dually
Everything posted by dually
  1. http://forum.mopar1973man.com/showthread.php/1681-Muffler-questions This may help.I am on the record with hushpower.How can you go wrong with the word hush and power.
  2. I have used a gas fuel pump to pump diesel fuel.I say why not.With mine i added a fuel filter.If it is a spare pump ues it.
  3. Hushpower for me.It has a funky cone something or other inside that they say gets a few hp on a dyno.
  4. I did a search on dpm diddnt come up with it.Sorry
  5. Just start going up slow, mine jumped a few numbers and i went back 1/2.I just did what it said because there is no magic number you are looking for. Just a 1/2 back.When i turned my timbo apps back per instructions.The voltage did not drop much.I used a screw driver with a 20 torx bit.It was easy to turn it up and back down looking at the handle to see a 1/2 turn.I went real slow.But to each his own in reguards to tools.
  6. It does.When you install you should get something like .620 (Just a example)Then you put a volt meter on.When is starts to go up you turn it back 1/2 turn.This will take up the slack in the pedal.Now the timbo apps is set.The pedal to the floor is to tell the computer the new voltage.Thats how i see it.I dont know about the reset.
  7. As far as the big brand names i here good things about goerend.I had what i call a first gen suncoast.It was good.I do here bad things about ats.Never had one just hearsay.
  8. THANKS ! Your hard work will save everyone time and money.I love hanging out where the smart people are.Hope it all rubs off and stays.
  9. http://www.genosgarage.com/prodinfo.asp?number=TPS98502 This is a timbo apps.That price is only 9 bucks more than i payed.So your better off than 450.00 from the dealer.This is a breeze to install.It comes with real good directions.You will be fine.You will need a digital volt meter.
  10. If you shim out the oil pressure relief valve you can get a little more oil pressure. ---------- Post added at 08:26 AM ---------- Previous post was at 01:08 AM ---------- This is why i did it.This could of happened for a number of reasons.I wanted to try a free fix.I have not looked at the rocker in a wile and i am not sure i want to.
  11. We have 2 here as well.Thats why i need work for monday:thumbup2: I am thinking i took one for the team (The me, myself and i team) and my efforts will buy me some time before i have to do that again. I can only hope.Truth is i dont mind helping out.
  12. Thanks Michael for correcting me i diddnt know that.So what did you get then?Did you get the bellcrank like the one in the picture?Or just the sensor?
  13. Talking about no work.You will never guess what i did yesterday.Now i know none of you know me.I am just a normal person like the rest of you crazys.That being said you will still never guess.I am however a go getter and when i have no work this is all i do:ahhh:.So i am walking down my hallway and i look into the bathroom.When i bend a little and stare at the toilet I see something funky looking back at me.Oh no! a stain under the rim of the toilet.Now i am employed !! I am on a mission.So i get the bleach and my favorite brush and have at it.Man thats work.I got it, and man does it shine.The best part ,i did this all wile my wife was playing on the computer.She seen me doing the work.I scored mega points Man i hope i have work on monday.
  14. This is the back.If you are NOT going with timbo apps and you diddnt buy the entire pc.Then you have to turn this pc to match the voltage on the white tag you see here.This one here says 0.553.So thats what you need to see on the voltage meter.And this is done by rocking this clock or counter clock wise.If you DONT have a timbo apps DONT turn the screw in the first picture.Edit :hey Michael I was kinda racing you:tongue:.No work today and to much coffee:hyper:
  15. If you are using timbo apps this is the one.Use a volt meter soon as it statrs to go up turn it 1/2 back and your done.Just did this yesterday.
  16. Atd builds there own converters.I dont know about banks.From what i understand after 120 hp or so.And a few beat sessions the factory trans will not be happy.
  17. I only ran 3 different turbos.None are on your list.A buddy ran the ats with good luck.I like the package deal.Dont forget to pre lube it before you start the engine.
  18. It has been a wile i cant remember.Somewhere around 4500.But you could spend less.Each billet shaft is 800.00.I diddnt use my old suncoast single disc converter.I also went with a manual valve body.Stuff like that adds up quick.Atd can rebuild your converter set the stall speed to whatever you want.You may just need it freshened up.I know a factory rebuild is something around 1000 give or take.Charlie is the man to talk to.Edit 1500 to rebuild.+ or -
  19. If you are sure thats all you are going to do thats one thing.If you get the hp bug you could go with a triple disc torque converter.That will hold just about anything you can give it.A billet input shaft is a smart idea as well.I dont know if there is any tranny vendors here.If not try these guys.http://www.autotransdesign.com/ They built mine.Whatever you are planning for your truck these guys know how to do trannys.You dont have to make 600hp to have a tranny built here.The shop has a tranny dyno and they build converters in house.They will ask you what you need and then build it.I went all out, i pound on mine with nitrous and shift at 3400 sometimes.It withstands a beating.Another dude i know with a 800 hp cr pulls with his.Season after season no problems.
  20. That plate doesent change 1 and 6.They are small because of the casting.I have a sidedraft like the one in the picture mine is from zz fabrication and it is for a vp truck.I have his prototype (the first one).If you cut off the intake and get one from zz it is the only way to get max flo.You asked it anyone has input.I dont, but if you read up on it you will see that the problem on our heads are 1 and 6.This will do nothing for that.My question to you is what are you trying to do?What are your goals for your truck? Not worth the money.People getting max mpg and going fast dont use this.
  21. That was cool and funny.I think i seen that in person over 20 years ago when i went to my first grateful dead show:wow: i sure love old country music.
  22. I can see your point Guesswho512.There is a difference with building a hot rod dd like me and doing something to your truck that kills the diesel community.I will just sit in the corner and watch.If in 2 or 3 years there is smoke laws in every state i wont say a word.I diddnt mean to upset the ballance of this site.Knowledge is power.
