NV4500 finally died...
Even on my 46RE on the 1996 Dodge Ram 1500 it has a drain hole. Weird part is it mounted with a gasket but not really needed. So during assembly I just married them back together and not bothered with any sealants or gasket. It will be the same on the NV4500. I'll take the time and dump the transfer case and everything and clean up everything I can.
relay board and accessory power feed
I'm curious where this is getting mounted...
All I can say I'm glad it blew up here and not out on a summer RV trip that would piss me off to no end knowing I would be at the mercy of any shop I get towed to. Most likely have high prices, crappy install, no way to claim warranty on the work. At least here at home I know I can get the R&R done myself and know its done right.
Bad part is having all the special tools to deal with bearings. I'd already asked @Dynamic about doing it and like he mention there is special tools for some of the bearings and such. You have to be able to split the shaft up and get new syncro's, bearings on the ends etc. I would if the core core was a few hundred I would just buy a new one attempt to fix this one. When the core is $1,530 and the transmission is $1,500 I'm not going to sacrifice $1,530 for core so I can gamble a rebuild and lack of knowledge the odd are against me and my pockets are already empty.
The the truck I trailered back to the owner was a 6 speed I really don't like it. Row out 4 gears to get to 30 MPH the 5th and 6th which is the same at the NV4500. Like in my 5 speed I row out 1st to 3rd gear to get to 30 MPH then got 4th (1:1) and 5th (0.75) that are the same as the NV5600 (5th is actually 0.73)or G56. I'll keep the 5 speed. I never in a million year thought my transmission would wipe 3rd and 4th. It like the bearing failed the shaft is moved and the gears don't quite make it. They still tick like they attempt to but nothing. I've seen rebuild kits for $350 or so. I just don't have the knowledge of manual transmissions to dive in. Jon said he's done a few but not really set up to rebuild them properly. Dang! That man there is Automatic Guru.
Teardown and Rebuild
Just feeding the fire over here "Six States Distributing" has NV4500 transmissions for $1,500.00 but with a $1,530 core. Don't feel bad I just wiped out 3rd and 4th gear on my truck. 1st, 2nd, 5th and Reverse still work fine. KInd of bad timing but good... At least it happened near home, I had a trailer in tow so just did a bit a rig swapping and got trailered home. I've got my friend coming from Washington Thursday so we'll have a wrench party. Install his new ISSPro gauges sitting here and then drop the transmission out of my truck and go to Boise pick up there other one. Hopefully I can get one into Boise quick enough while I got hands here. So my thread is split over here...
Hua? Who else killed a transmission?
261k miles and my NV4500 finally died. Not the 5th gear nut. I lost both 3rd and 4th gear. I was just leaving my place pulling the trailer back to New Meadows, ID with the a truck on the deck. Got into 3rd and the stick was rattling oddly. Poured the fuel to her to get rolling and it popped out of gear. Difficult to get into 4th. I knew the transmission had lost a bearing or something. Got up to New Meadows flats and check everything over no leaks. 1st gear works fine, 2nd gear works fine, 3rd pushing against you and BANG! Then tried 4th its missing. Rowed to 5th and barely had enough power to get the truck going. I had another 5-6 miles to go before cell service. I got a hold of the owner of the trailer and truck and told him to meet me at the 45th parallel. So we swapped truck and and loaded mine up and I got trailed home. I know Jon (Dynamic Transmissions) doesn't do manuals but I still asked if he knew of anyone. I talked to Muddy of Idaho Turbo Diesels he told me to call Six States Distributing. So I called there main office and they can get me a NV4500 for $1500.00 with a $1530.00 core. (Holy Crap Core Price!) So I found out Six States has a Boise Office but just missed them they are closed. Just for fun I called NAPA and there price was $2359.00 with a $484.00 core. No go there... Funny I didn't break the input shaft because I still got 1st, 2nd, 5th and Reverse. Just 3rd and 4th are gone.
