank the gent for mentioning that he had a damaged ECM and have him mail it to me for studying. I'm going to invest a bit of effort into playing with it and seeing what I can do with it. Not known what the failure was but I'll play anyways.
APPS low voltage p0122
AC noise test?
ECM information
Like the delayed "Wait To Start" light would be bad memory so replacing the two RAM chips would be easy. As for the failed lift pump you just have to find the MOSFET that controls the lift pump circuit and replace it. Like random revving issues that might be a processor issue. I've got to do some more reading on that Motorola processor and get better understanding of it functions.
VP44 dead with 80 k miles?
I tend to avoid synthetic 2 cycle oil. First off there is no gain to using a more expensive synthetic over petroleum oils. Not to mention synthetic oils do not have PPD (pour point depressants) because of the synthetic oils don't have paraffin waxes. PPD's are good for winter time use small amount of change in pour points for your fuel where synthetics will not.
Manual Trans Conversion - Seeking Advice/Tips/Issues/etc
Reflash will get rid of the codes.
Fuel Pressure Issue
Should be a sintered brass snubber not an orifice. Still need to be at least 5 feet away from the tap point to allow the pulses to fade that make it through the snubber.
ECM information
Has to be water tight. Might be a tough order being the 50 pin plug is soldered to the board and the mylar being glued to the aluminum. Hmmmm...
