Me78569
Everything posted by Me78569
  1. I think I have plugged my truck in 1 time in it's life. Most of the times I have had to do extreme cold starts I didn't have access to a outlet. The truck starts to idle rough for ~30 seconds when it gets to 0*f above that I dont see any issues.
  2. My truck doesn't cycle for that long subzero. its more like 20 seconds. I dont know if IAT has been at -40*f ever when trying to start. quite a few times at -30*f.
  3. Cranking timing is ~17* then timing when cold is higher based on ECT. It a roughly 6* over stock bump until ect are near 160*f.
  4. It might be. Even with stock injectors I followed the same cycling the grids at given temps. My 7 x .012 330 bar start easier than my 7 x .009 at stock bar. It might be at higher than x bar starting gets harder, but I am not seeing yet. I will be curious about 350 bar.
  5. My truck has always been a little harder to start when cold. If it's sub zero I cycle 2x sub -20*f 3x
  6. I would blame the fuel before anything else. I would guess the station just wasn't on top of it. It happens
  7. Part of the reason why I went to group 31's. Couple -40*f days in a row resulted in a hard to start truck. Cycle the key 3 times then crank
  8. https://mopar1973man.com/topic/12002-quadzilla-v2-custom-tunes/
  9. as the father begs, " please son anything other than a 2nd gen, it's front end will drive you to drinking"
  10. I would leave the cheapo tablet there, the samsungs seem to have issues importing tunes due to a custom rom they run.
  11. Pretty much, are you going to turn more than 3500 rpm? Fluid damper says dont worry if you aren't. I used the ARP bolt kit as well.
  12. I actually put one on this morning haha. A pin kit is something they sell that allows you to put set pins in the fluid damper
  13. you are running hte boost offset with the 2.7 base flash? connect to the truck, set boost ffset to 0 psi. What does it read? set it back to your old boost offset setting, what does it read?
  14. The quadzilla adds at least 2x more power. you answered your own question on lvl 6 you are adding under %33 of possible wiretap. That extra 100 hp the quadzilla gives you is being eaten up by your slipping clutch.
  15. lol I am nervous for you. I hope they run as well as mine do for you.
  16. youtube "merry christmas from the family" robert earl keen
  17. you have the wrong profile selected in the app, choose the 1998-2002 v2 profile. Samsung devices have issues with the file association. They block the normal andriod method. seeing this a ton on samsung devices.
  18. try to email it to yourself and open it from the attachment form. Is this a samsung device?
  19. same super 40 wheel I think
  20. So you opened the iquad app first, then open your download foilder? then tried to open the json? what app are you using to open the download folder?
  21. It's a basic sensor any shold work. nothign special about it
