015point9
Everything posted by 015point9
  1. If it's got a PVC valve take it out shake it if it rattles okay you're good but doesn't rattle get another one
  2. Glad it worked out for you. Also glad that Mopar mom can get in and out of RV. Gives you lots of options in case flooding or whatever and she can still get medical care or travel to safer place. I accidentally left an LED light on in the front pass through storage area and 2 days later when I noticed it on, nothing burnt or anything.
  3. Ibmoble.... Is she watching or supervising?
  4. Good idea. Probably measure next week after going on longer drive. If I remember right...Oil starts to coke up around 500?
  5. Out of couriuosly. How much better comfortable ride and braking on 2018
  6. Thanks...I'm not going to race wifes CRV. ?? And not sure if turbo is water cooled or not, which might a difference? Honda forums, mostly kids messing around. Little practical info that would benefit everyday common sence driver. Thanks
  7. Wives 2018 honda... I want a egt gauge. Dealer says installing gauge will void warranty. Question... modern turbos. No big deal on idling down temp before shutting off?
  8. Are head studs an upgrade when running extra power or a safegaurd for a known problem or ???
  9. What exactly happens when your prostate goes?
  10. You know when you're old... Doing taxes today and getting on some websites I only get on once a year. Security question , What was my first car? (Answer) Rambler Does date myself?
  11. Underneath view...pull tap about at 3 o'clock
  12. We had same problem. Wife wanted new lens. Actually found new entire light cheaper. Back side of light had manf info.
  13. Not saying those LEDs that you linked to our good or bad. We found a good deal two or three years ago swapped out everything and within the first three months about four bulbs burn out. And a terrible smell that lingered. Smelled like burnt plastic and wire, the only thing that got out the terrible smell was burning a scented candle. Made big difference with battery life. Very noticeable of how much longer we can go without having to recharge the batteries.
  14. Is that "airdog sencor hole" post filter or pre filter? (Testing with manual gauge at airdog and elec gauge in cab. I get about 2 pounds difference between testing at airdog and at vp44. Not sure if gauges at 100% percent accurate or pressure drop between the gauges or if airdog test port is pre or post filter.)
  15. So what do those heads weigh? And are they somewhat "cemented" in place to get them broke free at first?
  16. I had just the opposite problem, wanted to put on some air bags and turns out that my turnover ball hitch brackets was in the way. My recommendation is to call the hitch place and and talk their tech support. To see if they could send you some pic's of what others did. I was able to find some pictures of what other people have done as a work around the problem. Googling, there's some pictures and about all of them the people of had to custom weld something. Problem is trying to get two things to fit in the same spot. B&W has been around for a long time hopefully they can send you some pics of how people work around it. Sorry I couldn't be more help.
  17. How long miles have you running a spinner and what to you think about it? Down to 1 micron... aren't you also catching some additives that are supposed to be good
  18. Have you tried contacting who made your mirrors that you have now and get a replacement lens first thing? If no luck second thing... I had a right hand mirror that said the something like objects looks closer what it's supposed to be. I didnt like backing a trailer with it. I went to a mirror shop and they cut out a regular piece of mirror glass. $70 or $80. That was after I made a template out of cardboard.
  19. Okay didn't know that I thought. I've been waiting on doing the WT wiring mod. And waiting for wiring work around for grid heaters. Only wanted to mess with the wiring one time with the hood up. I guess I was wrong there.
  20. Thanks for the above. If I have it right in my mind you're also working on some type of work around... if you disconnect the grid heaters the trouble code check light wont come on?
  21. By California truck do you mean one that was sold in California that something done to it or.. one that is legal to sell in California? Is there any type of label or sticker that I could tell the two apart?
  22. Same here. Also sent txt to 1 number that I have but no response.
  23. Moparman "PM box closed, use public forum" OK... Cant find your address to send check. Yes I know you wont cash till you get the chance. Please post line with info Thanks
  24. My most useful mod...and hopefully nobody will ever see it. A chain that has a lock and nut/bolt securing my spare tire just in case spare tire winch comes undone again.
