  1. Most likely in a PTO cover plate.
  2. This last truck I was working on had both grease-able upper and lower ball joint. Rather strange to see zerk on a lower ball joint. I've got no idea who makes them.
  3. I don't trust most public bathrooms. Then like motels and hotels are clean for bathrooms but the bed is the issue. Never know if there is bedbugs or if the bedspread has been washed or not. I'd rather drag the RV to where I need to go than staying in a motel. Always nice to eat a meal that is not fast food or restaurant prices.
  4. The only thing I would be worried about is it plugging up enough to possibly cause fire issues?
  5. Kind of like @Dynamic discussion of transmission temperature gauges and temperature ranges of normal for ATF+4. Even he was on the low side at 220*F if I remember right. I'm going to invest in a ISSPro trans temp gauge for the NV4500. Foolish not too.
  6. Yeah I've been learning about gear usage in the little 1996 Dodge Ram 1500. You find that the most efficient gear will produce way less heat in the transmission. Again I'm not sure what happen I'm just taking a educated guess at the failure and it behavior. I know there is Quad 4x4 for most of the parts on the NV4500. So that is one resource for parts.
  7. 61k miles. So I'm going to say it could be syncro material darking up the oil but I'm thinking heat more so. That what I want to do is get it on the floor and opened up and inspect everything. Still got to see what happened with the 3rd / 4th gear issue I'm really curious if its a bearing or what.
  8. As for today I got the front and rear drive shafts out, the transfer case is out, slave cylinder is removed, and just got the 4 bolts holding the transmission in. My right knee is hurtin' so I quit early. I'm all setup for dropping the transmission. When the shift tower was removed I can see some in the inside I don't see any broken teeth on gears. The gear lube I drained out was darker than normal so there is sign of heat issues. No metal that I could see in the oil. I'll be ordering a transmission temp gauge for this one too. If my knee if feeling better in the morning I'll most likely get it dropped to the floor and popped open to see what happened. Other than that I'll wait till Friday and have @Taz drop it down with me.
  9. @TFaoro Holy cow dude. That just cruel to let your truck lope and knock puking out lots of unburnt fuel.
  10. The only thing I would change is I would toss hardware mesh behind the floor vents to keep little things from dropping in the floor duct.
  11. I've got a similar effect with all the dogs we've had and even Diesel. It seem when it comes to play time he looks towards me for the fun and excitement. Then when they get sick it's not MoparMom he goes but me. For some reason, they know how will take care of their particular needs. Animals in general are strange but if you pay attention you can friends with even wild animals. Every winter I've got flocks of small birds that winter here now knowing there is a supply of food and water through the winter time.
  12. Awesome... Neat to see animal husbandry...
  13. At least I'll have fresh transmissions in both trucks now.
  14. @Hawkez Could you do us a favor and create a rebuilt article for alternator suppling those links? This way everyone can find then in the article database.
  15. Like this picture. Heavy red with fuse is my fog lights, red wire without fuse is AirDog, black with fuse is cab accessories. Cover goes back on and the batteries are clean and don't have four tons of cables tied to the positive post. Much much clean under the hood. WARNING! Do not use the other stud. If the alternator fuse should happen to blow the PCM with crank up the field voltage attempting to charge the batteries but can't because of the fuse is OPEN. Any device tied to the alternator lead will most likely be damaged or destroyed electrically when the voltage spikes out over 20 Volts. This why I warn people about the old method of wiring the AirDog to the alternator which is a very bad idea...
  16. That's funny... I was talking to @Taz he's coming Thursday for his ISSPro gauges I order him. He's made the comment "I better close my mouth now or we'll be doing 2 transmissions". @IBMobile That makes sense being there is no grinding. Got all the other gears just 3rd and 4th are out. Thanks guys you giving my the confidence to dive into this.
  17. Like myself I'm running wide open on my Edge Comp (5x3). I'm only using the sublevel 3 for smoke control. Light right foot, low boost, low EGT's net the highest MPG's. S like my previous post about more aggressive the tuner the better the MPG is true.
  18. Thanks for the comments... I'll look into and see how much damage or carnage happened.
  19. That would drive me crazy. Being it's my first rebuild. I'd be afraid to use my truck then. I wouldn't trust my first attempt rebuild to travel long distances. Like my first engine rebuild I won't leave the valley with that truck for a long time because I didn't trust it. If I get my act together tomorrow I could have it yanked out and open it up and see what happened. I'm curious of what failed. I'm pretty sure its a bearing and the shaft moved and the gears are not lining up now...
  20. I've never done any transmission work ever... So its a gamble with poor odds of success for me.
  21. Suggestion... Master Battery Feed hook it up in the PDC not to the battery. This way the wire never deals with corrosion issues.
  22. Heck I'll have mine out on the shop floor by tomorrow. Making phone calls and getting transmission sent to Boise. 6 hours be back home and ready to stuff back together. Strange part is I'm pretty anal about monthly fluid checks and dealing with things as they come. This caught me blind sided and NV4500 just crapped the bed. But a rather common failure... https://www.google.com/search?client=ubuntu&channel=fs&q=nv4500+3rd+and+4th+gear+missing&ie=utf-8&oe=utf-8
  23. Heck I'll have mine out on the shop floor by tomorrow. Making phone calls and getting transmission sent to Boise. 6 hours be back home and ready to stuff back together. Strange part is I'm pretty anal about monthly fluid checks and dealing with things as they come. This caught me blind sided and NV4500 just crapped the bed. But a rather common failure... https://www.google.com/search?client=ubuntu&channel=fs&q=nv4500+3rd+and+4th+gear+missing&ie=utf-8&oe=utf-8
  24. @TFaoro What do you got to lose? Why not if they are willing to take your old transmission for some cash for core I would jump on it. Funny I got home and MoparMom telling hit your network of people get some information. I've got to give @MUDDY over at http://idahoturbodiesels.com the credit. I called him and he told me to call "Six States Distributing". When I heard the price I'm even thinking that's a bill even I can swallow. Being there is a Boise office why not I can get it yanked out in a few hours and be down in Boise picking one up and slamming back in. Again I'm glad it happen here at home... I guess this goes along with CSM "Burn out before I leave" POW!!! All you can say is a few choice words and deal with it.
