98whitelightnin
  1. I like the polished and the red. These are not sludgers so they should stay fairly clean with regular oil changes.
  2. I like it! Hard to tell where van ended and boat began before they split. Would have been funny if a john boat would have floated out of the back of the van instead of the the actual back of the van floating away.
  3. Welcome Logan, beautiful truck!
  4. Super tech is the only stuff I have ever used because all the other stuff is at least twice the price.
  5. I know its a long shot but I just stumbled across this on Craigslist. http://dallas.craigslist.org/ftw/pts/3730786403.html He says no shipping but it may be worth a shot.
  6. I believe it would be hard on shafts, probably not a good idea without billet.
  7. I believe its an exact cover, you could run without the oe cover if you wanted.
  8. Would it be that hard to drill and tap out own cap?
  9. I use the cheap ceramic pads from oreilly's or the house brand I your choice. It is a simple job if you have a jack.
  10. Very cool! I need a pair of snap ring pliers like that.
  11. I have a napa 190 in right now. It runs between 186-190 depending on speed and temp.
  12. I'm in that percentage too. My temp fluctuation ended up being my ECM.
  13. I believe a resonator will be all you need.
  14. Check out the fuelly link in my sig. My mpg's aren't as good as yours but are better than some.
  15. I ended up cutting a piece out of my factory column cover so the auto meter cover would fit tight over it. I cant remember if I used double sided tape or if its just setting up there but it does not move or anything.
  16. I always flush both out to back flush the heater core. Don't know if its right but it has worked fine for me. Don't use alot of pressure, just the hose with no pressure head.
  17. A Baldwin pf7977 will fit in your stock can and filters to 5 microns. Isn't there an o-ring that you can replace on the drain valve?
  18. My buddy got a smoking deal on an early 04 from a co-worker because it has a dead lift pump. 1st one lasted 195k on the block and he went to oreilly and picked up another carter. I would put a fuel pressure gauge on it and not mess with it until it goes out.
  19. I see another problem with this, we don't have pics!
  20. I wish I had remembered that you said you would make me a harness. I ordered one from Stern Thursday a week ago and have heard nothing, have not been charged yet either. Ordered my grandpa one and it arrived in 3 days:shrug:
  21. My wife and I went on a little back road riding tonight too but only got fries and ice cream.
  22. I would not run them if you cant get the lug nuts on all the way. May try some 3rd gen lug nuts and see if they are different or may go longer studs. Smokin deal on those Alcoa's though, they will look awesome!
  23. I have set the tank size and as far as I know I calibrated it. Had it for a while so cant remember really but I would like to think I did.
