  1. I'm sure you'd heavily fined now by a DOT inspector if your caught removing front brake system today.
  2. Absolutely true... 14.5 Volts x 140 Amps = 2,030 Watts (heat) So now upgrade to 200 Amp... 14.5 Volts x 200 Amps = 2,900 Watts (heat) So where is this heat going to be dumped? Right across the diode pack. The whole problem is every one is putting bigger and bigger alternators in that just means more and more heat generated. The only way around it is high quality diodes on a oversized heatsink... But there is still going to be quite a bit of heat generated on the diodes from switching.
  3. Not exactly something I suggest doing but in a pinch it will get you home if you know what your doing. I've practise with my truck off and on and very capable of rowing up and down without a clutch at all. Just need the clutch to launch beyond that I can float all the gears up or down. Again this is not something I suggest...
  4. I was speaking generally. Not all vendors are the same but some do matching before shipping and some don't. Still I want ask for both pop and flow matching before shipping.
  5. Only if you specify you want it done. Of course there might be added price because of this... Other than that 6 random injectors typically go in a box.
  6. Basically 7 holes with each hole being 0.012" in size. So it would be fairly large nozzle. So like 5 x 0.012 would be the same size holes but only 5 holes which ends up being smaller. I've seen every thing from 5 to 7 holes so far but holes sizes could vary greatly. In the past it was rated on approximate HP gains now its mostly how may holes and how big. Tidbit to help.. http://www.wattsshopperformance.com/Injector_sizes.html
  7. MPG is based how fine of a mist you can spray with the nozzle size you select. Make it more interesting is being able to burn as much as possible at very low boost pressures (less than 5 PSI). So this emphasizes more so on nozzle quality. So if you getting injectors I would highly suggest you have the pop tested and flow match for the batch you purchase. Now just 6 random injectors pull off the shelf and stuff in a box.
  8. Still running highway speed limits and you'll see mixed towing and empty driving. Fuel logs for June... Yes that 13.8 was my firewood run. 9.2 was just moving the truck in the yard a short distance.
  9. Even buying the part separated from Autozone you can do it for $95... that's a $55 dollar saving do it your self and bleeding the system out before you install it. http://www.autozone.com/drivetrain/clutch-master-cylinder/duralast-clutch-master-cylinder/dodge/ram-2500-3-4-ton-4wd/2002/6-cylinders-6-5-9l-turbo-diesel/426195_0_0/?checkfit=true http://www.autozone.com/drivetrain/clutch-slave-cylinder/duralast-clutch-slave-cylinder/dodge/ram-2500-3-4-ton-4wd/2002/6-cylinders-6-5-9l-turbo-diesel/426213_0_0/
  10. I'll agree city water and chemicals that treat the water can be problematic.
  11. Check under the dash for fluid leaks at the push rod of the clutch pedal.
  12. Wow. Impressive. Mostly highway miles I gather? I average about 30,000 to 40,000 for set of tires typically. The dirt roads ten to eat them up plus heavy chip coating out here.
  13. Also check your shop floor for this little ball to see if it rolled away somewhere if you dropped it by chance.
  14. Another 130 mile run including a 7% grade that is 7 miles long. I was not towing this trip just the truck. The weather outside is extremely hot at 104*F. Kept with posted speed limits the whole trip there and back. The most I've seen for transmission temperature was 165*F for brief time going over the grade. The rest of the trip it floated 158-162*F more or less a needle width below or above 160*F.
  15. As current flow increases so do the AC voltage. There is still frequency that you have to consider but can't meaure.
  16. Well here is a song I enjoy from my personal archive. I've got a weird taste in music...
  17. Ok... As for the PCM did you do any wiring mods or AC noise filters or voltage regulators (transmission)? If so make sure the power lead is still connected to the PCM. I've ran across @pepsi71ocean that his brother installed his voltage regulator for the transmission wrong and cut the power wire to the PCM. So this causes a weird issue of when the blower motor comes on the NO buss message and the transmission goes into limp mode (unlocks) and then as soon as you turn off again it goes back to working normally. So double check any and all wiring modifications you have. If you need to remove then from the PCM and return to stock form and see if thing work better.
  18. Typically you need a fairly expensive meter like a Fluke or SnapOn that cane read as low a 2V scale or lower on the AC side. I see lots of cheap DVM in hardware stores for $10 to 20 and only measure in the 200 volt range this is not low enough it must have a 2V AC or 200mV AC setting.
