		Raptor FRRP and 1/2" line
		I have a small wix inline filter before my pump and then just the stock filter afterword. I have never seen anyone else mount their pump where I did mine but I like it up out of the way.
		Replacing an Apps on a 2002 Dodge Diesel
		I dont think the factory replacment needs adjustment but I wouldnt buy one of those either unless its real cheap. Why not get one from Tim? http://www.dodgecumminsapps.com/
		Tranny Temp
		I have mine in the same spot and see the same temps.
		53 block
		http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
		tv cable adjustment?
		My trucks shifts good and firm but if im in 3rd and slow down to 10mph or just below it wont downshift to second and sure is a slug taking off again. It will go down to first if I stop completely or 2nd if I all but stop but I would like it to shift to 2nd if I slow down to 10-20 mph. Do I need to adjust the cable or what?
		Tensioner Sqealing
		The chirp is the compression hitting the belt but you will get a squeel all the time if the pulley goes bad.
		Tensioner Sqealing
		Mine started squeeling a few months ago and I bought a replacement pulley from advance auto for under $20. It was a simple fix.
		Newb in Kentucky
		Welcome to the fam Nick
		TC Switch
		I have had one for a few years and its nice to have, especially on a cold morning to keep the rpm's down. If I turn it on I keep my finger on it the whole time im driving so I dont forget. I did forget one time and I thought my brakes went out because it kept pushing me along and didnt want to stop. If im coming to a stop I turn it off at about 1000 rpm, if I just have to slow down I unlock between 40-45 so not to slip my convertor.
		tc hunting again?
		I have to reclean my battery terminals and resset my apps every few months or I get it too. In fact mine just came back last friday.
		slight surging type of feeling...
		Does it change if you turn the edge off or up/down?
		Pulled this lastnight
		98whitelightnin replied to 98whitelightnin's topic in Utility Trailers & Recreational Vehicles (RV's)I run my comp on 2x5 for daily driving for the best mileage and was also running 2x5 for both pulls. Lee's injectors run clean and cool, you can only see a little puff of smoke when I first took off. I built about 5-7 psi boost and let her eat. It hovered around 1100 then close to the end was between 1150 and 1200. --- Update to the previous post... Those Bd's will run hotter if they are 8hole nozzles. The jammer 150's I replaced with these 7x.010's ran hot. The hottest I saw with them was passing someone on a small hill one time on 5x5 to the floor and when I looked up it was at 14**, I checked my dataloging when I got home and it like something like 1640.
		98whitelightnin replied to 98whitelightnin's topic in Utility Trailers & Recreational Vehicles (RV's)I think they are 125-150hp, they run really good. They never hit 1200 during the pull and im still running the stock hx35.
		98whitelightnin replied to 98whitelightnin's topic in Utility Trailers & Recreational Vehicles (RV's)Most of the people were on the same side as my wife but it still wasnt a big turnout. There were probably more pulling trucks in the pits than therte were cars in the parking lot.
		This was our first pull and white did great and I really enjoyed myself too. Did not get a full pull but pretty good for the first try. Second pull was better but just a few feet shy still. This is where I ended up on the last pull.
		Wheels for the 2nd gen
		Yes, they should fit just fine. I ran some on my 98 and currently run the 3rd gen aluminum wheels.
		new injectors
		I run Contagious 7x.010 and couldnt be happier. It idles smooth as glass and runs like a champ with very little smoke. If you have never pulled the tubes I would go ahead and get new o-rings for them because they will most likely be rotten.
		I think I just found Heaven
		I have never found a station with bio in any of my travels but would like to.
		Texas Hail Storms
		He is supposed to talk to them either this weekend or next. He bought this new lexus in january and a month later someone keyed from front to back. He just got it out of the shop a month and a half ago for that and now this. he cant win for loosing.
		Texas Hail Storms
		My dad caught the last hail storm that came through Dallas a few weeks back, beat his new car to death.
		Best Value Rotors
		I also have oreilly rotors and just the cheap brake best ceramic pads and they work good.
		scan gauge
		I use one for my truck and the other in my car. I guess my brother put a little pressure on the screen at one time because its got a red blotch in it.
		New Kid From Texas. . .
		Welcome to the fam Will.
		scan gauge
		I got in on them when they first came out and it was $39. Several people said theirs didnt last long but mines going for about 1 year now. My brother bought one too but didnt mess with it so he gave it to me.
		scan gauge
		Dont forget about the http://www.ultra-gauge.com/ultragauge/index.htm
