98whitelightnin
  1. My little boy is in the top spot for ride of the month and its the picture you and moparmom like Mike, Check it out. http://www.cumminsforum.com/forum/ride-month/515112-july-2012-rotm-contest-cummins-kids.html
  2. Sounds like he has more money than brains.
  3. Welcome to the fam, dump that isolator when you get back and you wont have anymore problems.
  4. I just ordered that mechanical gauge and hopefully it will be here mid next week.
  5. My old quad commander would turn almost black after it had been setting in the sun all day too so i usually kept it covered with something.
  6. I have been considering it more and more lately but this temp thing is driving me up the wall. When I get it fixed there will be another problem so I dont know why im letting this one bother me so much. - - - Updated - - - If I were to put another temp gauge in the location of the oe sensor and not even have the oe sensor hooked up would the truck run right or without a temp reading would it think the engine is cold? Mike, what ohm resistor would it take to make it think its running about 190? I may hook up another gauge just to see if it fluctuates, if it doesnt I will hook the oe sensor back up and move the external gauge down the head a few ports. - - - Updated - - - Lookin at this gauge http://www.ebay.com/itm/261052269133?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  7. Also, I just had problems with my tq convertor locking and unlocking in the rain but after I cleaned terminals and resset apps it was fine until I flushed the engine out. There must be something that is getting wet on the passenger side when it rains and I got it wet again tonight because on the last run it was acting a fool again. Anybody wanna swap a 1st gen 5 speed for a 98 24v auto?
  8. I just drained and flushed mine with hose water and took it up the road with no change. I just wish it was more evedent waht was wrong so I could fix it.
  9. Dont know if I mentioned it or not but this problem all started directly after I put on a vulcan big line kit. Are there any wires or something I could have hit during the install?
  10. I enjoy smoking meat and really enjoy eating smoked meat. I dont have a smoker now but if I make a trip back to Tx with the truck, im bringing one back my grandpa made.
  11. I was suggested a gates t-stat because they only have 1 jiggle pin so I ordered one from rockauto. Well it came today and looks just like the napa t-stats with 2 jiggle pins. I put it in and it acts the same way but then I remember my buddy with a d-max saying something about electrical something or another in the radiators of chevys hurting something. When I had my radiator cleaned and rodded I put it back on and just ran water for a day or two and it acted perfect but when I put antifreeze back in the same ole fluctuation starts again. I never had a problem when I ran the green stuff but have had since I started with this red fleet stuff. I wonder if there is any connection?
  12. I would go with the vulcan kit since its less than half the price of glacier.
  13. Cleaned terminals and resset apps and it drives as it should.
  14. It didnt change anything, still shifting crazy. I cleaned the battery terminals for my monthly cleaning and will take a run in a few minutes.
  15. Dont know if this will help but these are the instructions I went by. http://www.tstproducts.com/Torque%20Converter%20Lockup%20Switch.pdf
  16. The newest in my lock-up issue's are now it lock/unlocks rapidly when its raining or wet out. I went to TSC the other day, it was dry out and the trans shifted perfect but when I came back outside it was raining really hard. The roads were flooded and the truck was locking/unlocking rapidly, like twice a second. Now even after it quits raining its still doing it so im gonna pull the alternator fuse and take it for a drive. Will report back shortly. - - - Updated - - - No go, pulled fuse and still shifting.
  17. Unless you have a built trans or stick shift I dont think you notice the power as much with new parts.
  18. Belt dressing.http://www.kpg-industrial.com/products/belt_dressing/ There is only one belt so the ac might be locking up.
  19. Ok Mike, what do you think of this? I went to tractor supply earlier and the trans shifted as it should but when I came out it was raining really hard and I was it town so I put it in 3rd and as soon as it shifter to lock-up, it went crazy, locking and unlocking 2 times a second untill I hit the lock-up switch. When I got on the highway and hit 4th lock-up it did the same thing. I went to the movies and when I came out it wasnt raining and the road wasnt as wet and the trans almost acted normal again except the occasional glitch. I have babied this truck like crazy but I get nothing in return so now in driving it like a teenager pissed off at the world!
  20. IAT is intake air temperature. If my memory serves, Mike uses a 2.2 k ohm resistor in his iat sensor to trick the engine into thinking its 143 degrees outside for best mileage.
  21. He said he did but it was still a little hard.
  22. Are your hand calculated mpg's close the the scangauges mpg figures? I ask because my ultra-gauge took several fillups before it would get even close to the actual mpg's and it still never was right so i quit using it for them.
  23. My grandpaw has one in his 6speed and likes it but it made the lid a little harder to shut.
  24. You can text or call me if you have any questions during install.
