  1. No. Just remove the intake cover plate and use a shop vacuum and a tool of some sort to remove the build up. Cummins isn't the only one with this problem even the VW diesel are really bad about plugging up. Most remove the intake manifold and use a propane weed burner to burn the crud out. As for the idling. Some place like California where traffic backs up for miles on the freeways or city street it can't be avoided. Even in Boise, ID there are time traffic is backed up to crawl or stand still. Then there are people that own these vehicles and don't drive more than 2-5 miles tops on city streets and never get to operational temperature. Basically, the whole EGR idea has been a horrid idea even as far back as the 1970's. I had it on my 1973 Dodge Charger and fought with the EGR every smog test. Always passed better without it but had to be operational to pass the test so it would fail if operational. I'm lucky my 1996 Dodge Ram 1500 is a V8 engine WITHOUT an EGR by design. The whole idea is to dump exhaust gases back in the intake air mixture to weaken the ability of the fuel to burn hot because of the CO2 mixed in the air. So this reduces NOx emissions. The dumb part is if the vehicle manufacturer would quit putting this junk on engine and allow the design for efficient engines then less fuel burned means there is less emissions. Dumping CO2 into the intake just means the engine can't produce good power because of lack of oxygen. Then more fuel dumped in to make the same amount of power as an engine without EGR.
  2. Wonderful 6.7L EPA garbage. As you can see the EGR valve has loaded up the intake manifold with soot choking the engine for air or boost pressure. Enuf said...
  3. 108*F outside. 3rd Gear at 35 MPH and 2,200 RPMs 4th gear at 55 MPH at 2,100 RPMs
  4. A bit of information to add... Towing a 8k pound RV in 4th gear (Direct 1:1) up 7 mile 7% grade in 4th is MUCH COOLER than towing the same RV up the same grade in 3rd which actually tripped off my 220*F warning light and rose to 225*F. Where the 4th gear (1:1 direct) transmission temperatures stay about 180-190*F. I'll have to say KATOOM is absolutely correct. Direct 1:1 ratio is the most coolest gear to run.
  5. @Atcmcc Did the gauge start tot function? @Chris O. Could you provide me information for PCM header address and the PID for said fuel gauge information? Plz! I want to add it to the OBDLink App.
  6. True... As for centrifuge filter not exactly cost friendly for most people. Bypass filters are cheaper though...
  7. Same reason I won't touch a washable air filter. Too many things to go wrong during washing of the filter. Typically all washable filters do not filter down to the same level like a paper element. Too many people will accept the poor filtering quality because they can wash it over and over. Even through the engine is wore out faster. Look back at the track record of washable air filters. I've seen my fair share of engine damage here local from washable filters this is both gas and diesel both. I can also see some losing the seal and losing the oil on this after taken it apart several times to wash it. I can see violent oil leaks occurring from re-using o-rings or not latching the housing.
  8. I won't touch it...
  9. Here is a new link... http://www.scottsonline.com/Product_Info.php?PartType=3
  10. Just look towards Swift trucking to see the less qualified drivers that managed to get a CDL.
  11. Weird one to check... WARNING! - Please be careful with the bolt holding this plug it extremely easy to strip out. The big plug in the PDC box has the CCD bus in that plug I wonder if the connection is poor or loose and creating issues.
  12. I tend to agree with @TFaoro and @AH64ID about pyrometer temps. Even my truck with holding 1,200*F up 6-7% grade typically it will hover around 210-215*F once the fan locks up. Recently I do have an odd issue there. The first grade I take on for towing it seen that the fan clutch is getting late to kick in but once it does it fine for the rest of the trip. Just plain weird how it will nearly hit 220*F for the first climb then after that it only needs about 208-210*F and its locked up and the turbo prop is flying low. Just weird. I haven't condemned the fan clutch quite yet.
  13. Till they seat. There is a flat on the bolts so there is no torque per say. You can only tighten to the flat shoulder bottoms out.
  14. Is the odometer still clocking distance?
  15. That was my thought to. Why would Auto PCM and ECM have manual software? Did you swap them?
  16. I don't know why but there is an absolute left and right error of speed sensors. I've had it check few different times. I've replaced the front sensors 3 different times with the same results. I've had my front bearings checked there are still tight and the tire shop also agrees there is nothing wrong with the unit bearings. So that leaves me back to the tone rings and the sensors in the front. Why I don't know but 2 new unit bearings are outside my budget right now.
  17. How the ABS sensors work is that the detect metal then gap then metal again. This creates a sinewave on the speed sensor lead back to the ABS module. The ABS module is capable of counting the cycles per second and turn it into speed numbers. So if the tone wheel has material in-between the teeth with metal (graphite loaded grease) then that gap is seen as filled with metal which now changes the frequency return to the ABS computer so now there is a offset from left to right and if so then the ABS will only allow so much then trigger the lights and disable the ABS. Like mine its enough offset that it pulls to the right when it does work but shortly trips the lights and disables the ABS function. Remember this speed function is compared to all 3 sensors and then used during braking to adjust brake pressures so a speed sensor that is showing slower like my left side does then the right applies more brake power and lighten the left so now you get pull to the right. Another way to see this action of the speed sensors you can take a sensor hook up a AC volt meter to the lead and now lightly tap on a metal surface. As it touches metal and breaks away it creates AC waveform that the meter can see. So the faster you do this the more cycles per second are produced.
  18. Here is the full article on it...
  19. Chrysler Crash Detection This isn't like vehicle crash but data crash. It's built on the same design as ethernet cable networks.
  20. Well here is how it works. The PCM looks to the fuel sender for resistance value for remaining fuel. Then the PCM converts this information into digital message on the CCD bus. Now it up to the Cluster or the Central Timer to receive these messages and convert the data into the information required. So the fuel gauge is stepper motor and told where to place the needle in respect to the digital information. Then the Central Timer tells the overhead computer how much fuel is left and calculates DTE (Distance To Empty) by using existing MPG data. So The weird part is the CCD data is correct because other than that the overhead would be providing false data to you. So that leaves me pointing my finger at the cluster. At least what I can think my way through.
  21. Hmmm... If the overhead is working that means the PCM is working and sending out data of the fuel level. But the cluster check works fine. But only displays for a short time nad the fall to empty again. I'm stumped if there is a module that is partly failed. This really got my head scratching going. Have you checked the interior cab ground in the driver side kick panel? I'll keep thinking on it.
  22. Check the resistance at the PCM plugs to verify the signal is making it to the PCM. Also you might check the plug there at the driver side fender it might be corroded from mud and water making weak connection.
