  1. Actually here in the river bottom just got to drill down to below the river level. I've got a fairly shallow well at 50 foot.
  2. If you ever bring down hives to my place I've got all natural setting. No weed spray here. Sad but true both neighbors spray weeds. I don't care about weeds so there is dandelions in my yard so what you can aways eat those or make wine. Plenty of flowering berry bushes like raspberry and blackberries. Then all the fruit trees in the spring of the year. I'm highly against the use of any chemical control for plants or weeds. The part I don't want to contaminate my ground water.
  3. Still use it just stay in higher gear and start earlier. The only time you get into trouble is pulling down through the gears too fast. Like yesterday I showed a friend that I can pull down so hard on dry pavement that I can get it locked up and hopping. So it's all in the manner of how it use and how quickly your down shifting with the exhaust brake on.
  4. Wheel cylinders, manual adjustment of the shoe slack, if you got the weight valve on the rear removing the rod and tie the arm in place.
  5. That can be resolved. There is ways of handling drum brakes. I've got them on my 1996 and work good.
  6. First pad change was at 185k miles. Here is what I removed at 185k miles. Fronts... Then the rears...
  7. Here is where I need to see the high side pressure. I need to be able to look at lo and hi side and then I can base the amount more so.
  8. I would stop there. Like the foot states if the pressures are below and discharge temperatures ar good then your fine.
  9. So how high is that now? Those are just cinder blocks? How do you keep them from toppling over with settling or shifting?
  10. Exhaust brake first, budget pads second. Typically it's very rare for me to even touch my brakes being I do major of stopping on the exhaust brake. Budget pads so I have the lowest content of metal in the pads to prevent eating the rotors. 267k miles and still using OEM rotors yet, turned once and never been replaced.
  11. Give perspective to micron sizes so other will understand. 35 micron (or 0.00137795 inches). Just a bit bigger than white blood cell. Just think of it, we run 3 micron (or 0.00011811 inch) fuel filters which is smaller than a red blood cell. As for the washable filter. Still not too happy with the idea. Just way too much that could go wrong during washing and reassembly. We've had all those problems in the early years with Fram filter and other name filters letting go and plugging a oil jets, or doing engine damage. Now here we are talking about a filter and taking a risk with a washable filter that you don't ever get anything on the wrong side and its passed on to the bearings or oil jets. It would spell disaster for the engine.
  12. That's cheap... Local shop here was doing rotor turning for $40 a rotor.
  13. I know heat is not an option consider the block temperatures and it not releasing with all the heat it sees in the life time. It's going to be solvent base for sure.
  14. Gotta go through the diagnostics and see if it point you in the right direction.
  15. MAP sensor or O2 sensor would be my first thoughts. Typically there would be a code or light with either if too far gone.
  16. You done nothing to fix the APPS P0123 code. Possible Causes 5-volt Supply At APPS Shorted To Voltage (Engine Running) APPS 5-volt Supply Circuit Shorted To Voltage APPS Signal Circuit Shorted To Voltage (Engine Running) APPS Signal Circuit Shorted To Voltage APPS Return Circuit Open APPS Signal Circuit Open From APPS To ECM APPS 5-volt Supply Circuit Open PCM (APPS) Circuit Shorted To Voltage With The Engine Running PCM (APPS) Short To Voltage With Ignition Key On APPS Open Between PCM And ECM Open APPS Circuit Accelerator Pedal Position Sensor (APPS) Engine Control Module
  17. Because as you discharging the can into the system the can got cold. So what I typically do is fill a small bucket or pail up with hot water and place the cans in hot water to regenerate pressure. Basically you need to keep the freon above the boiling point.
  18. Like my own rotors. At 185k miles when I did my first brake job. I had them turned on a lathe and trued.I had them measured bofore and after and only took .040" of a inch on the worst one to get it true again. So here I'm at 267k miles and still rolling on my OEM rotor and my second brake job no issue.
  19. No. Just bring the RPM's up and see what your pressure are like. See if the compressor is going to excessive cycle out. Remember you DRIVE your truck not IDLE in parking lots. So the A/C should be charged enough to prevent excessive cycling. Now under normal operation eventually it will cool the cab to the point you turning down the fan speed. Now I except the compressor to cycle because the evaporator temperature will fall even more. So the lo side pressures typically fall more. Then mild cycling of the compressor will occur because of excessive cold temperaure and prevent freezing of the evaporator. To see this happen roll up the windows let the cab cool on MAX A/C and now turn the fan speed to low and watch the lo side pressure it will fall to about 25 PSI and kick out the compressor. Look at the inner ring you'll see the discharge temperature is just below freezing. Optimally you want enough freon to keep the evaporator sweating. Hence why I normally head towards 35-40 PSI so when the vehicle is driven the lo side as close as possible to the freeze point without trip the lo side cutout.
  20. 2 Cycle oil basically follows the same kind of rules like engine oil. As standards and specification change they continue to hold that level never regressing back. So Ashless oils are standard as far as I know.
  21. That's why I love my manifold set. I can read both the hi and lo side pressure making the best choices in pressure based on temperature. I typically place a thermometer in the vent and monitor better the manifold and the thermometer. Now @leathermaneod secret to said. The lower the lo side pressure colder it will become but... You need to have enough low side pressure to prevent cycling of the compressor. I can tell you that Dodge's lo side switch is about 25 PSI for cut out pressure. So typically I aim for about 30-35 PSI on the lo side. This will prevent excessive cycling while driving which you can see if you have a second person raise the RPM's to 1,500 RPM or so. The pressure will drop again on the lo side.
  22. I want to see the new place... I'm curious of how you built it up.
  23. I'm done even trying... No sense in even posting anymore so far I've lost 3 threads to oil related argument I'm done...
  24. Actually you are just hell bent on selling me AMSOil... Sorry No.
  25. Sorry I'll have to agree to disagree. So many way I can alter you "delta" values that I make it look good..
