  1. As for the grease in the ABS sensor hole... You going to find out later it will impact the sensors and not function. I've got old grease leaching out of the bearing that has natural graphite the metal in the grease is acting like a gap filler so the sensors is reading all kinds of weird speeds and constantly ripping ABS codes. So you've been warned. No you can't wash it out now. My front unit bearing are tight no issue there but the tone rings and full of grease If I blow the grease out using compressed air it works for about 1-2 days and the grease gets back in the tone wheel screwing it and trip the ABS light. As for the pan gasket... You just rebuilt that engine and changing a pan gasket this early? It's not even a year old yet.
  2. 4060 / 2 = 2030 / 3195 = 0.63 * 50 = 31.7 (32 PSI) 4580 / 2 = 2290 / 3195 = 0.71 * 50 = 35.8 (36 PSI) Math looks good. Just never seen tire pressure so low for such a high weight rating. Just going to see how it works out for you. I still say scale the truck out ans see what the actual weights are for safety. because just from the tire stand point of inflating to 50 PSI on all 4 tires should carry 12,780 pounds on the truck alone. What you see in the photo is exactly what my weight were sitting on the scale with my RV in tow. My empty weights a bit different.
  3. Try the calculated and see how it does. At the most you can add 5 psi to your calculated number.
  4. Well I guess you'll just have to try it out.
  5. That rather disturbing with load range D's with that kind of weight and only 50 PSI limit. If I'm not mistake typically load range D's is 65 PSI and Load Range C's are 50 PSI. Double check your information on the tires again hard to believe 3195 at 50 PSI. If they are truly 50 PSI max I would highly consider getting different tires with at least load range E's for towing safety.
  6. Won't matter for the pressure calculation but might matter for the weight that might be placed on the axle. Might be over the rating of the tire. You can verify the tire weight capacity on the side wall of the tire. 235's are 3042 @ 80 PSI as long as the weight capacity is greater than 3042 pounds (gives 6,084 axle capacity) you should be fine.
  7. Really easy... Need to weight your truck with the trailer. The quickly do your calculations on your cellphone and readjust your tire pressures. Like my tire pressure are for towing...
  8. Here is what these trucks are rated for right out of the manual. 3 weights are GCWR, short bed and long bed
  9. I'll try that in the morning... I got to head to McCall for groceries.
  10. I would suggest just replacing the overflow valve if the spring is weak or failing. There is a test for the overflow valve..
  11. Sometimes there is a suction leak. Which in turn never leaks out. So with those kind of leaks you have to prime the system best you can and pressurize the fuel tank with compressed air (1-3 PSI). Now with a buddy crawling around under the truck you should be able to spot a dripping leak on a suction line maybe.
  12. First load done... Extremely happy with the performance. Heading up the mountain this morning at about 9am it was about 65*F and the most I seen in transmission temp was 160*F dragging 1,800 pound empty trailer up 8 miles of steep road. Spend the better part of the day cutting and loading. Being slow about it being I'm a bit out of shape yet. So here is the load 2 cords roughly of red fir still a bit wet yet. So I went back down grade in 2nd gear riding the exhaust brake most of the way down. At the very bottom where I hit the highway I seen 160*F from descending 8 miles of steep grade. When I started off the top at 2pm it was about 85*F. When I hit the valley floor it was much warm like 97*F. As for steepness of the grade I could leave my exhaust on and it would hold my speed constant at 18 MPH most of the way down. So now my 25 mile run back home is a mild up hill run with cruise control lock when I could running 65 MPH. The most I seen was 170*F even with 800-1000*F EGT's. So I would have to say that even with summer heat and towing, slow dirt roads, climbing and descending it did very good.
  13. Now the question is... How many of you personal have broke a grease-able joint? Be honest... ZERO for me... I wore plenty out but never broke a grease-able u-joint.
  14. Be careful. The grease idea is great but over doing it will create ABS issues. Like my whole ABS problem is because the graphite in the grease is getting into the tone wheel and screwing up the speed sensors. So even though there is nothing wrong that I can tell of my bearings I'm going to have to replace the unit bearings because of grease getting into the tone wheel area. Weather changed from yesterday to today. I had a run yesterday down deep in the canyon where the weather made it to 95-97*F. Running along at 65 MPH the most I seen was 160-165*F not quite to 170*F this was strictly all highway. Still that is nothing to cry about. Then today cloud cover moved in and dropped the temperatures and even after climbing a steep grade of about 8-14% for 5-6 miles at 15-20 MPH I barely made 110*F. Of course climbing at those grade angles and driving slow will create some serious EGT's. Again made little impact on transmission temperature. So transmission temperature are more about outside temperature and pyrometer (EGTs) has very little to do with it.
  15. 1. I've never had to do a dash yet for either my 96 or my 02 yet... So I can't answer that. 2. Yes there is a special tool it about $8 fro Napa and its just a plastic collar you push into the spring lock and pull the tube off. 3. I typically charge $40 labor and what every the price of freon is for about 2.5 can (12 oz). As for recharging you need to be able to pull a vacuum on the system to remove moisture. I've rebuilt several Dodge Ram A/C systems not hard just time consuming.
  16. Grid heater relays are arc closed. Just need to replace the grid heater relays.
  17. Here is more information on that... http://www.srh.noaa.gov/wgrfc/
  18. Drain for the HVAC plugged up and holding water in the bottom? Like @Me78569 said heater core should give off a sweet smell as the vapor blows off. About 90% of the time those kind of issues end up being the heater core. The only other moisture would be the A/C side and it holding moisture in the drain area because of blocked drain. Other than that there is no other moisture or water source in the HVAC system.
  19. Another spot that seem to be impossible to find the leak is the compressor front seal. It won't leave dye and impossible to snif while the truck is run with a fan blowing.
  20. If I'm not mistaken my AirDog 150 is 14 AWG wire and 10 Amp fuse.
  21. Ummm... There is so much I want to say about that but don't want to offend anyone that might be a cat owner. All I can say is that is just Wrong...
  22. Droplet size. For example nice hot day say 100+ outside. Now take a standard garden hose at 60-70 PSI and spray nozzle and create a fine mist upwards in the air. That mist will most likely evaporate before hitting the ground. Now take a 2 1/2 fire hose at 60-70 PSI and nozzle attempt the same thing you'll end up with water on the ground and evaporation will be poor because the droplet size is too big. TFaoro on the other hand is using boost pressure to created the added heat to burn the fuel by twin turbos. More boost pressure means more cylinder heat to convert the larger droplets. Just remember just cranking the engine around will produce 400-450 PSI of compression more boost means high cylinder pressures, which in turn means bigger nozzle injectors can be used because the heat is present to burn the fuel.
  23. As for temps like today I had a 60 mile round trip down canyon to look at a stall issue on a truck. Even on my way back home climbing the canyon again. It hovered like this all the way home.
  24. When it comes to oil change time the grease gun and oil change occur at the same time. I even pull the front shaft out so I can grease the 2 near the transfer case.