Boost with the smarty
Depends when you look at the transmission is just the same old 727 from back in the 1960s and 1970s and just added 4th gear to it. https://en.wikipedia.org/wiki/TorqueFlite
Time to upgrade Programmer
I'm sure your MPG will fall for the first few month as you play with the new found power. After the newness wears off then you'll buckle down and get tuning to get the MPG's.
New truck, help with codes
I just had one do the same thing tripping that code and found the battery temp sensor was unplugged. So verify there is no broken wires or the sensor is unplugged. As for high charging voltage double check the green wire and verify its not shorted to ground. I've seen a few cases where this happened and creates a runaway alternator.
Front passenger brake problem
Also take a look a the springs too! Springs over time will degrade in pulling strength so it might not be strong enough to pull the shoes back in. Most parts stores set hardware kits for drum brakes that typically replaces everything spring wise. http://www.oreillyauto.com/site/c/detail/BHH0/H2314/01271.oap?year=2000&make=Dodge&model=Ram%2B3500%2BVan&vi=1434797&ck=Search_01271_1434797_-1&pt=01271&ppt=C0064
Retirement,,, He's counting down...
Turbo Intake Boot
I use orange degreaser from Home Depot to set my boots up. It extremely slick while wet but becomes sticky after it dry. The boots really are a PITA to get back off. http://www.homedepot.com/p/ZEP-128-oz-Heavy-Duty-Citrus-Degreaser-ZUCIT128/100676344
W&F Hauling stuff part 2.
I've got a bird crap welder. I need something I'm not going to fight welding that back up ad grinding for hours to straighten back out. So I'll get a professional local welder to do it.
Crazy idea is to install a needle valve in the valve in the vacuum line. That way it would slow down the vacuum source so the PCM can't over shoot the acceleration process.
I'm "trailered up" and hauling a load bright and early to welding shop. Some managed to yank the track bar right off the axle...
I'm already running a small version of this. 4 place terminal strip. +12V Battery +12V Keyed Illumination Ground Position 1 is a 20A fuse lead out to the PDC battery terminal. Position 2 is a relayed power by position 1 triggered by key ON. Position 3 is tapped at the radio lead for gauge lighting. Position 4 is grounded to the body inside the cab no need for battery connection. For sure keeps you from hacking up a stock wiring harness, also removes the junk from the batteries. Old picture but the concept... So cleaning the battery up from this... To this...
Front Crank Seal Help .... and show and tell of what the dealer did
That one reason I still love the old spring clamps. No guess work. Slip it on and release. Always a good clamp.
Pretty soon it will be trailer time for me as well. This year I want to setup the 1996 Dodge Ram 1500 for my wood hauler. Being Dynamic did the 46RE transmission rebuild and upgrades. I can pour the weight to the trailer now.
RV Battery Charging From Trucks Alternator
Now you understand why I chuckle about roof mounting solar panels on a RV. So using what I show on the house panels the RV would be unruly hot but you'd have power. The only reasons people place the panels on the roof is the lazy and hopefully no one can see the panels on the roof to steal them. That does pose a problem with free standing panels they can walk off. I would like a better spot to store my panels but don't have any where else to store them. Mine are fairly heavy and rather difficult to weasel out of the bedroom back outside.
Torque Converter Lock / Unlock Issues
Alternator is done. Time to replace. You can rebuild it yourself but make sure to get both diodes and brush kit. There are other kits cheaper than LarryB as well. I will admit his diode packs are expensive. Make sure to get rid of all tin foil and wiring mods.
electrical gremlins
Most all cab related grounds go to the driver side kick panel or center of the dash. All engine related (ECM, PCM and VP44) go to the passenger side battery directly. The rest of external stuff are typically to the driver side fender shield.
Like mine fit under the bed. I know JAG1 has limited room being a slide in camper. This is the only thing I could find quick of JAG1 camper.
Just another update. The sun is going down on the ridge and casting shadows in the yard. This point I've lost all charging solar for the house. It's done for the day. My solar controller shows 0.4 amps at 24 volts or 9.6 watts.
