Everything posted by dripley
Tires: Treadwright
I might have to agree with you on more pressure. If nothing else it would seem to me to wear the centers out prematurely. The photo does appear to show them riding on the center 2/3 of the tread. I am curious as to what you ended up with cost wise. Tires, shipping, mounting and balancing.
Can you top this one!?
My mother-in-law is Japanese and my wife 1/2 Japanese(other half redneck and I do mean red)and they can come up with some weird stuff to eat, but I think they would draw the line on that one. I sure hope so any way. I think I better be careful what I eat next time I am at home.
New Member- New Ride 83 F250 with 24V Cummins
Wire nuts and butt splices, definitely some concern. The one picture you ask about the ECM. It is the PCM in the photo. The ECM would be on the left side of the block if it was left in the stock location.
Beating a dead horse?
This is what i did. I closed the drain valve and left the toilet valve closed and hooked up to the rinse connection and left the water on. I then proceeded to the beer locker and stopped and talked to the neighbor. As we were BS'ing, I noticed water coming off the roof of the rv. Somebody forgot the water was on. It actually filled the black water tank and went up the vent pipe and was venting water onto the roof. Fortunately I had already dumped the tank and was just rinsing. I did not even know that was possible, but it is.
New Member from Central California
Welcome again, I would have to agree with Mike, both inside and outside of the hood.
nice looking truck and welcome to the forum. That was one nasty looking air filter.
I do use a chemical in the hot weather for odor control. It can knock you down like MM says. I just use something mild and inexpensive. I am not trying to dissolve anything, its not in there long enough. Just for odor. I usually rinse mine once a month and it keeps it clean and the sensors still read just fine. When I travel I will leave 5 gallons in the black tank so it sloshes around and rinse it when I first set up. Now this is important about rinsing, never connect the hose, get another beer and start talking to the neighbors. It can lead to a mess.
Butt pucker!
The 4 or 2 wheel low gives you better mechanical advantage and works everything a little less. Another way to think when backing is, if you want the trailer to go to the left steer to the right. You want to go right steer to the left. The trick is learning when to following it up so you dont over steer. That is one that just comes with practice. I still over steer mine sometimes and just have to pull up a little to regain the angle you are looking for. Happens to all of us some times.
2002 Edge Comp Wiring Help
,All I see is tapping the pump wire, no mention of the stealth plate. Call DAP and ask them. They cant void it for asking. Jacob will be straight up with you about it.
You dont have to tap the pump, but to get the full benefit of the comp, tapping the pump is necessary. Tapping the wire will void the warranty. I have seen some vendors state that the stealth plate will void the warranty also. some dont.
I use it. It cost more but not enough for me to worry about. I have used regular when necessary with out incident but still but the rv stuff. That is most in depth discussion I have ever had about TP.
Jobs around the house you hate
Seems the older I get the more I enjoy working on and around the house as long as it is on my terms and not say the water heater blew up and HAS to be replaced now. Painting is definitely my least favorite. I get home so little though that I am always behind.
You aren't making fun of my professionally crafted "blue" wiring harness are you?
The best 5th wheel hitch?
I guess I am not seeing what the pin on my trailer fits in. Is there something I am missing or an adapter you must by with it?
cigarette lighter and power port
Well this is going to sound bone headed but I took my snap ring pliers and tried to depress them, never tried prying them up:doh:. As you said they are hard to see but I could not feel anything to pry up on. I will give that a try this week end.
Well I have seen the black tabs, kind of rectangular i think. Definitely cant get at them by removing anything on the front. bet I could have seen them when the dash was out though. Sounds like I picking at the right tabs so I guess I will keep trying.
Has anyone pulled their lighter or power port? The FSM says there are 2 tabs in them you depress with snap ring pliers from the inside. I seem to feel something like that in there, but have not been successful in removing either of them. All I have done is booger them up.
No horn ...
There is also a relay in the PDC for the horn. You can swap one of the other relays in its place and see if it is relay.
fuel pressure gauge
Lone Watie is right. You should be reading your pressure up stream of your filters. I have mine plumbed into the line between the fuel filter canister and the vp. I chose to keep my oe canister in the system for the fuel heater and the water in fuel sensor. A little extra filtration does not hurt either. It is not absolutely necessary, just what i wanted. Dont mess with the overflow it should remain and the pressure reading there would do you no good.you can ignore the second picture. got it on there and could not get it off.
truck died while driving now no start
with all of the above. Your vp will love you for it.
I am going to have to assume that she either agrees with you or there is no way she is going to read this.
Latest mod to the truck
Hey Denhop, you might have to shoot some more pics the totm or the ban hammer might get you. Rogan can be obliging when asked.
Bought a Steering Shaft, Borgeson
The silver lining has come out of the cloud. good for you.
200000 miles
It s hell on the paint. My roof shows it.
Finally!
Looks good, Hex. Mine goes to the overloads and stops and the truck sits level. But being a long bed the center of my hitch is just forward of the center line of the axle.
