Everything posted by dripley
Truck is "dead in the water"! HELP!!
You could try putting 12v straight to the pump and see if it runs and you get fuel out of it. Have you ever checked for codes? - - - Updated - - - You could try putting 12v straight to the pump and see if it runs and you get fuel out of it. Have you ever checked for codes?
Opinion: towing and nv5600
Aaaaaa, negative. Afraid to look now.
Please be aware of the roads you driving on!
He's darn luck the trailer did not slide off the hill and take him with it.
:iagree:I would have to agree with the above. Though I dont know much about the 5 speed. I had one for about 2.5 years but it was attached to a V10 gasser and would not pull the trailer in 5th except on flat ground.I do have a set of Fast coolers for mine but I cant find them. Whaa!! Whaa!! Whaa!!
Over filling 6 Speed tranny
I get the noise in 4th more so than any other gear(1200 to 1400 rpm) and not in neutral. But I have a Valair and not the OFE. I dont know how different they are.
I pull my 5th wheel in 6th gear as long as I can pull it at half throttle. Once I start loosing speed I will downshift. My last trip was from Terre Haute and think the only time I had to use 5th was in the 55 mph zones. Definitely pretty flat out that way and I was pulling 15k pounds. You probably wont even know your trailer is back there. Just take your time and drive however you are most comfortable with. Stopping is always whats on my mind when towing. - - - Updated - - - I need to add keeping an eye on your gauges, EGT and ECT mainly. I made my last trip thru the Blue Ridge mountains with my Banks tuner removed and it did behave differently. The tuner protected me from higher temps and I noticed I had to watch them more closely. If they started to climb I backed out a little to keep them under control. This was while crossing the mountains and the rest of the trip thru the foothills and flatlands was pretty normal.
Yet Another 20+ MPG Tank
Always thought it a little strange myself, but I guess they did not ask for our vote on how to do it.
My 02 has the CAD. some of the early 02's have them. I bought mine in October of 01.
5 OBDII Error Codes! Won't start. Thoughts?
I would think it would be on the pump somewhere, not sure where though. Never had any cause to need it.
I have a drainage ditch along the road in my front yard. I just drive in it with the passenger side down and fill it thru the filler hole.
I was a little naughty...
I like my exhaust brake for tailgaters. Just wish I could see there eyes as the tailgate blocks there entire windshield.
What I read was to get more oil to the rear of the tranny for the bearings. Read enough to convince me it would not hurt anything. Had the taranny continued in the trucks longer Dodge and/or New Venture might have been an advocate of the extra quart too. But we will never know since it was discontinued. I see it as cheap insurance on an expensive transmission.
clutch hydraulics
I bought mine from Advance Auto. Dont remember brand or part #. I just asked for one that fit my truck and put that one on. I have the valair clutch and I think 3800# pressure plate for 2.5 years with no leaks so far. You definitely feel the difference between the oe and the Valair, especially stuck in traffic.
Dead pedal, codes, and bad news from tests - please help
Your VP will be much happier with good fuel pressure and last longer. As far as MAP and APPs codes, I would not think the fuel pressure would have anything to do with it.
Small Chain of events and ABS pulsing
- I have been learning a lot on this site
Its the diesel fumes. Stick around and it might happen to you.- 5 OBDII Error Codes! Won't start. Thoughts?
Install is not difficult at all. Mike has a good article on replacement http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/126-bosch-vp44-injection-pump-replacement. Blue Chip Diesel has one also http://www.bluechipdiesel.com/vp44_install.html. They are both good articles and will walk you right thru it.- MOD - Installing a digtal thermostat
I like it. I dont however enjoy the 10* temp swings as MnTom mentioned.- Advice for long trips as vacations.
A decent set of hand tools is about all I ever carry. If something breaks I would not have the right part more than likely. I know others who do carry some spares, but its just not worth it to me.- Dead pedal, codes, and bad news from tests - please help
Mine acted very similar when the ECM crapped out. It would idle but surge like it had a mind of its own,rev very slowly no matter how far you pushed the throttle, and a lot more codes than you have. Pretty much undriveable.I would think it is the ECM, but lets see what some of the other folks have to say. I like all the confirmation I can get when a part is that pricey.- battery terminals
I appreciate the input. I have used the the clamp on style in the past and never liked them. Thats why I was looking into the solder on style. I replaced the passenger side negative a couple years back with a crimp on and it has held up well. My other negative is developing a crack and needs replacing soon. Just want to be sure and get the right size. I figured replacing the positives might be a good idea while I was in there.- Hello From AR
- New Member - 1997 Chevy 2wd crew cab dually 12v swap
Welcome Brad. Sorry I cant help with your Chummins, but i am sure some one will have some thoughts on it. Good luck with your project.- Truck with rust ....... thoughts
I have been looking at some of those parts for my self since the lower left rear corner of the my bed got crunched a good while back. I got lucky and found me a bed in pretty good shape with a rear bumper in decent shape for $200 bucks. the only bad part is there is a hole in the bed for a goose neck. Cant complain much for $200 though.- Truck with rust ....... thoughts
LMC truck has them also. Just a tad cheaper, but dont know which one is any better than the other. http://www.lmctruck.com/icatalog/de/full.aspx?Page=21 - I have been learning a lot on this site
