Taz's 06 Dodge Ram 3500
@Taz showed up to my house on Thursday for his gages and a-pillar setup. Also had a few other things to fix like his exhaust brake not working and also got a windshield banner. So here is the gauge setup. ISSPro EV2's chrome rims, blue on white background. Now the fastener for A-pillar is a chrome bolt and washer looks very stylish and proper. Much nice that standard old hardware bolt. Then he wanted a nice windshield banner too so I got that stuck to the glass...
Finally.
Ok. That would be like my road from Whitebird grade across Lake Rd to north side of Grangeville. Is posted 45 MPH I'm typically running 55 MPH is a dirt road cut off that saves the time and mileage of driving into Grangeville and back out again... My choice of roads that day was a bad idea but it gives an idea of the throw...
Finally.
Same here. Most of the city streets of McCall are graveled roads then most of New Meadows is too.
Finally.
Weird.... either I'm lucky because of the canopy or because of the trailer design.
Teardown and Rebuild
The other part has to do with the GL-5 is not compatible with the syncros from what I've read and like for NV4500 that fluid was design to over come the hard shifting in cold weather operation. I can't speak for the other tranmissions but I do some research on what I'm running...
NV4500 Questions
Also could be the same thing I've got a problem with. 4th gear syncro. Later today I get some photos. Like I've learned already the syncro more so of the detent action that the top cover is. Take quit a bit to push with your fingers a shift ring over the syncro on a good syncro.
Finally.
I'm also out here in the back country dirt roads towing trailers but never had this issue of rocks flying forward at the rear window or tailgate. Are you running without fenders or tires hang out of the fenders or something?
automatic transmission late shift
First off all alternators are the same for the most part and have been for years. It just back years ago other there was no computers. So now as a diode or brush pack fails the AC noise increases and what happen the AC noise increases and computer go nuts because of the AC noise. I hate to say it even Ford and Chevy have the same problems too just manifest in different ways. So it's not the the design of the alternator its the on set of all the computers. Like you PC your using right now like to have PERFECT 5V and 12V for the motherboard thats why its got a power supply with noise filters and everything. So technically the best way to run your truck would be off the batteries without an alternator which would be absolutely clean DC power. Problem is the batteries won't last. As for steering I've just about master correcting most steering issues as long as there is stock or smaller sized tires. Even for 261k miles perfect tight steering just like the day I bought with 43 miles on the odometer. Still got OEM tie rod ends yet! So as you read the four reason you'll see the VP44 isn't really the problem everything around it. VP44 not an issue. There only 4 ways to kill a VP44. Excessive AC noise from the alternator. Low fuel pressure. Less that 14 PSI is asking for trouble loss all your cooling flow. Filtration most people toss the stock can it best to double up stock like FASS 150 or AirDog 150 against the stock can. Fuel Lubricity. It should be <450 HFRR (Bosch Standards) but US diesel fuel is typically ~520HFR. Air Filter thumping noise is for the most part normal because of the megaphone effect of the BHAF if installed. You can go ahead and verify the valve lash and do a compression test but I'm pretty sure everything will be fine. You not complaining about white smoke on startup, unusual cranking speed with surge, or misfiring. Vacuum pump seal kit is only 13 dollars and typically change them out in about 1 hour. No problem Most all plastic exposed to lots of UV's and heat tend to degrade. That's another thing that I still don't have a problem with. If you got a 47RE automatic talk to Dynamic he's a transmission guru and can build a heck of transmission. As for the 47RE is actually based on the old 727 Torqueflite from back in the 70's. Dodge has been using that transmission since 1956. The problem was and error was the transmission was designed around a V8 HP/TQ where its high the RPM span but the Cummins is much lower and the transmission doesn't deal with it good. Then toss on power mods and the trans gives up early because most like to defeat the torque management and build more low end power. POP goes the transmission. There is another very weird design flaw that we all suffer with but no one every talks about... (another chapter...)
NV4500 finally died...
Tomorrow I'll try pulling the rear cover off and and do this... I want to clean the case out really good there is crud in the oil holes. I want to clean it out really well.
Well... Errr... Ummm... I have no idea what I'm doing... I got the top cover off but no idea how to get the shaft out... Good normal wear appearance... None that I seen... Know more if I find a way to get it apart. (Dunce Smiley)
Got the transmission out. No broken gear teeth. 3rd and 4th gear syncro is broken. You can select 3rd or 4th gear by sliding the shift collar and the shaft is free spin yet till it hits a snag in the shaft then hooks but not enough to pull the truck.
Busy... Working on 2006 Dodge for the weekend... @Taz is going to help me drop the trans this morning...
I don't have either. I'm looking to do a single ISSPro Trans Temp gauge and the two sensors. One for the transmission and then one for the rear differential then add a toggle switch to toggle either transmission or rear differential temps. I'm thinking ahead on this one...
ZERO. Should be DC power with little to ZERO AC Frequency...
New doesn't mean good. I've seen new alternators failed right out off box. Any alternator you buy make sure to have tested. I typically buy reman'ed.
Flooded out.
Strange how the group of people became more family like and worrying about each other. I'm sure if there is member near you that are reading this might try and help. I think in the past during a few other events member have got together and helped where they can.
Having an RV is almost a needed item now a days.....
Lot of truth in that...
We need a truck for the new mopar1973man tshirts
Dang... I love the truck just so much black it will lose detail like the hood, grill and every will wash together. Another spot would be the black on the tire and wheels.
My SON!!!!!
Congrads to your family!
Flooded out.
I've been flooded out twice right here in Idaho. I know the pain and heartache you must be going through. Hopefully the river drops quickly and allows you get things cleaned up quickly.
Ball joints
If I'm not mistaken... The upper ball joint isn't a true "ball joint" its a shaft joint.
What I've got a problem is this group pushing their beliefs on the rest of us. It might not be our place to judge but every one always speaks about the "Good Lord" above but you have to remember there is always the dark side of thing like the Devil below. So where do you draw the line saying "I believe in the Good Lord above and these actions by this group are unacceptable." Then at the same time being quiet and not speaking up is like saying you accept their way of life. How does one go about handling these moral issues? Tough I'll admit but I still hold true to the Bible. Leviticus 18:22, "You shall not lie with a male as one lies with a female; it is an abomination." Leviticus 20:13, "If there is a man who lies with a male as those who lie with a woman, both of them have committed a detestable act; they shall surely be put to death. Their bloodguiltness is upon them." Romans 1:26-28, "For this reason God gave them over to degrading passions; for their women exchanged the natural function for that which is unnatural, 27 and in the same way also the men abandoned the natural function of the woman and burned in their desire toward one another, men with men committing indecent acts and receiving in their own persons the due penalty of their error. 28 And just as they did not see fit to acknowledge God any longer, God gave them over to a depraved mind, to do those things which are not proper."
Rainbow... Maybe...
I have to buy SPONGE which is suggested by Timbo. Sam I highly suggest AGAINST any noise filters or tin foil tricks this just points to a bad alternator problem. Rather just replace the alternator or rebuild it to keep the rest of the system from getting fried from AC noise issues. So you'll do all this and still lose your VP44, ECM and other computers. Fix it right have the alternator rebuilt or replaced.
Steering column pod. That the only open spot. The Edge Comp will be relocated. I'm considering doing a bit of sensor and switch magic and getting a second sensor too and wiring a toggle switch and install a rear diff sensor too.