  19. Fan clutch is loaded with a thick oil it normal when cold to hear the fan locked for the first say 1/4 miles then unlock. Mine does the same thing most in the colder winter days. My fan clutch locks up typically around 208-210*F the stays locked as it falls to 195*F or close to it then unlocks. I've only had one time that scared me the fan didn't lock till 218*F come to find out the thermostatic coil on the clutch was all buggered up with packed dirt and dust. Too much dirt road traveling. I will mention anyone that is attempting to use water other than distilled and its known city treated I would be very cautious of that. Chlorine and other things added to the water can already set the water for low pH making it corrosive natured from the get go. I've even used my well water during times when there was no irrigation water available. Still no issues with well either. The whole trick about it is my water here is very close to neutral pH level so there no corrosive nature to cause problem like distilled. Even though both sources of water have mineral in it it doesn't hurt nothing as long the water is not corrosive. Now like Riggins, ID city water I would not use that with a ten foot pole. I know that was start like already very heavily treated with chlorine and you can smell it in the water. As for the ppm of hardness of water. Again personally I don't think the hardness has anything to do with it. It has to do with pH of the water where people living in the city and using treated water already start out lower or higher than a pH 7 from chlorine treatment and already forcing the coolant to compensate for the pH correction giving shorter life to the coolant. Once the additive in the coolant is washed out the coolant can no longer hold up and scale blooms start to form as the metal start to corrode away. Since my water is rather neutral already it has no impact in the coolant since it does have to correct for pH. Again if mineral and dissolved solids where an issue then my radiator should of been packed tight by 14 years and 263k miles as you can see it did not happen and still will not happen. So if you in the city or know that your water is already offset from neutral pH then yes you will have to shift back to distilled water.
  20. This should help... 0.010 to 0.030 normal good alternator. 0.050 and up is marginal... There is some people that report strange happenings at this level. 0.100 is a fail. The diodes are damaged and producing too much AC noise.
  21. When I get some more free time I'll do just a "Alternator AC Noise" article.
  22. If the panel has a good aluminum frame you should be able to create some sort of folding legs with basic hardware. Then you'll be able to set it just about anywhere to catch the daylight for charging. Like this afternoon in the heat of the day went out and watch a DVD movie for about hour and had the water heater turned on to give the dog a bath with the outside shower. Last time I check the voltage I was still 13.2 with everything still running. Day before with everything shut down and just the panels out there is was bounce off the regulator cycling up and down at about 14.5 volts. I know it would be nice to have just a wee bit more power but when I go out boondocking I really don't need much typically there is no over the air TV, rare that I might watch DVD movie, but keeping the fridge, powered up is easy. Some use of lights at night is typically recovered in the morning hours. Water pump and furnace would be you biggest eaters. But you don't have fan forced heat nor do you have a full bath so you power requirement should be easy to cover with at 100 watt panel. I'll admit I'm a bit tight at times with mine would be nice to have 100w (7.1 Amps @ 14.0 volts) compared to 45w (3.2 amps @ 14 volts)
  23. Some people think I plain nuts then... The only water ever used in my cooling system. Yep... Just good old Idaho creek water. Flush the block, mix my coolant load it back up. 263k miles and absolutely no mineral or scale build up. As I've been documenting this since first coolant change till now. Radiator and cooling system still spotless. As for the photo in my coolant flush article the radiators was removed for cleaning. I spray the front and back with degreaser and power washer both faces. As you'll see the battery cable laying on the valve cover and the radiator is missing. So while I was doing that I flush the block out from top down. Being there is no way to run it and flush it. As for the whole scale mineral scare. I personally don't believe mineral scare really any more after 255k miles of absolutely nothing but creek water. I've seen factory loaded distilled water and HOAT coolant look complete scaled up on the inside the radiator. Again that is cause by the coolant become corrosive and oxide of metals turning into scale blooms. Kind of like the previous owner of my 96 Dodge distilled water and coolant... Shouldn't eat the thermostat housing. Again its not because of the distilled water but the coolant become corrosive and dissolves the metals into solution which now creates the scale blooms. This is where your minerals come from. I suggest @leathermaneod to do what makes you happy feel the best...
  24. Updated video... Other videos are deleted now as well so this is the only video in my library for AC noise testing now!
